Question about Century Heat Pump Hrg1336-1a - 33600 Btu Cool 32000 Btu Heat
How wiring diagram connect - Century Heat Pump Hrg1336-1a - 33600 Btu Cool 32000 Btu Heat
    Top Expert:
  • Century Master
  • 35,549 Answers
You might be able to get a diagram from Century. We can't supply one
Posted on Apr 22, 2013
Wiring details for alpine3215
Wiring connection diagram. For Alpine 3215 7-band graphic equalizer with 4-amps. have custom scanned this item for those folks that don't have a need for the full service manual and just need a simple connection diagram. Includes wiring connection diagram and pin-outs of the din as well as output block connectors.
Sep 28, 2016 | Car Audio & Video
Wiring diagram
A wiring diagram is a simple visual representation of the physical connections and physical layout of an electrical system or circuit. It shows how the electrical wires are interconnected and can also show where fixtures and components may be connected to the system. Use wiring diagrams to assist in building or manufacturing the circuit or electronic device. They are also useful for making repairs. DIY enthusiasts use wiring diagrams but they are also common in home building and auto repair. For example, a home builder will want to confirm the physical location of electrical outlets and light fixtures using a wiring diagram to avoid costly mistakes and building code violations.
http://resumeplus.us
Sep 01, 2016 | Cooktops
I need to no where the red wire from computer goes on fuse box ( had new harness installed and was told the red wire from computer goes to fuss box
Typically the red wire is a Positive voltage wire. If you were told the wire goes to the fuse box, you should get a wire diagram for the wire harness. On the diagram it should show connections marked with numbers and possibly colors. The computer on the wire diagram should show a red wire marked Vcc or Positive or something like that, trace that wire on the diagram carefully to the fuse box on the diagram, the fuse box on the diagram should be marked with a fuse rating at the location where the wire connects. As long as the fuse rating is the same and it's marked as "ECU" or something similar related to the "engine control unit", that is where you connect it. DON"T put it on any other connection with a different fuse rating, it could damage the computer as soon as you turn the key. this should give you enough info to get it connected and if not you can refer to this to explain to someone else. Good Luck.
Nov 26, 2014 | Cars & Trucks
2001 Cadillac Deville oxygen sensor wiring diagram
The wiring diagram shows the wiring color code, Power rating and connector plug used. The wiring diagram explains the vehicle's electrical connections with color code. It's a bit complicated to understand.
Apr 07, 2013 | 2001 Cadillac DeVille
I want to hook up a slim sub for my truck using this amp. how can I do that? Because this amp plays everything not just the bass
You will need to connect the low level input leads from the head unit to the amplifier (they are RCA cables). If there are no low level leads from the head unit, you will need to connect the wires from the speakers directly into the high level inputs using a wiring harness which should have been included with the amp. It should include a wiring diagram. You will need to use that diagram in conjunction with the truck's wiring diagram in order to know which wires to connect. They are color coded and once you have the vehicle wiring diagram (which can be downloaded by searching for it on google.com), it should be easy to determine which wires to connect.
Mar 04, 2011 | Audiovox AMP610 Car Audio Amplifier
I bought this generator with the 30 amp breaker missing. I have a new breaker but i am not sure which wires connect to which terminals. there are 4 wires 2 blue and 2 white and 4 terminals.
Hello, please open this link.
http://www.briggsandstratton.com/generators-pressure-washers/support/operators-manuals.aspx?NTT=030242-0
You can download either wiring diagram. Look at the diagram that shows the back of the breakers. CB1 and CB2 are the 30 amp breakers. Check to see if the wires have numbers on them. They should. If so, connect them as per the diagram. Now, if not, then follow the wires back from the 30 amp receptacle. Follow only the ones that are not connected. These are then connected one to each breaker. The other two remaining wires are then connected one to each breaker as well. I cannot tell you about the colours, but if you follow the diagram, then you should be successful.
Feb 08, 2011 | Briggs & Stratton 6200 Watt Electric Start...
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
Model MES5770AAB Serial 11517659WK The single element, 700 watts came with a wiring kit for a new connections. My range has "Old connection type 1" . the moddification kit (A-30001, Revision 4) shows...
Ten to one the elements will have to be changed also. Call or email Maytag about your dilema. You can simply reject to pay me also on this one
Jan 21, 2010 | Maytag Kitchen Ranges
Century Heat Pump Hrg1336-1a - 33600 Btu Cool 32000 Btu Heat Logo
47 people viewed this question
Top Century Pool & Spa Experts
Jay Finke
Jay Finke
rogerpaul3
Level 1 Expert
Bill Jordan
Are you a Century Pool and Spa Expert? Answer questions, earn points and help others
