Question about Compaq CQ60-211DX Notebook
Com4 says its not working properly
  • Compaq Master
  • 27,725 Answers
Could be a driver problem
Click start control panel administration tools computer management device manager scroll through all of your devices
If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
If you computer came with a motherboard disk the drivers could be on it.
Rather doing a driver hunt which can take hours
http://ct.download.com/clicks?t=1169844150-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Posted on Apr 22, 2013
Instruction manual for GFIT300 Treadmill
PLEASE GO TO HTTP://FITNESS.MANAULSONLINE.COM
2) http://www.manualsnguides.com
3) HTTP: MANAULSFACTORY.COM
4) WWW.FITNESSREPAIRPARTS.COM
5) WWW.ICONSERVICES. COM
6) HTTP://PDFSERVICEMANUAL.COM
SINCERELY. GOOD LUCK
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Nov 30, 2011 | Exercise & Fitness
RT 8212 rolodex will not connect to pc says there is a cable problem
I am running Windows XP. My Franklin Rolodex RT-8212 is connected to a USB port through a USB to serial connector I purchased separately. I was getting exactly the same problem until I downloaded and installed a driver for my connector (even though the supplier pretended it was a plug and play device). In my case I had to set my connection setting to COM4 in the Intellisync Mobile Desktop application (under the Setup + Connection menu). It is working fine now.
Regards,
Simon
Feb 18, 2011 | Franklin RT-8212 Handheld
How to activate singular
Hi 123nimin.
You may activate the Singular connection by following the below steps:
NOTE: A SIM card must be inserted to perform the unlocking procedure. The Sony provided Cingular SIM card, if activated, will still function after the Sony Ericsson EDGE Module is unlocked.
1) Click the Start button, point to All Programs, point to Accessories, point to Communications, then click Hyper Terminal.
2) In the Connection Description window, under Name, type EDGE.
3) Click the OK button.
4) In the Connect To window, next to Connect using, click the down arrow and click to select COM4.
NOTE: If COM4 (or the port that the Sony Ericsson EDGE Module uses) is not available in the list, ensure the Sony Ericsson EDGE Module is installed properly and turned on in the Smart Wi utility.
5) Click the OK button.
6) In the COM4 Properties window, ensure all the following settings are configured properly:
Bits per second = 2400
Data bits = 8
Parity = None
Stop bits = 1
7) Click the OK button.
8) In the Hyper Terminal window, type AT.
IMPORTANT: Use capital letters for all entries.
9) Press the ENTER key.
NOTE: Ensure OK is displayed on the next line after AT.
10) Type: AT+CLCK=PN,0,xxxxxxxx
NOTE: Replace xxxxxxxx with the unlocking key provided by the Sony representative.
11) Press the ENTER key.
IMPORTANT: If OK is displayed, the unlock was successful and the procedure completed.
NOTES:
a) If a +CME ERROR 3 error is displayed, reset the EDGE Module.
b) If a +CME ERROR 40 error is displayed, remove the SIM card provided by your third-party carrier and use the Cingular SIM provided with the notebook.
c) Consult the full list of +CME errors for more information on other errors that may occur.
Please perform the above steps to activate the Cingular Connection.
Hope this helps.
Please feel free to contact for further information and assistance.
Sep 06, 2010 | Sony VAIO PCG-K25 Notebook
Usb/serial adapter not working
check the com port of the appliaction, it is based on com1 only then you will need to make changes to the com4 to com1 follow these steps
open device manager
choose com4 and then right click for properties
choose port settings
choose advance
change the port number from 4 to 1
that will be all you can now give it a shot again
Jan 01, 2010 | Bernina Artista 180
Install driver and software of GSM modem
Send/Receive smses with panasonic cf-27 toughbook
these both software works..
download and configure it on com4 and 9600bps and enjoy
http://www.activexperts.com/mmserver/
http://www.smsgee.com
Regards
Tehseen
www.citinetsolutions.net
Mar 22, 2009 | Panasonic Toughbook 27 Notebook
Not receiving a gps signal
Com4, Baud 56K, Other NMEA GPS Antenna.
Jul 07, 2008 | HTC Touch P3450 Smartphone
Pentium III 800 mhz T21 Thinkpad Internet connection problems
why fight it , let it be on com 1 then,
go into the bios and disable the serial ports .
that may be the easiest fix as long as you don't need the serial port for anything.
but if you have a serial mouse oh boy.
May 13, 2008 | IBM ThinkPad T21 Notebook
Posiflex cash drawer
Ok
please type the following line as i am writing here to your commad prompt:
MODE COM1: 96, N, 8, 1
and then printer
I am sure it will work.
Thanks
Iqbal
Mar 12, 2008 | Computers & Internet
Janome customizer 2000 reader/writer
hi i have found a solution to this problem if the ladies would like to contact me i would gladly tell them what i did .
Mar 04, 2008 | Audio Players & Recorders
TOM TOM 910 no gps signal.
If TomTom is stating there's is "No GPS Device" then you don't have TomTom configured properly. You need to set TomTom to use "Other Wired GPS", select 4800 or 9600 bps and set to COM4. Once this is done it should detect the GPS and it will either show you your current position or it will say no valid GPS signal.
Use GPSTest application (search on google or on this website) to test your GPS. It will automatically scan your device, detect the GPS and give you a lock on your current position.
Nov 29, 2007 | Tomtom GO 910 GPS Receiver
Compaq CQ60-211DX Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
