Question about Nuova Simonelli Oscar Coffee Maker, Espresso Machine
Water running trhought the group head slowed to a trickle
I cleaned off the group head, ran a cleaning cycle with Cafiza last weekend according to the insturctions but no difference. The machine is about 4 years old.
  • agw2 Mar 12, 2009
    yes. the gasket has been replaced before by my late husband, probably a couple of years ago. I will see if I have another one at home or if I need to order new ones.
    thanks
    Master:
  • 497 Answers
1.There is a rubber gasket inside the group head that can wear down with use and lack of cleaning. Try cleaning it well or replacing it.
2.There may be coffee grounds around the rim of the portafilter after tamping, which would disrupt the seal. Always make sure the rim is clean before attaching the portafilter to the group head.
3.The coffee may have been ground too fine. If the water cannot go through the coffee, it will move in other directions.
Posted on Mar 12, 2009
  • Yaz  S
    Yaz S Mar 12, 2009
    plz replace the group head gasket..it must be replace once in a year...Hope this helps
    Thanks for using Fixya
    Have a nice day!
  • Yaz  S
    Yaz S Mar 13, 2009
    Thank you very much for the rating.
    Take care
Dishwashwer not cleaning dishes at all, though it runs through a complete cycle.
try removing spray spinner and clean out holes the spray heads get blocked and stop water flow, or you may be able to remove spray nozzles and clean out , i had this several times in the past also make sure the base drain filter is clean some times the small holes in the filter get smaller and smaller reducing water flow
hope this is of some help good luck
Aug 02, 2016 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
My Bosch Nexxt 300 has E13 code, I'v cleaned the bottom drain, cleaned the outlet hose, ran 1 gallon of cold water threw on the Regular/Cotton cold water cycle, unplugged it for several minutes, t
please download the user manual from the manufactures website its normally free and look at the trouble shooting guide for help on the subject eric
Dec 19, 2017 | Bosch Nexxt 300 Series WFMC2201UC
Making very bitter espresso. I already decalcified it and ran empty tanks through, without success.
Hi. The bitterness you have got is most likely to be dirty group head and shower. Remove the shower and clean with a steel wool. The group handle and filter basket will also have to be cleaned. Sounds like your using a dark oily blend. You cant use different blends unless you clean the group head every time. Same with the grinder. You can not use different blends for grinding. The different blends just cross contaminate, which can make your coffee bitter. Incorrect grind or wrong water tempreture can also make bitter coffee. Running descale does nothing for the coffee taste. Descale only cleans the lime/calcium in the boiler. Coffee does not pass through the boiler. Give your group head and handle a clean, and you should be right. Hope this helps. Dazza
Oct 21, 2011 | Saeco VIA Venezia
The water going in on the rinse cycle is very slow
The water going in slow can be the small screen in the inlet valve of the washer could be clogged, or sometimes the hose has a inlet screen that gets clogged.
Sep 01, 2009 | Maytag Washing Machines
When i clean my machine, the release valve isn't working as it should. the pressure builds up in the head and water just trickles out of the release valve. i've had my machine for approx 1 year. Could the...
There is apossible restriction, but, whatever actuates the rrelease valve is what is actually malfuctioning.Depending on you level of detertermination, you can follow my approach to the dilemna if mass production. Since it doesn't work, find out why! Worse case scenario is the trash can, the best, A better understanding and working knowledge of the appliance. Screws usually hold these things together. Expresso machines are not inexpensive and there is a reason for those big bucks. No glue! So always taking the electrical part into consideration, there is no reason you cannot disassemble the unit and entertain yourself while at the same time learn something. Always take the approach that someone assembled it and you can disassemble it. If it does have glue, rhen it was anever intended to be serviced or repaired by anyone. So give it a shot and if you run into a problem, Give me a holler and we will keep moving. My ph. # is 909-630-3192. You may have to send me a picture or two of our project, So have a camera ready.... Ned
Jun 28, 2009 | Pasquini Livia 90 Espresso Machine
Kenmore 90 Series fills so slow on rinse cycle
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside where you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 09, 2009 | Kenmore 15944 Top Load Washer
Not making espreso all the time
Being that you just started using it I would not be concerned. You did the correct thing by cleaning the brew group. Check on your screen under total coffees. We usually recommend you change the brew group every 10,000 cups.
Make sure you descale the machine and you can try using the cafiza tablets to clean your brew groups internal passages.
Brew Group: http://cerinicoffee.com/Saeco_brew_group_Magic_royal_916006715.asp
Cleaning instructions: http://cerinicoffee.com/clean_descale_coffee_equipment_instructions.asp
Nov 19, 2007 | Saeco Royal Exclusive 30153 Espresso...
Steam blowing out of group head
Were you using cleancaf to descale? If so, it is not a strong enough descaler. Use Dezcal. or a Dezcal cleancaf mixture. The two work great together.
Make sure you get some descaler in the solenoid area by turning on and off the coffee button.
Hope it works out for you.
Espresso Parts and Cleaning Supplies
www.CeriniCoffee.com
Nov 12, 2007 | Rancilio Silvia Espresso Machine
Open Questions:
Nuova Simonelli Oscar Coffee Maker, Espresso Machine Logo
162 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
