My topfield trf2100 starts recording programs but they disapear when the timer is finished are they hiding some where or are they lost?
Also if stop recording early they disapear. this does not happen all the time with both situations but very annoying. No usb recording straight to hdd
Palmbeach
  • 185 Answers
SOURCE: DMR-55E dvd recorder timer fault
This is a common problem with this particular model. I can tell you what the fault is but unless you feel confident in using a soldering iron, the repair is best left to someone who is.
Ok...the fault you describe is caused by failure of IC001. This is a voltage regulator on the power board. You can identify the regulator as it is fixed to along thin metal strip near the middle of the board. It gets very hot during normal operation and will fail after a couple of years. The metal strip offers very little heat dissipation so the regulator operate in excess of its limits and therefore fails.
You need to take the lid off, remove the board which is mounted on the right hand side of the unit and replace the faulty regulator.
To remove the board, remove the fixing screw above the power connector on the back of the recorder, then the 4 fixing screws that secure the board. Next carefully remove the multi-connector that connects the board to other circuitry and lift the board clear.
A new regulator type STRG 6353 and can be obtained from several online suppliers. The old regulator can be removed by unscrewing the fixing screw, cuttiing the 5 pins with wire cutters. Then using a soldering iron, carefully removing the residual pins from the printed board making sure the print is not damaged.
Use some heatsink compound on the back of the new component, this will help it to dissipate heat more easily, use an additional heatsink if you can, which will help to prolong the life of the new regulator, then tightly secure it in position before carefully soldering the 5 pins.
Check that you have soldered it correctly without any shorted pins or tracks and reassemble the unit. I have repaired dozens of these successfully with exactly this fault.
Mains voltages can be lethal so always remove the power plug before doing any work like this and be sure of your own ability. If you're not confident in tackiling this, get someone to do it. Whatever you do, don't ditch the unit for such an easy to fix fault!
From your user name, I guess you're a radio amateur, so you should be on home territory.........
Posted on Feb 14, 2008
  • 476 Answers
SOURCE: Philips DVDR3450H Recorder does not record all of timed programs
When setting the record timer make sure that PDC / VPS is switched OFF.
PDC - Programme Delivery Control / VPS - Video Programming System is designed to allow for late starting or running programmes. Not all channels support PDC/VPS, so the recorder may be waiting for a PDC/VPS signal which isn't there.
Posted on Feb 16, 2008
SOURCE: Hi, Have just purchased Samsung DVD
I had the same issue. It turns out that the recorder has to be switched off otherwise it won't record. The unit will power itself on at the scheduled time and record your program. It doesn't make any sense to me why this would be a requirement but it solved the problem for me.
Posted on Jul 25, 2008
SOURCE: LG RH7823W - Timer recorded audio out of sync
Try this site reportedly the fix is here
http://mybroadband.co.za/vb/showthread.php?t=24182&page=6
Posted on Aug 05, 2008
SOURCE: Timer recorder n/w
the recorder must be off, otherwise timed recording doesn't work
Posted on Sep 20, 2008
Just bought Topfield TRF2100, screen on and says"installation", but remote won't work.
Be sure there are fresh batteries in the remote. Be sure they are installed correctly and that there is nothing covering the remote's battery contacts. Look to see if there is a film covering the remote's infrared lens or the receiving unit's eye. Check your manual to see if you need to program the remote to the unit. if it's a multi-unit remote, be sure that you have set it to control the specific unit you're working with.
Jul 17, 2015 | Televison & Video
My topfield wont go past main recording on the screen. How do i reset it
Since you haven't provided the model number i can't help much goto the homepage and start there. It's well documented and has the manuals for their products.
topfield com au
Feb 01, 2015 | Televison & Video
Topfield problems
when I try to install I get to the search part and it always freezes at 66%, has anyone else had this problem and what did they do to fix it ???
Jan 18, 2014 | Televison & Video
L.S.My Pioneer DVR-550H does not record when programmed with the timer. After setting a timerprogram one can see the small red clock in the display but that disapears after some time and so the DVR does...
Make sure you have the right date and time set. You cannot set a timer program until you have the correct time and date set. Let me know if that helps.
Feb 20, 2011 | Pioneer DVR-550HS HDD Recorder
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Doesn't stop recording
Make sure there is no time overlap on any of the programs you have on the recorder.
That is the most likely problem
Aug 19, 2009 | DISH Network DVR-625 DTV Receiver /...
Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Nov 26, 2008 | Panasonic PV-7451 VHS VCR
Jan 17, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
