Question about Gateway GT4016 Desktop PC
CANNOT ACCESS INTEL PENTIUM 4
Worked normally last night but error screen states that a problem with he hard drive has been detected. on reboot, processor starts , fails, and gives error message
    President:
  • 2,692 Answers
The hard drive is going bad. Replace it.
Posted on Mar 12, 2009
Intel hdd hard error
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 19, 2013 | Dell Latitude D610 Laptop Computer -...
Hi, The situation is My system INTEL PENTIUM
Do you have any extra things plugged into the usb ports? (external hard drive,Ipod,Flash drive) anything like that can sometimes cause pc's to hang at boot they will try to boot to that device instead of your hard drive
Mar 07, 2011 | Dell Inspiron Desktop / Intel Pentium...
I was working on my Dell Latitude D610 last night and this morning; I left it running while I went out for a few errands. When I came back, everything had shut down and I am now getting this error message...
Do you know how to bring up the bios ? (try pressing del or f10, f12, f2 while the dell logo is showing at startup) usually one of these will open the bios. Now look for your "primary master" click on it and then click on populate when the option becomes available.
As long as the bios can "see" your hard drive it is still good.
from here you have 2 options.
the first is to pull out the hard drive and put it into a usb enclosure and reinstall your OS and software onto a new hard drive, while retaining access to your files and such on the external drive.
the second is to use the recovery tools on the OS install disk to try and repair the MBR (master boot record).
Oct 10, 2010 | Dell Latitude D610 Laptop Computer -...
Troubleshoot D530 Pentium 4, i get the boot screen, over n over
Run hard drive tests, if HD tests good, and no data to keep, restore os from restore partition with f10. If data needs kept, run a repair installation of os. Run fixboot and fixmbr commands from prompt. Also try sfc/scannow from command prompt.
Nov 21, 2009 | HP Compaq d530 CMT Intel Desktop PC -...
I own a Hi-Grade Via 14'' (VE8569)Notebook and until last night haven't had any problems with it - but for some reason when I turning it on, I am getting a black screen with the following message: Intel...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty.
First - re-seat the hard disk and reboot the computer. if this does not work then reboot and go to the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Next - to determine if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external hard drive and you cannot open the various folders and files, this confirm the hard drive is faulty.
The hard drive needs to be replaces in the laptop and Windows installed and the laptop's device drivers and your programs etc to get a working laptop again.
Oct 29, 2009 | Computers & Internet
I turned on my external f drive this morning, after it worked fine last night. Now shows as local disk F. I cannot access it as it says F drive is not acessible error performing in page operation. I have...
The inpage operation error actually refers to an error going between the drive and your RAM. Try the drive on a different computer, if it works the problem may be in your RAM, if it doesn't the drive is corrupted and can't be read under normal circumstances.
If it does work, let me know and I'll link you to a memory diagnostic program to test your RAM. If it doesn't work on the other computer, let me know your Country, State and City and I can refer you to a nearby Data Recovery team.
Chris
Aug 06, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
My EVO 510 has been operating fine until last night when I entered my password resume from screen saver, the machine did not return to the desktop and just hung with a blank screen. I powered off teh...
Click Start>Run and type msconfig. Select the startup tab and deselect everything. Reboot your computer and attempt to log into Windows. If you are successful you will need to access msconfig and re-enable programs systematically until you find the culpret.
Best Regards.
Jul 15, 2009 | HP Compaq EVO D510 Intel Desktop PC -...
Boot failure
Check the connectors running to your hard disk to make sure they are firmly connected. Also check the data cable to the motherboard. Reboot the computer and enter BIOS. Check that your hard drive is being detected properly. If it is not, the drive is shot and needs to be replaced.
May 29, 2009 | Intel Pentium III , 900 MHz Processor
Cmos value not saving
Change CMOS battery
Jan 01, 2008 | Intel Motherboard
Gateway GT4016 Desktop PC Logo
44 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
