Ignition lockout on carrier furnace. How to get furnace running again
    New Friend:
  • 8 Answers
It locks out because their is a problem with the flame ignition after it tries to light several times it locks out. Could be a flame sensor or bad igniter. Could be other reasons but these are the most likely. You can reset it by turning the power of and back on again
Posted on May 14, 2013
  • 1 more comment
  • Anonymous Oct 28, 2013
    Hmm I've been having problems with my furnace in Edmonton maybe that's it. Thanks for this.
  • Greg Perryman Nov 23, 2014
    You can remove the sensor out and clean it up with a piece of emmory cloth or sand paper. Now if the flame is not crossing over well ( from ignition point over to the sensor point) then the burners need to be cleaned. Unless you are very confident in doing this, you should call a professional
  • Greg Perryman Nov 24, 2014
    You have to turn the power off then back on to reset it!
    New Friend:
  • 101 Answers
Sounds like the flame sensor may not sending a signal back to the controller. clean the sensor with a non abrasive like scotch bright.
Posted on Jan 21, 2015
  • Victor Scarpita
    Victor Scarpita Jan 21, 2015
    CHECK ON THAT STICKER WHAT CODE 41 IS?
    New Friend:
    Problem Solver:
  • 8 Answers
If it lights and then goes off before the blower comes on, it could be just a dirty flame sensor. All you do is see which side the ignition is and find a wire going to the opposite side, pull the sensor out and cleanness it wit some sand paper, reinstall and try it out, if it still doesn't work call an HVAC dealer in your area. I hope this helps G. P.
Posted on Jan 03, 2015
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
What is "Ignition Lockout Fault?"
I wonder why your question ended up in the wrong category.
Now that we know that it is a propane heater and not a TV I still don't know the brand name or model. I think you said 5th. wheel.
Most rv furnaces are are very similar. This is a link to trouble shooting a RV furnace.
http://www.rvforum.net/miscfiles/Furnace_Trouble-2.pdf
Atwood 8531 Service Manual
http://bryantrv.com/docs2/docs/hflamefurn04.pdf
Sep 24, 2014 | Televison & Video
Furnace fault codes ignition lockout fault.. and this means what?
This means the furnace will not operate. Remove the power and then on again to clear it.
Sep 30, 2013 | Dometic 3312024.015 Duo Therm Comfort...
I have a Carrier model # 58MXA080-F-15112. I think my furnace is 30 plus years old. it isn't heating properly. The blower turns on and sometimes the flames come on, but sometimes they don't. As...
A 13 code means the furnace cycled on limit more than three times consecutively and is in a lockout for 3 hours. A 14 is ignition lockout. An ignitor does not intermittently quit working. I'm the service mgr at our shop, and I know that particular furnace model has a service bulletin out on bad secondary heat exchangers. If your lucky the filter is dirty, or the furnace condensate trap or drain is clogged. Most likely the secondary heat exchanger is plugged up and isn't allowing the pressure switch to make. Or the furnace is overheating due to it not being able to properly vent hot gas. Which would explain the high limit lockouts. Call an authorized carrier dealer so you can take advantage of the free heat exchangers and the $300 labor credit. You can also call an authorized Bryant dealer to perform the work for you. Only an authorized dealer can rectify this problem because the Bryant corp requires testing and paperwork in order to get your free parts and labor credit.
Good luck.
Dec 23, 2012 | Heating & Cooling
Furnace gas valve is not opening
YOUR FURNACE IS IN LOCKOUT MODE DUE TO A SAFETY FEATURE OF UNIT. USUALLY THE HIGH LIMIT HAS BEEN TRIPPED, OR YOU PRESSURE SWITCH FROM DRAFT INDUCER MOTOR FAULTY OR PLUGGED. IT WILL CONTINUE LOCKOUT MODE UNTIL THIS IS FIXED.
Dec 23, 2012 | Carrier Weathermaker 8000 Gas Furnace 125k...
Carrier Furnace keeps going through ignition switchs, could it be
This is actually the wrong place foe this however there is an overload on the circuit which may be caused by a faulty ground on the circuit.
Apr 29, 2009 | 1997 GMC Jimmy
Gas valve lockout
It means that the furnace isn't igniting and for safety the control board is preventing the gas valve from opening. Turn off the power to the furnace for a few seconds then observe what the furnace does in heat mode. Some furnaces will run the blower for a minute after you power it back up. After that see if the furnace tries to come on. If you are still getting the code then one of you high temp limit or roll out switches has tripped. Now is the time for a service tech. Make sure that you check you filter and air flow too. Low air flow means the furnace may be over heating.
The other thing is the hot surface igniter. Look closely at it with the power off. Do you see a white spot on the element or a crack. If so the HSI is bad. It's an easy replacement but DO NOT touch the carbon element with your fingers and be very careful handling it as it is EXTREMELY fragile.
Mar 17, 2009 | Carrier 38BRC048 Air Conditioner
Carrier Weathermaker SXI Model 58SX8100LG Code 12
Code 12 I believe is power up after power off and a call for heat from the the thermostat. If you have a weak door switch that may be vibrating and going on and off it would cause this as would any thing that causes the power to drop low or out then reapply its self. try holding the door switch in while watching the board and after 2 or 3 minutes the furnace should go on to lite and the blower cycle off. If it stays in this mode try turning the thermostat off (heat - OFF -cool) and then push in the door switch nothing should happen except the lite on the board come on and stay on. If it does this than have someone turn the thermostat to heat and see if it starts or put the door on and set the heat and see if *** goes through the normal cycle of heating. If however it goes right back into the blower mode and shows the 12 code your problem is still with you. So next remove the wire on the "W" terminal on the board. Retry power to the door switch and now nothing should be on except the red lite. If it tries to start the 12 code and blower up again Im pretty sure you have a bad ignition/blower control board.
Mar 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace trouble
How long unit runs after reset .If limit tripped blower motor will still run and if that's the case you might have a bad heat exchanger
May 25, 2017 | Heating & Cooling
Heating & Cooling Logo
1,601 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
