Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Clean flashing I suppose the relays and solenoid are located underneath the dishwasher?
    Top Expert:
  • Whirlpool Master
  • 34,255 Answers
Your supposition is correct
Posted on Apr 22, 2013
Solenoid under cab getting red hot
I am sorry but you have this posted in the wrong product category. Please re-post the problem.
Jun 17, 2012 | Cars & Trucks
Dishwasher won't start
Replace the control board, or...if you're capable, resolder the control board joints for the wire connectors and the relays.
That fixed mine after I wasted money on a heater.
Jun 17, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
GE Nautilus dishwasher isn't draining... PLEASE HELP
Check floater valve.
Inside the unit. On the floor. Looks like and small upside down cup.
If it is jammed in the up position it will stop the machine. Lift, clean underneath. It should drop and the machine will run.
The float valve stops the machine from over filling.
Could also be clog in the drain filter. Remove the cover from the drain inside the unit. look for clog in the filer of the drain.
If none of the above it is the timer. The timer tells the unit what to do (fill, run, empty). If it is not working the drain function will not run.
Adrian
Mar 07, 2010 | GE Nautilus 24" Built-in Dishwasher
Not cleaning Fills up with water at the bottom. Just not spraying. I took off everything inside to clean it out. Down to the grinding wheel. Pump feels like it running.
The water first gets pushed into the dishwasher from the water supply, then fills up until the float detects the water level, the water then gets drained into the sump pump and either drains to the plumbing or shoots up through the arm inside the dishwasher. Thats a basic cycle anyways. If it is draining into the sump pump like its supposed to, and not coming out through the arm, then something is blocking it or a solenoid/relay isnt working properly on the pump. If its not draining at all, which you would be able to hear if it were from the sucking or gargling sounds, then the same follows, just in different areas. I know its not to technical, just hoping to shed some more light on the situation.
Dec 28, 2009 | Kenmore 15129 Built-in Dishwasher
Whirlpool dishwasher won't drain? Model#DU5000xw
When it is suppose to be draining, do you hear the pump running.
If not, then the pump or controller/timer is bad. If the controller is sending power to the pump and the pump doesn't run, it's the pump. If no power is getting to the pump, then the controller is bad.
You'll need a voltmeter and know-how to diagnose this electrical problem. This is high-voltage power with water in the area. So please don't try to use a voltmeter unless you are confident of your skills.
If you do hear the pump, then the drain valve (solenoid) is the problem.
The solenoid valve and the pump are all underneath the unit. Accessibility from the front, bottom panel.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | KitchenAid Dishwashers
I have a GE dishwasher with the following model number: GSD3230F00WW. Last night, while the dishwasher was in the clean cycle, a buzzing/grinding sound came from underneath the dishwasher. I removed the...
The part you are referring to is the pump out solenoid. ( part # WD21X10071) When the dishwasher is suppose to pump out, power is applied to the solenoid and it swings a flap inside the pump assembly to divert the pumped water out the drain instead of up into the dishwasher. If there are no signs of water leakage at the solenoid arm, I'd just ignore the noise. Note: Newer models use a separate drain pump and no longer use the pump out solenoid.
Apr 19, 2009 | GE Dishwashers
Leaks underneath frount looks like the white tube that has a eletric control for water level
I decided to tell you of a generic problem for these models (Nautilus) and this is also a universal problem with every DW ever made,,,,It sounds like you are describing the float...lift the (inverted saucer ..hafl-bowl shaped float) up and listen for a clicking sound as you lift it up and down...you should hear one....if you don't the solenoid is bad...if you do it's good..(.so far)...look inside the float it probably is full of gunk...clean it thoroughly and replace it....(when these get filled with debris they stick in place...and the float is supposed to float to a certain level...which takes pressure of of the solenoid and when it clicks it stops the in-flow of water...if it is stuck(from gookus)..it will allow to much water in and you will develop a leak.
If this does not do the trick...please get back to me...(model #..in hand)
I hope this helps...Good Luck and thanks for rating my effort....The Fang.
Mar 30, 2009 | GE Nautilus 24" Built-in Dishwasher
Kitchenaid superba kuds01ijbs0 rinse only light flashes
hi! there only the solenoid valve for water supply has reciving a source to activate by your timer,the sequence operation of diswashing process has ben ignore,so the faulty was on your timer switch.disabling the motor to function you can check this in your panel front control.be sure to switch of power and service valve for water supply before checking.the fig are just sample as reference
to your dishwasher control panel so you can start where are those control.cb7265c.jpg
open front cover using screw driver,loosen screw holding timer control circuit try to clean all contact if defective replace timer
circuit board,check also the moter control timer using multitester
ser to R1 taking the continuity of terminal and contact point and some multi relay,solenoid valve supply.replace any defective part and reasemble parts after replacement,regard and have a nice day
Mar 20, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Dishwasher flashing green light
try to open the door and shut it that's supposed to acknowledge to the washer that you know the dishes are clean let me know if it works
May 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Water valve
The water valve, or water inlet valve is what lets water in the dishwasher. If it is filling and emptying at the same time, that is a different situation, and is most likely the drain solenoid. Take the bottom panel off the dishwasher and take a peek underneath. The solenoid may be simply stuck, but if it's an old dishwasher, it's most likely corroded or burned up and is stuck in the drain position. If this is the case, it should be replaced.
Apr 07, 2008 | Dishwashers
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
235 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
