Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore laundry center 110 suspension spring replacement instructions
Anyone have the suspension spring replacement instructions?
2 Suggested Answers
  • 291 Answers
SOURCE: kenmore 110 60942990 dryer works but takes 3 hours to dry a load.
Venting. When elements or thermostats burn out it is almost always caused by venting restrictions. Vent is plugged with lint, smashed(usually from the dryer being pushed back to far) vent run is too long, or nylon stocking on vent outlet. Also check to see if you can pour water through your lint screen. Sometimes fabric softener builds up on the screen and restricts the air flow. Scrub your lint screen to get this build up off. Good Luck, Appliance Specialists
Posted on Dec 16, 2009
Kenmore elite oasis 110 unbalanced
If it has a UL error and very loud during spin, you may have a bad bearing. Check suspension by pushing down on tub and if it bounces around alot, replace suspension rods. There is also a service bulletin about this problem, call sears and they may cover the replacement of the main pcb, parts and labor, it has updated software to correct this problem.
Sep 02, 2014 | Kenmore Washing Machines
How do I get the lid off a sears laundry center. Does it slide out after the lid has been popped? This unit has the dryer on top. I have to repair the lid switch
Your shouldn't have to remove the lid all the way. You should be able to replace the switch by just propping it up after it's out of the spring clips.
Mar 26, 2011 | Kenmore Washing Machines
I have an He3t/110 42922200. The drum hits housing on hi speed with a heavy load. Do I replace the drum suspension springs, the shock absorbers, or both?
Check upper springs first as one snaps on this model next make sure machine is level,if all else fails you could replace suspension legs/ struts....
Jan 31, 2011 | Washing Machines
My kenmore topload washer has always had excessive noise and vibration. we always try to balance the load but it doesn't seem to make any differance. while it's agitating i can push down on the top of it...
Although these machines typically have a number of snubber pads and suspension springs to hold the super structure in place. Inside the cabinet (just off center at the back) attached to the lower frame and the assembly is a levelling spring, 62597.
Its possible the spring is broken but its also possible it has worked its way thru the frame. If thats the case I normally just drill another hole very close to the orginal and replace the spring.
Hope this helps.
Nov 23, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer off balance
Go to www.applienceparts.com and ask them for assistance, it is a free service.
Mar 13, 2017 | Kenmore Washing Machines
Washer Tub appears top be off center after move upstairs. How do I remove cover to check? kenmore washer model # 100.24812200
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 08, 2009 | Kenmore Washing Machines
Replacing front struts
Okay....here is the steps first....and then the directions on how to use the tools:
  1. Raise and properly support the vehicle.
  2. Remove the front wheel.
  3. Detach the shock absorber lower mount by removing the two bolts.
  4. Remove the retainer nut, retainer, cushion and shock absorber.
  5. Detach the cushion retainer from the shock absorber.
  6. Compress the coil spring with a commercially available spring compressor.
  7. Detach the stabilizer bar.
  8. Support the upper suspension arm and steering knuckle securely.
  9. Remove the cotter pin.
  10. Loosen and remove the nut.
  11. Using a ball joint removal tool, detach the lower ball joint from the lower control arm.
  12. Loosen the suspension arm set bolt.
  13. Remove the suspension arm set bolt nut.
  14. Remove the nut from the strut bar front set bolt.
  15. Pull out both set bolts.
  16. Remove the lower suspension arm and coil spring. To install:
  17. Installation is the reverse of removal. Note the following torque specifications:
    1. Strut bar front set bolt: 221 ft. lbs. (300 Nm)
    2. Lower suspension arm set bolt: 148 ft. lbs. (200 Nm)
    3. Lower ball joint nut: 80 ft. lbs. (110 Nm)
    4. Lug nuts: 83 ft. lbs. (110 Nm).
May 13, 2009 | 1998 Toyota Tacoma
Vibration on second floor laundry
Apr 06, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
74 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
