Question about Dryers
Need to know how to connect power cord with four wires...
This should be a 30 amp 4 wire plug for a dryer white to center take off the ground strap from the center white post that bolts to the green ground screw u want to isolate the ground green wire goes to green ground screw, black and red goes to outside screws one left one right
Posted on Apr 22, 2013
  • 1122 Answers
SOURCE: hooking up the four prong cord to the dryer
this is the rule of thumb,white always goes on the middle terminal ,the 2 outside terminal wires it does not matter which side they are on,if you can see the red and black wire on the terminal block then match them up,the green wire gets mounted to the cabinet,you should already have a green wire to the cabinet so remove the screw and put both wires there and your done,let me know how you do-mike
Posted on Oct 15, 2008
  • 8 Answers
SOURCE: REPLACING POWER CORD
White to center, red on Right, Black on left, Green goes to case or external ground screw.
Posted on Mar 27, 2008
  • 1073 Answers
SOURCE: How to change a dryer
black to left screw on terminal block red to right screw on terminal block green and white to center screw on terminal block screw
Posted on Apr 30, 2008
Illeagle
  • 525 Answers
SOURCE: trying to connect dryer cord
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
I don't quite understand what was wired how but the wiring should be as follows:
For a 4 prong plug and matching outlet
1. Black wire on one end terminal of choice.
2. Red wire on remaining end terminal.
3. White wire only, on the center terminal
4. Green wire on the the dryer frame or chassis terminal.
For a 3 prong cord and matching outlet:
1. Black wire on one terminal end of your choice.
2. Red wire on the remaining end terminal.
3. White wire on the center terminal.
Always be certain that the wire in the breaker or fusebox match the wiring of your outlet.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 02, 2008
aborcass
  • 2651 Answers
SOURCE: have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Posted on Mar 28, 2009
I need to convert my dryer from a 4-prong to a 3-prong power cord. I understand all steps of the installation except for the grounding wire. Since there are only three cords now I no longer have a...
On your cord, the outside leads are the hot leads, with each one carrying 120 volts. On a four wiire cord, the two inside lines are neutral and grounds. For a three wire cord to be used with four lugs, the middle wire connects to one of the middle lugs, and the inner lugs should be connected together, Normally, a drier comes with a bridging plate to connect the two lugs, and it is removed for a four wire cord, or left in place for a three wire cord. You can bridge the two terminals with a piece of substantial insulated wire. I have never tried to buy a bridging plate, but you might try Lowe's, etc. for one.
Best regards,
--W/D--
Jan 21, 2011 | Dryers
Wiring for three prong power supply cord
If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
Connections
New
Picture shown is for a range cord but is exactly the same for a dryer connection.
Feb 03, 2010 | Roper REX4634KQ Electric Dryer
Model LeA80AW will not start. It is connected with a 3 prong 30 amp cord, don't know if its connected right. It looks like there is electricity running to it, but it does not start.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 26, 2009 | Dryers
I'm trying to replace the power cord on the Maytag Atlantis MDE7400AY. originally it has a three prong cord but i need to put on a four prong. in the back of the dryer it seems to only have three...
Sep 04, 2009 | Dryers
I NEED HELP CHANGING CORD TO A 4 PRONG ASAP!!THANKS
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Comments: Jul 23, 2009- bf71290.jpgfb4d3ed.jpg
Three wire Four wire.
Better? Best wishes and sorry about the pics. Hope this is better.
Aug 17, 2009 | Frigidaire GLEQ2152ES Electric Dryer
I need to change my eltric cor from a four wire to
The following link explains how to install a power cord for your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Refer to the section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, let me know. I hope this helps you.
PS The GREEN wire is ground and gets grounded to the appliance frame.
Jul 06, 2009 | Whirlpool LER4634J Electric Dryer
I don't have the manual need to know the sequence left to right of the four wires of plug wire connect
If you are talking about how to connect the power cord to the dryer. the following link explains:
This is US Standard wiring code. Just follow the wire color codes and remember NOT to ground the Neutral (WHITE) wire in a four wire configuration. If you are in another country, please let me know. If this isn't the wiring you are talking about, also let me know. I hope this helps you.
Jul 02, 2009 | Roper REX4634KQ Electric Dryer
Mar 26, 2008 | Dryers
Correctyly wiring power supply to Kenmore dryer
A three wire pigtail is connected thusly. The two outer wires go to the two outer terminals on the dryer, the center lead goes to the center of the dryer terminal block. If its a four wire pigtail, the outer leads go to the two outer terminals on the dryer, the white goes to the center terminal. The jumper strap on the center is removed and the green goes to chassis ground.
Sep 16, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Dryers Logo
136 people viewed this question
Top Dryers Experts
