Question about Bosch Coffee Makers & Espresso Machines
Descale red light, wont go off, and can i use any delcale tabs
Ive tried to descale my Tassimo machine for the first time, and in error, did not use the correct amount of water with the tablets, now the red light wont go out. Can i use any delcale tablets, and if i start it again, will it work, and will the light go out. Have i ruined my machine.
  • Anonymous Mar 24, 2014
    tried to descaler the machine, the "close the door"red message light came on can't get rid of it
Solution: Just refill the water tank with water (no descaling solution) all the way to the "Max Line". Then run the full descaling program again --takes approx. 20 minutes. After the program runs completely you will get the yellow "standby" light on and the red "descaling" light will be off.
Next time you descale, be sure and fill your water tank to the "Max Line" before running the descaling program.
Hint: An incomplete cycle (not full tank) is what makes the red light stay on. In other words, it's staying red to tell you to run a full cycle (beginning with the water tank filled to the "Max Line"). Hope this tip is helpful!
Posted on Aug 08, 2009
Descale my tassimo
This is a great posting on how to descale your tassimo
http://shay.la/descaling-your-tassimo-on-the-cheap/
Feb 03, 2014 | Home
The 7d(fill tank light) & 7e(descale light) are flashing simultaneously, what to do?
According to the manual, when both lights 7d and 7e are on at the same time, you need to contact Tassimo.
Sep 30, 2012 | Bosch Tassimo TAS1000UC 1-Cup Coffee Maker
I descaled my tassimo brewer, and now the red light wont go off pls advise
Hi, Red light means something needs attention. Descale solution is very corrosive and may have caused damage. I cant think of anything that would do this. Try switching it off and unplugging it for a few minutes. Hopefully resetting it will fix your problem. Dazza REPAIRER
Sep 23, 2011 | Braun Tassimo Espresso Machine/Coffee...
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
The red light is staying on, what do i need to do?
The light stays on if you do not follow the instructions when descaling. You must hold the button for 3 seconds to descale. It takes about 20 minutes. If you press the button for less than 3 seconds with the service disc you just run the water through quickly to rinse/clean and the machine doesn't reset the rescale light.
Feb 15, 2011 | Bosch Tassimo TAS4511UC Coffee Maker
Red warning light on bottom left dial is on. Machine still working correctly..... What does this mean? Thanks....
It indicates that it is time to descale your Tassimo. Consult their website for instructions and materials (warning, don't use vinegar).
Nov 24, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
Has anyone used vinegar to descale their tassimo machine without any damaging their machine? thanks
Never use vinegar to descale esrpresso machines since will destroy the copper parts in long terms. Vinegar is used onle on plastics and st. steel. Try to use special descaling powder which you can find online in ebay maybe
Feb 06, 2010 | Braun Tassimo Espresso Machine/Coffee...
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Mar 26, 2009 | Braun Tassimo Coffee Maker
Bosch tassimo
Sep 03, 2008 | Braun Tassimo Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
3,755 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
