Question about Acer Aspire Computers & Internet
C drive is almost empty but d drive full
My D drive which is where my auto backups go is full but my c drive is only 10% used. Anyone know why? I don't save anything to my D drive.
  • 826 Answers
You might already have the setting where your backups will be saved in D drive and hence it is full now. You can now reset the settings and change it by C drive. By the way, C drive is by default the drive in which your OS and its related files are stored and nothing else.
Posted on Apr 22, 2013
2 Suggested Answers
SOURCE: don't know how much hard drive acer 5050-3371 has
I have an ACER ASPIRE ONE. Try the following; 1- click start. 2. click computer. If it doesn't display how many GB you have left on your hard drive, click computer . I'm just a rookie, so good luck.
Posted on Apr 14, 2012
What hard drive is used in wj-hd316a
The hard disk is divided into three partitions: "Normal Recording,"
"Event Recording," and "Copy." Image data is automatically
recorded to the appropriate partition according to the recording
mode. For the normal recording partition, the data is overwritten
when the capacity is full. The event recording partition prohibits
overwriting to protect data. Copy partition prepares data for
retrieval to external medium.
Hard Disk Partitioning Function* automatically
selects the partition to be recorded.
RAID5 distributes image data to multiple hard disks in the
extension unit. Upon hard disk breakdown, lost data can be
restored from other hard disks. When using one WJ-HD300A
Series unit, mirroring function is available for data backup.
RAID5 / Mirroring Function
Playback VMD
One VMD area can set one
playback image for motion
search.
WJ-HD300A Series
Conventional
(* 10, 13, and 16 screens are available only with the WJ-HD316A.)
Even when images from multiple cameras are displayed on a multi-screen,
live monitoring can be achieved on all cameras at a full rate of 60 ips
(image per second). Experience real-time,
full surveillance with
full-rate video images.
Full Rate Live Multi-Screen
4-window 7-window 9-window 10-window* 13-window* 16-window*
Multi-screen in versatile variations
GUI Setup Menu
Time Table
Actual recording result (Example)
hope it helps
Feb 25, 2012 | Panasonic (WJ-HD316A/500) (WJHD316A500)...
Cavalry 400GB CACE USB/FW800 7200 RPM 3.5in Mac Formatted
Open a Finder window and type a search word or phrase in the search field in the upper-right corner.
step_2.gif Focus the search by choosing a search location in the location bar.
You can search your entire computer(This Mac) or the folder that was selected in the Finder when youstarted your search. New search results begin to appear after youselect a location.
step_3.gif Refine the results by specifying search criteria.
Specifying criteria in a search window step_4.gif Click the Time Machine icon in the Dock.
If Time Machine isn’t in the Dock, look for it in the Applications folder.
step_5.gif Use the arrows and the timeline along the right edge of your screen tobrowse through the Time Machine backups. Your search is performed inevery window.
step_6.gif When you find the item you want to restore, select it and then click Restore.
Aug 26, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
DMC-zs10 records on internal memory - not on SD card
Hello bro..
Do you check your SD card? It is work ?
My solution:
1. Off Lumix camera.Until LCD was off. Press center of card to remove it.
2. Use card reader to connect your SD card to pc/netbook/laptop..
3. Check full capacity for SD card, it is empty(zero) or have it their mount.
4. If empty (full,used,free is zero) ,try reinsert card again and don' t touch the terminal.
5. If still empty, that mean, your SD card was corrupted.
6. If not empty, backup all data in SD card.
7. Format the SD card using FAT32.
8. Checking Disk.
9.Insert back to camera, and format SD card using camera menu.
10. Take picture. and see if save on SD card or not. comment back here. if succes or not.
11. Don't use any battery except original from panasonic. It will affected to product.
12. Don't remove battery or card before lcd was off light.
Jul 24, 2011 | Cameras
My drive is full so it won't back up anymore!
Check the backup settings in the software that came with the device. You may be saving every backup instead of saving incrementally. An incremental backup will back up the files that have changed after doing one full backup.
You can also view the files on the drive through Windows Explorer.
The files should be dated. Delete the oldest files making sure that they seem to be the same size as the next oldest file.
If your computer is not faulty, and the files on the backup are not the only place that they are copied, you can start over with the backup drive, change the backup settings and create an incremental backup routine.
Depending on the size in Gigabytes of the backup drive, you are limited to the amount of data you can back up.
Example:
If you have a 500Gigabyte drive in your computer and the external backup drive is 250 Gigabytes,a full system backup will not fit.
Go to Windows Explorer, Click on My Computer and view the available space and total size for each drive.
If you need more help, Use Fixya's new Phone Call Service. For $29.99 an expert will walk you through the setup and drive check.
Mar 17, 2010 | Western Digital My Book Essential Edition...
Unable to schedule auto backups on Mybookworld 1 TB NAS
how do i go to all these problems? if the amount of passwords and users names i have printed to my computer would cause me to resign in and start using my computer when the passport is plug in. let us solve this problem right now.
Jan 17, 2010 | Western Digital 500GB My Book World...
External disk drive full when i try a operator initiated backup
Before runnning the backup please go ahead and run the check disk once..
chkdsk /f/r use this command on the command prompt
Nov 11, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Sync software/empty folder/ slow backup/
hello frustrated one,
the back up feature is application dependent, not hardware dependent, misfortunately. Gotta love sales guys.
my understanding is that these will back up data files, not application files.
backup speed is dependent on how it's connected. in ascending order.
USB 2.0
Firewire
Ethernet
simple situation..just need to know what your connecting with.
Also, you may want to consider an online backup utility, as well. I use one from here
May 08, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Formatting hard drive on 604 wifi.
upload the latest firmware first
http://gofurygo.blogspot.com/2006/11/archos-604-wifi-firware-updated.html
Nov 26, 2007 | Archos 604 WiFi Digital Media Player
Axim Data Backup Does Not Work
After doing a soft reset to enable Clear Type, I tried a backup of all data and everything worked! Nor Backup Failure Message and the backup file can be seen on the CF card.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Computers & Internet Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
