Transmission & Drivetrain for Chevrolet Cavalier Logo
Anonymous Posted on Apr 22, 2013
Ok i have a 96 cavalier with bad transmission and i have a 97 transmission the 96 is a two door the 97 is a four door the plugins look the same the 96 has a dip stick and the 97 has a vent cap no dip
The 97 has a red cap on the top of it n dose not have a dipstick and the 96 has a dip stick will it fit
Tom Lawyer
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 207 Answers
  • Posted on Oct 22, 2013
Tom Lawyer
Expert
Level 2:
New Friend:
Cheetah:
Answers
207
Questions
0
Helped
30476
Points
267
If the 97 doesn't have a dipstick where would you put the stick from the 96.
2answers
Will a 97 cavaliers transisson fit in 96 cavalier
if body style is the same and motor size is the same yes
I put a 97 engine in my 96 cavalier and it will not start. it has power at the coil and injector pulse but no spark. I had to change the crank sensor from the 96 to the 97 engine because it had the 3 wire...
There are several thongs that could cause this. Have you checked the ignition module? The wore harnesses or ecu could be different. A number of sensors on the new engine could be bad or incorrect.
When driving 35 mph + the front end seems to bump it feels like going over a bump in the road i dont think its the transmission because it does not happen when shifting it happens more when driving up hill...
Could be a tire out of round, or even a bad strut. Bounce the front end, if it's spring like, the strut (s) may be bad. Look for leaking of oil from them, that is a sign of a bad strut.
5helpful
3answers
97 Nissan Pickup transmission swap for 95 or 96 transmission?
yes this will fit, model years 88-97 will fit. I would recommend the newest model you can get, as they improved internal hardware after 93. hopefully this helps
2helpful
Is it true that in a 1996 chevy tahoe 4x4 u can't convert the transmission with another year model like the rest of the1997s. The dealer told me with the 96 4x4 has to be replace with another 96. but 97...
The key distinction of the Later 4L60-E (1997-2006) from the Early 4L60-E (1992-1997) or 4L60 (1990-1992) or 700R4 (1982-1989) is the six-bolt "hex" rear output or tail housing / adapter pattern. The previous versions featured a four-bolt square bolt pattern at the adapter or tail housing. This is where that made the small change and the 96/97 year was a change over year so you may have the newer housing or the older housing, but if your replacing the transfer case with the transmission your good to go, the electronics are the same. Just the body housing is different. Good luck and hope this helps. And why wold you want to convert the transmission, there are lots of easy simple up grades with out dropping the transmission or valve body.
'97 Chevy Cavalier Z24, transmission questions...
my friend is selling a 1997 z24 chevy calvalier manual with 148,000
miles. should i buy it for 200,dollars. its looks ok and runs ok
what should i be looking out for before i buy it.?
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
