Question about Whirlpool Refrigerators
I have a Whirlpool Gold side by side bottom Freezer gi7fvcxwqoo. The refrigerator side is not Cooling very will. The freezer seems to be ok! Does anyone know what's wrong?
The temperature of the freezer is 7 degrees. The temperature of the refrigerators side is 58 degrees. The refrigerator also sits outside in my patio.
Whirlpool refrigerator gi7fvcxwydo isn't cool. The ice maker is in the for if area and has condensation. Water leaks from ice dispenser Temp on freezer is 0 and frig is at 34. Bottom freezer is worker and milk is barely cold. Help!
Posted on Jul 02, 2013
Testimonial: "Thanx too all who has responded to my Whirlpool Gold Side by Side problem. I check the Defrost Heater and the Air Damper it was fine. The problem was the fan motor in the ice maker that had a short. It would run occasionally, that's what threw me the curve ball. So I replaced it and all is well with the Refrigerator. Thanx Again!!!!"
  • 1 more comment
  • Rebecca stalcup Jul 02, 2013
    There is no frost on the back of the freezer.
    When checking them board....on defrost mode. Do I need to change from adaptive defrost to 8 hr basic ?
  • Whirlpool Master
  • 4,655 Answers
Either the refrigerator is too cold to run properly in the location of your patio, defrost failure. or air damper is not opening and closing properly. First I would like you to enter the control panel into diagnostic mode=> GI7FVCXWA GI7FVCXWB GI7FVCXWQ Diagnostic Test I am going to be here to assist you in locating the problem but because your model has so many electronic features I am asking you to do the diagnostic test first to help pinpoint any problem your refrigerator may have that can be located while in diagnostics. You may get the complete repair manual by contacting me HERE
The temperature of the freezer should be colder and around 0 degrees F. What is happening here appears to be a defrost problem. 12729123 Defrost Heater
another source here=> 12729123 Defrost Heater
I am here so please let me know if you have questions Thanks Sea Breeze
Posted on Apr 23, 2013
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
mikedurland
  • 481 Answers
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
  • 236 Answers
SOURCE: Whirlpool Gold GD5RHAXNQ00 refrigerator not cooling properly.
It takes time for the temp to adjust(up to 24hrs) If the door is open a lot(looking into the box) or the door gasket is bad this will contribute to your problem. Are you sure the thermometer is good that you are checking the machine with. The thermistor could be bad as well(the control that senses the actual temp
Posted on Nov 03, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE PROFILE REFRIGERATOR SIDE BY SIDE IS NOT COOLING
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Nov 17, 2009
Whirlpool gold refrigerator is not cooling ice build up in freezer. Water on bottom of refrigerator.
Too much build of ice in freezer will not cooled the refrigerator side, you need to defrost the fridge. Set it to proper temp setting, just enough to have ice on the freezer and also remove water on the bottom.
Thanks for asking.
Jun 24, 2011 | Whirlpool Refrigerators
The Whirlpool Gold refrigerator is not cooling and the bottom freezer has ice formed on the back of the freezer. I purchased the refrigerator in February 2009.
If you can hear the fan running in the freezer you have a defrost issue. Depending on the Model number it can be a timer, adaptive defrost board, a bi-metal themostat, or heater.
May 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Whirlpool gold conquest, freezer working fine, fridge warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 05, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Refridgerator side stop working on whirlpool gold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer working ok but refrigertor not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 06, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold GD25DF FRIDGE NOT COOLING FREEZER WORKING FINE
Clean out the coils at the very bottom of the refrigerator from all of that lint/dust buildup it makes your system inefficient
Aug 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side freezer not freezing but fridge is running
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Oct 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
  • possible causes:
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
226 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
