Question about OKI C9600hdn Laser Printer
OKI PRINTER C9660 SERVICE CALL 128 : FATAL ERROR 01
SERVICE CALL 128 : FATAL ERROR 01 WHAT SOLUTION?
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
  • 78 Answers
SOURCE: fatal error 917 on an Oki C9600 printer
A fatal error 917 means there is a problem regarding the belt **** sensor.
Usually it means the printer can't see the transfer belt rotating.
First thing to try is to remove and re install the transfer belt, if that does not work you should replace the transfer belt.
Posted on Jan 07, 2009
SOURCE: does anyone know what is
If you look on top of the fuser roller(upper orange roller), there is a thermistor (orange rectangle plastic that rides on the roller) you will see four wires going into that housing. Two are for the thermistor and the other two is for the fuse that is built into the housing. You would have to use a soldering iron to melt the plastic that the fuse is sitting in. You would have to figure out what to use as a fast blow fuse.
Okidata makes it difficult to take out the thermistor because the nut is locktite on the screw. Try using the soldering iron to melt it. Just make sure you dont damage the thermistor.
Posted on Jul 03, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
SOURCE: OKi C5800ldn 231: fatal error 03
I have the Oki 5650 which had been great for about 18 months. Then found that the C cartridge was showing error as 'not installed'. After much fiddling about with it and checking on the internet I can now rectify this by either pushing down on the top of the printer while it boots up, or removing the small chip on the left top of the toner (make sure you have 'earthed' yourself to prevent any static damaging the chip when you handle it!) and taping securly onto the top of the cartridge above the chips proper slot. This now has been working OK for 6 months. Strange how this only affects the C cartridge (which has also been replaced and had the same problem). I suspect that the printers RFID chip reader for the C cartridge is having problems reading the chip and moving the chip closer to the reader by either taping to the cartridge top of puching on the top cover while printer boots up resolves the problem (for now anyway!) This can also trigger the 'service call 231 fatal error 03' message which also disappears if you follow the above procedure.
Hope this helps you.
Posted on Jul 27, 2010
How can I fix oki c3530 231: fatal error 03?
RFID Reader I/F Error An interface error was detected
with the RFID reader device.
01: communication error between
the RFID reader and the engine
PCB.
02: the transceiver circuit error of
the RFID reader.
03: communication error between
the RFID reader and the Tag
chip.
04: the RFID Tag detection error
Jun 21, 2014 | OKI C5800Ldn Led Printer
Error message: Service Call 980 - Fatal Error
It means a call to OKI will be necessary. Typically, fatal errors are related to internal ROM, or board components that effect the boot process of the printer. When it can't boot - you get this type of message.
Dec 31, 2010 | OKI Electric Industry B4545 Laser Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Fatal error 231 on oki c5800 after changing toner, tried power off/on still doesn't work
From the service manual, doesn't look good.
A technicain will have to look at the printer.
An interface error was detected with the RFID reader device.
01 : communication error between the RFID reader and the engine PCB.
02 : the transceiver circuit error of the RFID reader.
03 : communication error between the RFID reader and the Tag chip.
04 : the RFID Tag detection error (more than 4 chips).
If rebooting the machine does not improve the symptom, you need to
check the device.
Mar 08, 2010 | OKI C5800Ldn Led Printer
Fatal error 122 on a oki c5200 printer
YOUR DRIVER CD IS CURREPTED.ANOTHER DRIVER CD USE.
Jun 23, 2009 | OKI C5200n Laser Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Hi I have a Oki c6100dn Printer with fatal error message 173, How can I fix that
unfortunately, a 173 error is a fatal error which requires service, or technical skill on your part. It usually involves replacing the power supply board and fan.
Jan 27, 2009 | OKI C5100n Laser Printer
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
OKI C9600hdn Laser Printer Logo
104 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
SiNnA
SiNnA
Level 1 Expert
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
