Question about HP Officejet 6310 All-In-One InkJet Printer
How may I do a return address label--all 30 labels on 5160 Avery template without typing the address 30 times
  • HP Master
  • 1,679 Answers
Hi Jan,
You can use the option Mail Merge In Microsoft Word to print Return address.
If you are Using Windows 2003, Follow the link below
http://www.wikihow.com/Mail-Merge-in-Microsoft-Word
If you are using Windows 2012, You will find Mail Merge option under Mailing tab on top - Create Mail Merge option
Regards,
Sean
Posted on Apr 22, 2013
  • 112 Answers
SOURCE: paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Posted on Jan 15, 2008
SOURCE: HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Posted on Dec 11, 2008
  • 43 Answers
SOURCE: label stuck on a roller?
Looks like label stuck on the toner cartridge. Easiest solution would be to replace toner cartridge or if you can slowly spin the OPC drum on toner cartridge till you find label NOTE: damage to the OPC drum with affect print quality as well as oil from fingers will affect PQ( print quality)
Posted on Jan 13, 2009
  • 71 Answers
SOURCE: c6180 will not print labels as set out in the
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Posted on Aug 09, 2009
  • 414 Answers
SOURCE: My hp officejet J4680c printer and my hp pcs 1315
follo0w the link to avey for further help
http://www.avery.com/avery/en_us/Help-Center/Formatting-and-Printing-Tips/_/Ns=Rank
Posted on Jan 05, 2010
How to make address labels
Get the Avery plug in for word from the Avery web site. It makes things so easy if you do.
Aug 18, 2014 | Avery 5160/8160 compatible (100 White...
How do i merge and print labels please
Hello, I have had the same problem but useing windows 7, I downloaded the avery address label template for the particular stock and alligned perfectly to my computer. The templates work much better and efficiently then microsoft office and I'm not wasting prinyer ink.. Let me know if I can be of further assistance..
Nov 22, 2012 | YouTube Videos
I have an Access file with 132 names with addresses. I want to print them on Avery labels. How can it be done?
Avery labels have an ID# that when entered into the Avery site will supply you with the page format for your Msoft Office software.
Dec 14, 2011 | Avery 5160/8160 compatible (100 White...
How do I set up my HP 3050 to print Avery labels 5160?
You need to download the templates they have online and edit them in Microsoft Word. Here is a link to the template:
http://www.avery.com/avery/en_us/Templates-&-Software/Templates/Labels/Address-Labels/Address-Label-30-per-sheet_Microsoft-Word.htm
Click the blue download template button and follow the instructions.
Mar 31, 2011 | Office Equipment & Supplies
Hi I am trying to print labels. Avery #05161 and business cards Avery8371TM or 5371TM. I am using Microsoft Office and there do not seem to be any relevant numbers. I have gone under labels. Help Thanks
You can use a different template for either the labels or the business cards, just make sure the labels you choose are the same size as the avery 05161 & the business cards are the same paper eg: glossy etc. The other thing you can do is go to avery.com & download the correct templates.
I hope this helps you
Jan 21, 2011 | Avery Address Labels AVE4151
I have a Kodak ESP 5200 series printer. When I try to print Avery 8160 address labels the sheet comes out not printed.
Hi
You can try and download the label again from below link--
Avery 8160 label download
Click the "Download Template" button. Enter your info and click "Submit". Follow the prompts to download the file. After you download your Avery template, be sure to remember where you saved the file on your computer and the file name. Open Microsoft® Word or an Adobe® program for your template and select File > Open to navigate to the drive and folder to open your template. Use the program's formatting and printing features to edit and save your template. For Microsoft® Word users - If the template looks like a blank page, select Table > Show Gridlines to view the template layout.
Hope this helps... Please post back if you need more information.
Daniel
Dec 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do you type and print Avery labels 74520? I have lost the instructions which came with the labels.
This can be done with settings through your word processing program. Assuming you are using Word:
Microsoft Word 2007
The newest version of Microsoft® Word now includes hundreds of Avery Templates for labels, business cards, dividers and more.
Find Avery Templates by selecting the Mailing tab at the top of the Microsoft® Office Word screen. Just choose Create > Labels > Options > Avery US Letter, then choose your template by selecting the correct Avery Product Code.
Access Pre-Designed Avery Templates that are available from Office Online by selecting the round Office button at the top left of the screen, selecting New and then choosing the Avery product type. Pre-designed templates for Avery business cards, greeting cards, dividers, labels, note cards and postcards are available.
Avery Wizard for Microsoft Office is a free download which inlcudes step-by-step instructions to format Avery labels. Trust this is helpful. :)
Dec 08, 2010 | HP Officejet 6310 All-In-One InkJet...
How do I use Avery Template
download it from their site in the type of labels you bought (there is u template number on the box).
they provide MS Word documents, open the document and you'll have the labels layout to start creating and printing labels
Dec 27, 2009 | Avery Wizard for PC
Avery laser addressing labels l7160
What software are you using? I use Microsoft Word to print my Avery labels, and quite often have to tweak their templates by simply adjusting my margins on the page. I do a 'select all' and then add one tenth of an inch at a time until the proof sheet looks just right. If the labels are a bit off, you can also adjust the pitch in the label options dialoge.
Oct 08, 2007 | Avery DesignPro 2000 for PC
HP Officejet 6310 All-In-One InkJet Printer Logo
152 people viewed this question
Seeker5211
Seeker5211
