Question about Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model
Mower will run then starts running bad turn the choke off and it stalls stalls after i choke it also blows gas out of the top of the carburator how do i adjust the vaalvesType your problem for a solut
How do i adjust the valves?
    Habit-Forming:
    Scholar:
  • 54 Answers
Using the choke as you did,mentioned in your problem,you have flooded the carburetor. DO NOT USE THE CHOKE,ONCE THE TRACTOR IS RUNNING. Choke is used to start the motor only. When you run with the choke on,the motor gets to much gas and the plug(s) get fowled up and gas comes out of the carburetor. Remember the motor is hot,when gas comes out of the carburetor,the amount of over flow (flooding),could cause a FIRE. Lay off the choke,clean the spark plug(s),they will most likely be fowled up. The filter will be soaked with gas,remove the filter,soak up the gas,using a handy wipe,let filter dry out. Once dry replace filter. You should be good to go. Remember,do not over choke,use when starting a cold motor,usually when motor is hot from running,you may not have to use the choke at all. Hope this helps. Sincerely,Brad Locke
Posted on Nov 21, 2015
jrw4u
  • 62 Answers
SOURCE: Craftsman Riding mower won't stay running
Well this could be a couple of things first thing first is check the air filter and make sure its clean you can blow it with air or pore gas over it and clean it make sure you let it dry before reinserting
second im assuming this is the first time you have used it this year if so the gas you have in it hasnt been sitting in it all year has it like anything else gas gets old
third alot of times you can let it run for a while with the choke out then slowly pushing it in
fourth you could have water in the gas remove the tank and empty it remove the spark plug turn the engine 4 or 5 times only bumping it dont hold it down this will blow some of the water out then dry the spark plug off and replace it
if this doesnt help it could possibly be carburetor problems
Posted on Apr 29, 2009
Healeyman
  • 1198 Answers
SOURCE: mower starts runs begins to back fire and run
Sounds like it is leaning out, running out of fuel. That can be the strainer at the gas tank, any fuel filters it has. Disconnect the fuel line from the carb and see how good the flow is to it, and check for water. A new spark plug never hurts.
  • 153 Answers
SOURCE: air filter fills up with gas and stalls the mower.
bad fuel pump. Rebuild carborator.
Posted on Apr 30, 2009
da420bmx
  • 4 Answers
SOURCE: MOWER RUN WITH CHOKE HALF OPEN BUT PUSH THE CHOKE
Check to air screws on the carb.
Posted on May 19, 2009
wikkidd420
  • 96 Answers
SOURCE: mower tries to stall after running stronge for sometime.
I had the same exact problem with mine :) I adjusted the valves and cleaned the fuel bowl on the bottom of the carberator, and it helped for a while, but started again a monh later. Recently, I took the head off and found a large amount of carbon deposit in the head and on the piston. I believe the new 10% ethanol fuels don't burn as cleanly as before. You may try to run a higher octane fuel or a small amount of fuel system cleaner through the engine to try to remove these deposits. Let me know if this helps :)
Posted on May 23, 2009
Engine will run only with choke on
you need to take apart the carb and clean the jets inside
Jun 07, 2012 | Garden
Tecumseh TVT691 not getting spark in one cylinder
Did you check for spark of assume that since the spark plug was not dirty that it is not firing. I am leaning toward water in the gas since you have to keep the choke on and it is blowing white smoke. You may want to drain the fuel tank and carburator and put in fresh gas. Good luck!
Dec 30, 2011 | Garden
I have a murray push mower 6-22271 briggs straton 4 hp. it start and then stalls . filter clean. choke fully closed when control is in full forwrd run/choke position. I pour gas in the throat and pull...
Your carburetor needs cleaned. It is dirty/has debris in it. If it has a bowl that is. If it has a diaphram (carburetor mounted on the fuel tank), replace the diaphram. They go bad.
I hope this helps get you going.
Jul 28, 2011 | Garden
Yard machine mtd 123cc mower stalls after starting it runs for a few seconds and then stalls. Previous to this it only ran on choke but when you took the chock off it stalled also. Now it stalls even when...
dirty gas. the fuel bowl likely has junk in it which plugs the jets as soon as it starts. you may get luck just emptying the carb bowl but a good carb clean and new gas will do the trick. (dump out the old gas
Aug 16, 2009 | Mtd 22" Yard Machine Push Mower
2004 Honda Shadow Aero stalls
sounds like bad fuel try adding some fuel stabilizer.
Jul 19, 2009 | 2004 Honda VT 750 Shadow Aero
Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Jul 05, 2009 | Garden
Greetings, my nmae is Tim and I need some troubleshooting assistance with my Huskee GT (26 hp Briggs and Stratton ELS OHV eigine). The problem first became noticable about a month ago. When the mower had...
Check for an air leak around the intake and carburator mounting area. Also don't forget to check your fuel cap to make sure that it is vented properly. A cap that is not vented properly will not allow fuel to flow between the fuel tank and the carburator. These are a couple of areas that I would look at first. Hope this helps and good luck.
Jun 24, 2009 | Garden
Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model Logo
78 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
