Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
How do you lubricate the air handler blower motor on a wheathermaker 8000
U can't oil any motors there all sealed now sound like u will be replacing your motor call some one trained or it will cost u more later
Posted on Jun 04, 2013
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: BLOWER NOISE
Could be a loose blower wheel. It has slipped and touching the sides of the blower housing.
Turn off the power to the nit.
Remove the 2 bolts holding the blower in place.
Make yourself a wiring schematic.
Remove the wires.
Be careful not to touch the capacitor.
Remove the blower housing.
Clean the blower blades.
Spin the wheel to see where it is hitting.
Loosen the set screw on the motor shaft and adjust your blower wheel.
Posted on Mar 10, 2009
What causes my AC to sometimes stop cooling & can hear a buzzing from the motor?
The blower motor probably needs very badly to be cleaned, lubricated, or replaced, Michael.
Aug 06, 2014 | Heating & Cooling
How do you clean the fan in a rheem air handler?
Pull the blower assembly...2 screws on the angle bracket holding the blower & disconnect the wiring if needed to the motor.
May 28, 2014 | Rheem Complete Split System Straight...
Air handler blower/fan wont come on.
open it up and vacuum and blow out the fan and other areas
Feb 28, 2014 | Amana ASPF183016 Multi-Position, Air...
I need to replace my blower motor on my air handler
Turn off power to machine and have a 5/16" or 1/4" nut driver handy take off front door of machine. Take a rubber coated Screw driver and place across the terminals of the Capacitor to discharge any stored electricity. Cut wires for blower Black, Red, white, two browns one with white lines on it probably. Look inside machine and locate where bracket holds squirrel cage to air handler and there you will find either 5/16" or 3/8" screw remove pull bracket out. Then you will need a 1/2" socket and a crescent wrench. Remove screws for motor bracket that is attached to squirrel cage. Also you need to loosen the set screw that attaches blower wheel to motor. Apply wd-40 if needed to remove blower wheel from motor. Then install new motor on the flat part of the shaft comes through wheel attach set screw to motor shaft at that position. Install new cap that goes with motor. place entire housing of motor back into air handler and then follow wires that where previously cut back to either relays, sequencers, or fan timer board located in top section of air handler. Tighten everything up and turn power on and make sure air is coming out of vents. Then your good to go.
Apr 29, 2011 | Heating & Cooling
Indoor blower not running,capacitor is good,blower motor is good
have you check the 24 volt transformer in the air handler? you must have 24 volts from the thermostat to the tranformer in the air handler.
Jun 23, 2010 | Goodman CLJ30AR32 Air Conditioner
How to adjust blowed speed on a rheem air handler
There are probably six wires coming out of your air handler blower motor. There are 2 brown wires which are capacitor wires, one white wire which is neutral, and probably red,black, and blue. Look behind the door of the air handler to see the wiring diagram. They should have the color coded speeds marked on the diagram. There is probably some sort of control board that the blower speed taps plug into. By changing these wires around on these taps you can adjust the speed of the blower motor.
Jun 05, 2010 | Heating & Cooling
Air handler running but nothing coming out of
Shut unit off, remove door that would have the blower
located in it. Make sure that the blower motor has not seized up. Try to spin it with your hand.
If the unit starts up ,fires up and shuts down all the time, more than likely the blower motor is the problem
Feb 13, 2010 | Goodman CLQ36AR49 Air Conditioner
Why is my air handler fan motor tripping the 20
sounds like fan motor is going bad - replace
Jun 15, 2009 | Heating & Cooling
BLOWER NOISE
Remove the wires.
Mar 10, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
65 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
