Question about Hitachi 53UWX10B 53" Rear Projection Television
Hitachi 53UWX10B magic focus blinks once then black
  • Barbara Waxer Apr 22, 2013
    Same with DCAM
  • Barbara Waxer Apr 23, 2013
    History: Had major convergence issues, replaced the chips, but no resistors as they looked fine. Afterward, display looked perfect, could access Magic Focus & DCAM fine. That lasted about a day. Then blue started to warp. Disassembled to ensure soldering was good, when I reassembled I could not longer access DCAM or Magic Focus. When I pressed respective buttons, the alignment screen would flash on upon button release, but not stay on. Update: can access Magic Focus, blue still off on on top row. Still can't get DCAM screen to stay on. Note: If the suggestion is to replace the blue resistors, will need help IDing which ones in the new kit.
  • Hitachi Master
  • 3,459 Answers
There are several common fixes for this model that you can get from www.tvrepairkits.com
Posted on Apr 26, 2013
yankeegurl
  • 121 Answers
SOURCE: PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Posted on Apr 13, 2008
Slinteriors
  • 8617 Answers
SOURCE: Magic Focus does not fix the blue 57UWX20B Hitachi
you need to replace the convergence ICs they are STK392-110 you can get replacements at the following link and they send instalation instructions with pictures so you can do the repair yourself. You need to replace both IC they are both STK392-110 they are located on the large heat sink on the far right side of your Tvs' chassis Heres the link for replacement ICs
Posted on May 20, 2008
experttv
  • 203 Answers
SOURCE: hitachi tv magic focus does not work
Your problem is the convergence circuit. This is very common in CRT projection sets like yours. There are a couple of IC's that need to be changed and possibly some resistors. A good repair shop will run you $400-$500 to do the repair.
Posted on Oct 28, 2008
ladywinn
  • 5138 Answers
SOURCE: hitachi 61udx10b
Replace Both of your STK ICs they are your convergence ics they are big black ICs will have Part# on them for example STK392-110, if they are 110s use 180s, if 020s use 040s other wise replace with exact same number. To get Parts call Electronix 1-800-223-3205
Posted on Dec 30, 2008
Ecollier2012
  • 3459 Answers
SOURCE: convergence settings on hitachi 53uwx10b
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 19, 2009
Testimonial: "Thank you for the info. It was really helpful. TV is back in business. :)"
How do i adjust the magic focus?
  • Press "Menu" on the remote select the "Magic Focus" option in the Video menu or press the "Magic Focus" button on the front panel to adjust the convergence of the three picture tubes that create the proper color for the picture. Pressing the button on the TV initiates the automatic adjustment, and accessing the feature through the Video menu allows you to choose automatic or manual adjustment, though the "Automatic" setting must be selected for the button on the front of the TV to begin the process.
  • Aug 04, 2011 | Hitachi 53UWX10B 53" Rear Projection...
    Convergence is out, magic focus not useful. Help? There are adjustments on the lenses but how would you adjust with the back removed? . Yes, I know something about electronics, CRT's, and even lasers. I...
    Unless the CRT gnomes got in there and messed with the FACTORY SET focus adjusment then don't touch them. you'll only make it worse, you need to have the convergence board rebuilt and it should work fine.
    Jan 02, 2010 | Hitachi 53UWX10B 53" Rear Projection...
    Power light on my hitachi 53UWX10B blinks 7 times then shuts off
    Replace Both our STK ICs they are big black ICs will have part number on them example STK392-110 for parts call Mats 1-800-628-1118
    Nov 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
    I get a split up of red and green in a wave at top of screen
    The convergence ICs and resistors are the most likely things to cause that. You can get the convergence repair kit for the DP14G hitachi( 53UXX10B) at the following link which contains the parts and instructions.
    http://www.tvrepairkits.net/
    Jul 11, 2009 | Hitachi 53UWX10B 53" Rear Projection...
    Magic focus 4 error
    Error 4 is listed as an overflow in the convergence section.
    To fix:
    1. Check the placement of the sensor
    2. perform an Adjustment check of th H/V size & centering
    3. Conv. amp. gain check, check these resistors:
    R041, part # 0790024R, RES.CHIP 1/16W 100 OHM
    R046, part # AQ00164R, RES.CHIP 1/16W 75 OHM TAPE
    R050, part # 0790059R, RES.CHIP 1/16W 47K OHM
    R058, part # 0790054R, RES.CHIP 1/16W 18K OHM
    R062, part # 0790047R, RES.CHIP 1/16W 5.6K OHM
    May 16, 2009 | Hitachi 53UWX10B 53" Rear Projection...
    Double vision
    there is an option to adjust the primary colors adjust them
    Dec 02, 2008 | Hitachi 53UWX10B 53" Rear Projection...
    Hitachi 53UWX10B Convergence cutting in and out
    Good Day, Armenian;
    You have poor connections on the convergence IC's , re solder and your TV should be back to normal.
    Good Luck, big IRISH.
    Aug 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
    HITACHI DIGITAL ULTRAVSION HDTV PROJECTION TV
    This is a problem with the convergence circuit. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large and black, attached to a heat sink and are marked STKxxx.
    Keep us posted on your progress.
    Dan
    Jun 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
    Hitachi 53UWX10B 53 convergence color lines dont move w\RC
    After replacing IC's, double check the solder connections for bridging or no solder on pin(s). Check all bias resistors (low ohmage). Make sure you have your VCC voltage, should have a positive/negitive voltage of about 24 v on each IC and +38v.Also, make sure all cables are plugged in and fully seated
    Note: All bias resistors are very low ohms eg; 3.3, 1.8, 2.2 make sure correct value, very important.
    If can't adjust still CPU digital convergence board (near ic's) shielded may be defective.
    Feb 23, 2008 | Hitachi 53UWX10B 53" Rear Projection...
    Open Questions:
    See all Hitachi 53UWX10B 53" Rear Projection Television Questions
    Hitachi 53UWX10B 53" Rear Projection Television Logo
    44 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    matt martin
    matt martin
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
