Question about Plumbing
Resin expelled from water softener during regeneration
I have a water softener with an Autotrol 255 valve. Occasionally after a regeneration cycle I find approx. 1/2 cup of resin has been discharged through the waste line. I have no issues when the valve is in the service position. Any ideas regarding where to check for a failure?? Thank you.
  • juanlizcano May 16, 2009
    I have the same problem, does anybody know the answer?
Congratulations,
If you made it this far, you’ve just figured out what’s wrong with your water softener. There are a couple of things that can cause this. No it doesn’t mean that you have to throw your entire water softener away into some landfill. It can be fixed instead, possibly even at no cost.
First thing you need to check is the springs on top of the valve (in my guess this was the cause of losing resin). Take the cover off the top of the valve. Look at top of the valve, there are several metal springs. One or more of these springs may have come disconnected from the flapper valve(s). The springs will hold the flapper valves shut when they are supposed to be shut. I believe either me or someone before me did not put the valve back together correctly.
Alternatively, the flapper valves could be deteriorated, letting water/resign out. Also check the plastic dip tube that goes down into the tank, make sure nothing is broken there.
Posted on Mar 22, 2010
  • nateoverbey Mar 22, 2010
    Oh by the way. I used some panty hose attached to the drain line to determine if it was fixed. Manually run it through the cycles.
  • 21 Answers
This is a problem you have some broken parts inside the tank you need to get this fixed.  you are loosing your resin that is what sofens your water.
Posted on Jun 23, 2009
Can u use water softner pellets direct in to water
Water softener salt is used to regenerate a water softener after the softener has been in operation for a few days removing hardness from the water. If you were to only add the salt to your water you would still have hard water but now it would become salty. Go to youtube and look up How does a water softener work? If you want to buy one go to wqa.org and find a Certified Water Specialist close to you. He or she will be one of the only 5% of water treatment people who have received formal training in how to fix your water. There is a lot that can be done to improve your water.
Oct 18, 2014 | Morton Salt Inc 15010000 Water Softener...
Autotrol 1550 tc manual
I've been an Autotrol dealer for 25 years and this number is unknown to me. You will find a model number on the back of the microprocessor or timer... like 255/460i or 268/762. For a manual, go to http://www.pentairaqua.com/en-US/product/water-conditioning-and-filtration-control-valves/autotrol/ choose your valve; either 255 or 263/268, select Resources , open your manual and download.
Aug 01, 2014 | Water Dispensing & Filtration
What is wrong with my water softener Autotrol 740 Electrical problem?
if there is a bridge rectifier or diodes directly down line of the transformer i would suspect it is bad.. put an inline fuse also on the primary side of the transformer and wouldn't hurt to put a fuse on the secondary also if the transformer only has two wires for the secondary..
May 14, 2014 | Autotrol 263/740 Performa Logix Control...
Harveys water softener leaking
Actually it is regenerating if it is filling the salt tank with water. It is just not drawing out the water/brine during the brining cycle. Check the eductor assembly it is most likely plugged with iron or debris. Clean thoroughly and manually cycle unit to brine draw. Usually second cycle, until the water level is back to normal then do a manual regeneration from beginning. Then regen 3 consecutive days.
Feb 05, 2014 | Reliance Water Dispensing & Filtration
Sestem is not using up salt and will not flush the lines when it is set up to .
Hi Joey,
There could be several reasons why your softener is not using salt. If it has a Demand Control the turbine that meters the water may be blocked and stuck so the softener doesn't realize that you are using any water, so it won't try to regenerate.
Your injector may be plugged, although this would cause the salt tank to become more full with each regeneration.
If you initiate a manual regeneration and regeneration does not happen you may need to replace the softener.
Knowing what make, model and age of your softener would help greatly in assessing. The best quality softeners last 15 to 18 years unless you have an Autotrol Turbulator in your softener, in which case add 25% more time; 19 to 23 years. There are a few brands that don't seem to last longer than 10 years...
Steve Scott CWS, CI
Sep 03, 2013 | Pentair Water Dispensing & Filtration
Waterside water softener model MC250 Dear Sir, Salt level did not go down during regeneration. I poured 2 pints of warm water to break solidified tablet salt, I found moist salt, but very little water in...
the salt in use should water softener salt and nothing else
there is water added to the salt crystals up to the overflow hole
during regeneration that salty water (Brime) is drawn into the unit and upon finishing the process that reserve is refilled for the next time
there is little salt actually used during the regeneration process ( around 4 regenerations to a 25 kg bad )
Apr 13, 2017 | Dishwashers
I have a GXSF27EO1 water softener serial # LF102017B that makes a strange moaning sound frequently and I don't know what causes it, can you help me? Thank you, Don Kneebone Email donk98926@hotmail.com
That typically means the softener is in a regeneration cycle. When the valve is switching cycles it quite frequently will have the noise you describe. The regeneration cycle should be set for 2am.
RJ
Mar 09, 2011 | General Electric GE SmartWater Household...
My water softener emptied im not sure how long it was empty for but I dont think it was too long I filled it with salt and now it doesnt work. It still regenerates but im getting hard water still any...
Do you mean the salt tank was empty? If so fill salt tank half way wait about 6 hrs for brine to develop. Manually regenerate softener 2x within 24 hrs. When the salt runs out the resin becomes saturated with hardness minerals. It takes at least 2 regeneration cycles back to back to completely restore soft water. Also the hot water will take some time to get soft. It will help to flush water heater after cold water is consistently soft.
I hope this helps,
h2oservices
Feb 26, 2011 | Culligan Compatible S7011C RS23SED5...
If i had to describe how the water-softening unit works in one paragraph in simple words, can u help me with that plz?
The softener resin traps hard water and iron. The sodium strips the resin of hardness and iron as it regenerates and recharges the resin.
Ray
Jan 14, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Plumbing Logo
444 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
