Question about Olympus VN5200PC Voice Recorder
Froze screen date will not set
Have a vizio tv model e550va mfg date june 2010 serial no ltlpieal2500661. don't have the remote. there was a problem with my cable and I tried to use buttons on the side.
Try a hard reset on set and see if that does it. Also check with Vizio to see if there is some sort of factory default reset provision. Sometimes you can access it with some of the controls built into the set.
Apr 30, 2017 | Vizio Televison & Video
Froze whilst playing a game nothing is working
you should go to your tablet setting and check it there.
if you can not find it i suggest you to change your setting to default.
Apr 05, 2014 | ASUS MeMO Pad HD 7
The tv froze up while watching netflix and won't turn off or do anything
Sounds like the CPU froze. Unplug set from power completely, then plug back in, should work. If not then the problem will have to be solved by a repair technician.
Mar 12, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
HP Pavilion dv6700. no screen.
Please run system restore to an earlier date.
Start system holding down f11 key till you hear a beep then follow the screen instructions.
Good luck.
Mar 21, 2010 | HP Pavilion DV6700T Notebook
Displaying time and date when printing
The date/time cannot be deleted once it is embedded in the image. To turn off the date/time deselect the date/time stamping by following procedure:
These instructions explain how to insert the date in images.
attention:
  • The [Date Stamp] cannot be deleted from the image data once it has been recorded because the date is written in as an image.
  • When selecting [Date Stamp] , [Recording Pixels] is set to 1600 x 1200 pixels and the compression (image quality) to [Fine].
  • When the shooting mode is set to <Movie> (g0029623.gif), settings for inserting the date and time cannot be made.
  • The following explanations are provided based on the assumption that the [Shooting Mode] is set to <Program AE> (g0034813.gif).
1. Press the <Power> button on the camera.
2. Press the <FUNC./SET> (g0046915.gif) button.
3. A screen like the one below will appear on the monitor.
Select g0013174.gif [Date Stamp] (g0013171.gif) in the [Recording Pixels] section g0013173.gif.
g0013176.gif Press the <MENU> (g0046624.gif) button.
4. A screen like the one below will appear on the monitor.
g0013173.gif Operate the <directional buttons> left or right to select [Date Stamp] and set it to [Date] or [Date & Time].
g0013174.gif Press the <MENU> (g0046624.gif) button.
5. Press the <FUNC./SET> (g0046915.gif) button.
6. Make sure that the [Date Stamp] is set and the following screen will appear with the icon (g0013164.gif) in the lower-left corner of the screen.
7. When shooting with this setting, the date will be embedded in the image as shown below.
g0013173.gif [Date]
g0013174.gif [Date & Time]
warning: The date, its font and color, and the position where it is displayed cannot be changed. Also, dates and times recorded with [Date Stamp] cannot be deleted.
If you need a manual for the A480, you can download it from:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=18155
Please rate this solution. Thanks.
Oct 15, 2009 | Canon PowerShot A480 Digital Camera
WELCOME SCREEEN PROBLEMS
You probably damaged the main circuit board and the settings like the date cant be saved properly so after reboot it thinks something has happened and wants you to re set settings and happenes again and again.
Oct 07, 2008 | Nintendo DS Lite Console
Palm Zire 71
The top plastic digitizer is defective.
It needs to be replaced.
There are several sources on-line to buy such digitizer part.
Best regards,
Jul 14, 2008 | Palm Zire 71 Handheld
Screen froze,now wont read any discs
if your system is only 5 weeks old PS3 factory warranty covers all defects in materials and workmanship for 1 year from purchase date. there are some inclusions and exclusions which can be accessed at http://www.us.playstation.com/Support/PS3/Warranties
but if you have any implied warranties from the store you purchased it at you should hit them up first to see what they'll do for you
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Nintendo ds froze
sometimes you could get the batery replaced by nintendo $$$
or you could buy it and do it your self
by the way when did you get it this (i assume) is covered under the warenty
hope i helped
Dec 31, 2007 | Nintendo DS Console
Olympus VN5200PC Voice Recorder Logo
23 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
