Tan 35 degree * sec 55 degree * cos 35 degree
SOURCE: SIN COS TAN
The answer that you have received in actuality is correct. However, it is in exact form when the answer that you were looking for was an approximation (decimal form) answer. To achieve this all you have to do is hit the alpha button (the yellow button with a diamond in the center) and then enter which will give you your desired answer :-)
Posted on Jan 15, 2008
SOURCE: Tan Cos and Sin errors
go to:
mode
select DEGREE rather than RADIAN three lines down.
Posted on Jan 21, 2009
  • 8049 Answers
SOURCE: Degree and radian function Casio fx-9750GA Plus
Press MENU, then select RUN and press EXE.
Press SHIFT MENU to access the SetUp.
Move cursor to highlight Angle.
In the botton of screen you see the Deg TAB. Activate it by pressing F1.
Here is a screen capture.
Posted on May 06, 2010
Testimonial: "Omg thank you sooooooooo much !!!!!! =) Now I can do my homework =) "
SOURCE: I have a Sharp EL-531W.All keys work except for sin cos tan hyp.
No solution, but I have the exact same problem with a Sharp EL-531W calculator. Doesn't matter whether mode is degrees, radians, etc., and resetting with button in back has no effect.
Posted on Aug 19, 2010
  • 102366 Answers
SOURCE: My new calculator is giving incorrect answers to
Your calculator is set to radians, which is the norm for higher mathematics. To set it to degrees, press MODE to bring up the mode editor, press down-arrow twice to get the the angular mode, press right-arrow to highlight "DEGREE," and press ENTER. Press 2ND [QUIT] to exit the mode editor.
Posted on Sep 15, 2010
X=ln(seca+tana) find coshx
Sorry I do not like to work with secant and cosecant.
sec(a)+tan(a)=(1+sin(a))/cos(a)
ln(sec(a)+tan(a))= ln( (1+sin(a))/cos(a))=X
2*cosh(X)= e^(X)+e^(-X)
e^(X)=(1+sin(a))/cos(a)
e^(-X)= cos(a)/(1+sin(a))
2cosh(X)=(1+sin(a))/cos(a) +cos(a)/(1+sin(a))= 2/cos(a)
cosh(X)=1/cos(a)=sec(a)
Now that you see how you can do it, I trust you will discover any mistake I might have made.
If you want to use the classPad function sequence Action>Transformation>simplify(, do it step by step as I have detailed above.
Good Luck.
Dec 07, 2013 | Casio ClassPad 300 Calculator
Use the identity tan(x/2)=sinx/1+cosx to solve for the value of tan45 degrees
tan(x/2)=sin(x)/(1+cos(x))
Setting x/2=45, means that x=90 (degrees)
But cos(90)=0 and sin(90)=1. Thus tan(45)=1/(1+0)=1.
Mar 13, 2013 | SoftMath Algebrator - Algebra Homework...
How do you calculate sec174?
SEC, CSC & COT are the INVERSE of COS, SIN & TAN and are usually require hitting the "2nd F" or "Func" key of the calc to make:
SIN button work as COSEC,
COS button work as SEC
TAN button work as COT
Formulas are below:
sec x = 1
cos x
cosec x = 1
sin x
cot x = 1 = cos x
tan x sin x
Feb 05, 2013 | Sharp EL531 Scientific Calculator
How to use calculator on how to evaluate trigonometric functions
The FX-115ES is somewhat different to other calculators you might know. The sequence of keys is more like writing up a calculation in a textbook, whereas for "normal" calculators operations are reversed in some places.
For example, with most calculators you would type 30 [sin] to calculate the sine function of 30 degrees, with the 115ES its [sin] 30 [=].
The 115ES has all the standard trigonometric functions:
  • Standard functions (sin, cos, tan), type the [sin], [cos] or [tan] key followed by the argument.
  • Inverse trigonometric (sin?¹, cos?¹, tan?¹), type [SHIFT][sin], [SHIFT][cos] or [SHIFT][tan] followed by the argument.
  • Hyperbolic functions (sinh, cosh, tanh), type [HYP][sin], [HYP][cos], or [HYP][tan] followed by the argument.
  • and finally inverse hyperbolic (sinh?¹, cosh?¹, tanh?¹), its [SHIFT][HYP][sin], [SHIFT][HYP][cos], or [SHIFT][HYP][tan] followed by the argument.
Arguments can be given as numbers with mantissa (2.718), as fractions (use the fraction key below [CALC]) or as degree, minute, second (30°12'45") using the [°'"] key for input. To switch between degrees (1 circle = 360°), radians (1 circle = 2?), or grad (1 circle = 400 gon), use [SHIFT][DRG>].
Jan 06, 2011 | Casio FX-115ES Scientific Calculator
How to solve for the trigonometric functions in the casio scientific calculator?
Press the relevant function key [SIN],[COS],[TAN] followed by the angle value.
For inverse trigonometric functions [SIN^-1], COS^-1], or [TAN^-1], Press [SHIFT][SIN], [SHIFT][COS], or [SHIFT][TAN].
For other functions
sec(x)=1/cos(x)
csc(x)=1/sin(x)
cot(x)=1/tan(x)
When calculating trigonometric functions one must make sure that the angle unit the calculator is using is the correct one.
Aug 26, 2010 | Casio FX-115ES Scientific Calculator
Need to know how to obtain the cot,csc, and see in the degree mode and radian mode
There are no dedicated keys for these trigonometric functions, for the simple reason that they can be obtained from the tan, sin, and cos by a simple division.
cotangent (x) =1/tan(x) . Do not confuse with the arc tangent tan^(-1)
cosecant (x) = 1/sin(x) . Do not confuse with the arcsine sin^(-1)
secant(x) =1/cos(x) Do not confuse with the arccosine cos^(-10)
If you know how to use the tan, cos, and sin, with angle unit in degrees or radians, then there will not be any problem
If angle unit is degree, any number you give a trigonometric function is interpreted as degree. For instance if mode is in degree , and you calculate cos(PI) do not expect the value -1. You will have the value corresponding to the cosine of of 3.14159 degrees, namely 0.99849715
Now for you if you are interested.
If [MODE] is in degrees you can still enter angles in radians
You use the [2nd][ANGLE] [3: raised r] [ENTeR].
Here is a screen capture to show you more clearly.
The raised r is obtained by [2nd][ANGLE][3: raised r] [ENTER]
Hope it helps.
Oct 13, 2009 | Texas Instruments TI-83 Plus Calculator
Cos+tan(sin)=sec
This is a trigonometry problem not a calculator's.
cos(x) +tan(x).sin(x) = ( cos(x) + (sin(x)/cos(x)).sin(x). After reduction to the same denominator (which is cos(x)) you obtain
{cos(x).cos(x) + sin(x).sin(x)} divided by cos(x).
The content of the bracket above is just 1.
Your fraction will have 1 as numerator and cos(x) as denomitor. That is exactly the definition of the secant function i.e. Function sec is the reciprocal (not the inverse) of the cos function, while the arccos is the inverse of cos.
A mild advice: Avoid writing function without specifying the argument (the variable on which a function acts).
Note:
Aug 14, 2009 | Casio FX-115ES Scientific Calculator
(1+cotx-cosecx)(1+tanx+secx)=2
I shall attempt :D
1) cosec A + cot A = 3
we know that (cot A)^2 + 1 = (cosec A)^2
Hence, (cosec A)^2 - (cot A)^2 = 1
thus, (cosec A + cot A) (cosec A - cot A) = 1
3 (cosec A - cot A) = 1
(cosec A - cot A) = 1/3
(cosec A + cot A) = 3
Summing them, 2 cosec A = 3 1/3
cosec A = 6 2/3 = 5/3
sin A = 0.15
Thus, cos A = sqrt (1 - (sin A)^2) = 0.989
2) Prove that (1+tan x - sec x)(1 + cot x + cosec x) =2
expand
LHS= 1 + cot x + cosec x + tan x + 1 + tan x cosec x - sec x - sec x cot x - sec x cosec x
We can calculate that
tan x cosec x = sec x (since tan x = sin x / cos x)
sec x cot x = cosec x
so the above is
LHS = 1 + cot x + cosec x + tan x + 1 + sec x - sec x - cosec x - sec x cosec x
LHS = 2 + cot x + tan x - sec x cosec x
LHS = 2 + cos x / sin x + sin x / cos x - 1 / (sin x cos x)
LHS = 2 + [{cos x}^2 + {sin x}^2 - 1] / (sin x cos x)
LHS = 2 (proved)
May 12, 2009 | ValuSoft Bible Collection (10281) for PC
Maths
I am having problems with this one. Is this tan(a) + cotan(a)=1? The only solution I get is sec*csc. Tan is sin/cos and cotan is cos/sin which yields sec*csc. Is it supposed to be adding these two or multiplying these two? cuz if it is tan(a) * cotan(a) then the answer is one.
Aug 12, 2008 | 2001 Saturn S-Series
TI-84 Plus silver edition sin/cos/tan
for function = (sin,cos,tan,sec,cosec,cotan)
arc(function) = function^-1, calculated in the first quadrant for simplicity(0-pi/2) (0-90deg), as all functions repeat circularly
just another method of notation
http://www.mathwords.com/t/tangent_inverse.htm
Jun 19, 2008 | Texas Instruments TI-84 Plus Silver...
74 people viewed this question
k24674
jasbo
jasbo
