Question about LG Flatron Computers & Internet
Lg 21 flat screen computer monitor double vision problem
iqbal_del
  • 655 Answers
SOURCE: New 19" flat screen monitor only shows analog on the screen
finwiz,
When you on your computer, does any thing appear on the screen, some text display/logo etc.?
If yes then:
  • After making power on your computer start pressing F8 till boot option menu appears.
  • Then select safe mode and if it works, then goto device manager and re-install driver for your display.
If no then:
  • Check out the connection from monitor to computer and try. If still no luck then post comment whats you did and what was the result.
Thanks
Iqbal
Posted on May 12, 2008
  • 47 Answers
SOURCE: Black Flat Screen, sometimes works for a second
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's most likely the problem. You can confirm that it's actually the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old your monitor is, and how much you've invested into it, you may find it better to just replace it with a gently used one from ebay.
Posted on Jun 18, 2009
  • 152 Answers
SOURCE: I have a soyo computer monitor, flat, 19
packldr, If your certain that the monitor is not going into sleep mode, you will need to find out where the possible bad solder joint might be. This type of symptom could be a "intermittant thermal fracture" of a solder joint on an internal printed circuit board inside your monitor. Your monitor works fine until the internal temperature rises enough to cause "thermal expansion" to cause a OPEN connection on some critical component on a "switch-mode-power-supply" or "cold-cathode-fluorescent-tube" power supply circuit. (INVERTER ckt) If you visit youtube, check for videos that deal with "LCD monitor repair" and "bad capacitors", "LCD disassembly" just so you know what you are dealing with. Please let me know if this was helpful to you. I'm louie12fix on fixya or lmistyrel@aol.com Bye for now.
Posted on Oct 01, 2009
  • 61 Answers
SOURCE: monitor is fuzzy. A bit like double vision
Try moving cables around, may be too close to, another, power source. Plugs may be loose tighten.
Posted on Apr 30, 2010
Slasher_X
  • 767 Answers
SOURCE: hi, my computer monitor is a lg flat screen 22
See my tip here: http://www.fixya.com/support/r6820093-hard_drive_or_monitor_randomly_switching
Posted on Apr 18, 2011
Hi I have a problem with my Toshiba regza 52Z3030D, on start up the screen has double vision and lines that go from right to left
It sounds like you have a classic either horizontal and/or vertical drive problem. This is definitely a "take it to the shop" problem. Nowadays it can be either a hardware or a software problem. If you're using it as a computer monitor it could be a faulty video card or corrupted driver.
Sep 12, 2011 | Toshiba Televison & Video
I double clicked an icon and the screen went black.now on srart up the screen goes blank after power saving mode
Try it on another PC first, if it still does not work then you will need to open it up, most failures are in the power supply section due to bad caps (leaking/bulging tops)
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Monitor is fuzzy. A bit like double vision
Apr 30, 2010 | Acer AL1716 F Monitor
Have a lg l1510s monitor and the power green ligt
Have you tried to substitute a different cable? Many times a cable can go bad, and you cannot tell, because of how they are made. Get a different cable to try as a replacement, and see if that doesn't resolve this issue.
-a.
Jul 02, 2009 | LG Flatron L1510S 15" LCD Monitor
Jun 04, 2009 | Computers & Internet
The task bar along the bottom of the screen, I can't see it
Adjust controls on the monitor. There a double box that lays on top of the other. Adjust that option... You may also want to adjust the setting that shows a box with arrows pointing up and down. adjust it as well.. Experiment on the settings. You'll get it right.
Mar 14, 2009 | Hitachi SuperScan Elite 802 21" CRT...
I can't get any sound from the monitor
Need to plug an audio cable from the Vision Monitor (Audio IN port) to the Lenovo 3000 (Audio OUT port)
Jan 11, 2009 | TDV Vison vi06fv19x Monitor
Repair of Sony 21'' flat screen television set
problem lies in the power supply check opto coupler or check horizontal output transistor and lot
Nov 22, 2007 | Sony 21" Trinitron P202 Flat Screen...
Computers & Internet Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
