Question about Yard Machines Garden
Riding lawn tractor will not stay in gear /mtd
Model #13am772g755
    Guru:
  • 145 Answers
Outdoor Power Equipment Parts Use the Part Finder Tool from MTD Inside the transaxle is a detent ball and spring, NOT suggesting that you go looking for it! MAJOR REPAIR
Posted on Apr 13, 2014
  • 40 Answers
SOURCE: broken starter cord MTD Model 125-478R062
try this link.
http://www.smallenginesuppliers.com/shop/html/broken_starter_rope.html
you will want use size #4 or 4.5 starter rope. about 7 foot in length.
Posted on Mar 18, 2009
  • 630 Answers
SOURCE: RIDING LAWN MOWER STUCK IN GEAR
Have someone to rock you while you attempt to move gear shift. Hopefully it is only stuck between gears and will disengage. Your grease in gearbox may have become hard causing problems. If you wash the gearbox with water when hot (after mowing) You may have created moisture in gearbox causing major damage to transmission.
Posted on Mar 28, 2009
SOURCE: Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Posted on Jun 01, 2009
  • 376 Answers
SOURCE: MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Posted on Jun 28, 2009
moretons
  • 155 Answers
SOURCE: need wiring diagram
Hi try the mtd website
Posted on Jul 25, 2009
What kind of manuals can you give me for a statesman 21hp MTD tractor
go to MTD . COM and they'll give you everything... use the 14A number... the engine you'll have to go to that manufactures web site
Sep 09, 2014 | Garden
MTD Lawn Tractor Model 13AM672G120 Steering gear broke, how to fix
Jun 03, 2012 | Mtd Garden
Charging system for MTD YARD MACHINE riding mower
under the flywheel is a magnetto system the stator this is what charges the battery
Jan 19, 2012 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Got an MTD lawn tractor model # 137-752-300 need a left deck shaft, or the part # for a deck shaft that would fit that model
Sears has diagrams parts and pricing for alot of MTD products
I could not however find the model you listed.
Double check the model and then go here :
http://www.searspartsdirect.com/partsdirect/brands/Mtd-Parts
Jun 01, 2011 | Mtd Garden
I need a manual for a 1998 or 1999 gardenway lawn tractor by MTD troybuilt Model #13AI617H118 Serial #1A082H10211 can you help? It's a 21H tractor 46SDIt's up above
Most of the MTD product manuals are available here: http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001 . Just fill in the model and serial numbers.
I found two separate manuals listed: lawn tractor owner's guide and the engine operator's manual. I found the manuals only opened in IE (Windows OS) after clicking the I Accept button. The direct links are: http://manuals.mtdproducts.com/mtd/Safety.do?pid=152292&model_num=13AI617H118&serial_num=1A082H10211&filename=770-10317b.pdf and http://manuals.mtdproducts.com/mtd/Safety.do?pid=152290&model_num=13AI617H118&serial_num=1A082H10211&filename=274794.pdf .
I hope this helps.
May 14, 2011 | Mtd Garden
I have a MTD 13AM662F765 Lawn Tractor It will not move in 1st or second gear and very slowly in 3rd is there an adjustnment for brake clutch pedal
yes their is but the models vary so you will have to have a good look ,normally its on the bottom of the pedal under the floor so to speak ,but models can vary it its on the gearbox end
Mar 19, 2010 | Mtd Garden
Mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Aug 23, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
88 mtd mower wont go past third gear
Without knowing the model, or type of transmission, I can only suggest checking your owners manual.
You can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Apr 16, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
208 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
