My maytag washer 3000 will not light up or the power will not come on
  • Washing Mach... Master
  • 17,129 Answers
Possible that you have a faulty power supply or one which is damaged and needs a full replacement. The best is to open the front control panel and get access to the board, check the fuses, the voltage to the board which will indicate if the board had failed.
Posted on May 02, 2013
I have a Maytag 3000 front loader. It looks the wash is done but I cannot open the door
Unplug the power. Wait 2 minutes, then reconnect the power. You should be able to open the door.
Alternatively, you can UNPLUG the washer and remove the bottom front service panel. Carefully reach up along the inside of that front panel and pull down on the manual release tab that is on the bottom of the door latch assembly. You should then be able to open the washer door. If this doesn't work, you will need to call Maytag for assistance.
Apr 19, 2017 | Maytag Washing Machines
Maytag 3000 series washer F21
Just cleaned out the drain inside the Maytag 3000 and boy if that don't fix it nothing will. I think something was growing in there. Seems to be working fine now. Thanks for the help
Feb 03, 2013 | Maytag EPIC MFW9700S Front Load Washer
My maytag 3000 washer keeps coding F-25
F25
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Nov 11, 2012 | Maytag Washing Machines
Maytag quiet series 3000 lights do not light up. Unit has power and door switch is working correctly
maytag 3000 washer will not lite up or power on outlet was checked it works.
Aug 07, 2012 | Maytag Dishwashers
Maytag front load washer, MHW 3000 series, f22 error message
This is a problem with the door not locking shut. Maytag have an ecellent technical assistance page on this problem with diagrams and stuff. Go to:
http://maytag.custhelp.com/app/answers/detail/a_id/2889/~/display-shows-f22-or-fdl---front-load-washer
and take a look
Jun 30, 2011 | Maytag Washing Machines
Just bought a Maytag 3000 washer and dryer and
Most likely the metal is aluminum or stainless and you should worry about rust unless you wash your clothes with salt-water (seawater. not gonna happen.)
If you're really concerned, I'd attempt to reach a maytag customer service person.
800-462-9824
To reach a real person press 0 at every option. Should take three times.
May 11, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
