Question about Philips HDD1630 MP3 Player
Philips HDD1630 doesn't turn off..
My MP3 philips HDD1630 doesn't turn off, is just frozen in the screen Gogear, no matter what I do, plug it to the computer o the electrical power nothing changes, I tried to reset it using the power button and the volumen + but the problem persist.. Can you help me?
  • Chewi_Ninja Dec 19, 2007
    reset works, but when i plug it in, it goes back to the "GoGear" screen and wont change. . .
  • Anonymous Dec 27, 2007
    YES,ITS BEEN LIKE THIS FOR A YEAR NOW,PHILIPS COMPANY DOESNT WANT TO HELP ME,DEY DONT WANT TO REPLACE IT OR NOTHING,I DNT KNOW WHY?PLZ IF ANYONE HAS A SOLUTION CONTACT ME AT [email protected]
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
SOURCE:
GoGear screen is frozen and device will not turn off
go with the reset button, it will erase the music but is not that bad.
any way, you will have another problem later. if you are able to change it...do it! i have had a lot of different problems
Oct 27, 2008 | Philips GOGEAR SA6045 MP3 Player
What is wrong?
It doesn;t matter if it turns on or not - it only matters if the computer recognizes that something has been plugged in, try one more time:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 27, 2008 | Philips GOGEAR SA6045 MP3 Player
Device manager wont detect my gogear HDD1630/17 even though i recently updated the software and driver, also my device is frozen on "Please connect player to pc". I can't even get it back to the menu...
I was experiencing this similar problem, and from my research so were alot of other people, what finally worked for me was this:
  • Update all the software on your computer via Phillips site
  • Open the Philips Device Manager
  • With the device connected and the 'connected to pc' screen showing on the GoGear, do a 'soft reset' by holding the Power Off + Volume Up buttons for a few seconds
  • As soon as the device restarts itself, hold the Volume Down button, the computer should now recognize the GoGear
  • Follow the onscreen directions to Repair the device
  • Thank the intarwebs.
May 21, 2008 | Philips GoGear HDD6330 MP3 Player
My phillips 1630 6gb is frozen on the gogear screen
Press volume + with the player disconnected from computer.
Continue holding volume + as you reconnect player to computer.
Continue holding volume + after you connect player to computer.
Windows will recognize it for what it is after 5 to 55 seconds and will say "Found Hardware Wizard" - go through re-installation.
Get the latest firmware upgrade after you are done by Opening Philips Device Manager - Click on Update Tab - this will prevent problem from recurring in future.
Note: if you have Windows Media Player 11, ignore everything I said. You must rollback to Windows Media Player 10, or this player will give you constant heartache.
-Tha Mp3 Doctor
Mar 19, 2008 | Philips HDD1630 MP3 Player
Philips HDD1630 MP3 Player about 2 years old, no excessive use, won't charge any more or be seen by computer. Only shows low battery on screen then dies. I am a little technically incline, can anyone tell...
You may have to change the battery, but try Reset, Repair, and Update (firmware upgrade) first. Also, there is an FAQ on the Philips website for the computer does not recognize device issue (but only follow it AFTER you have tried reset, repair, and update).
Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
After repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
Feb 05, 2008 | Philips HDD1630 MP3 Player
Froze on the screen
Here's what you want to do:
1) Back up all music and picture files if possible
2) With the GoGear powered on, reset the player by holding the power on/off and volume + keys simultaneously until the GoGear shuts down
3) Turn the GoGear back on and see if message persists
If the "please connect player to PC" msg persists:
1) Connect GoGear to computer
2) Open Philips Device Manager (Start --> All Programs --> Philips in Windows XP if no shortcut on desktop)
3) Click on the Repair tab - see if there is a msg that says something like "to repair your player, connect GoGear to computer while holding the volume + button"
4)IMPORTANT: Disconnect the GoGear from the USB cable, turn the GoGear OFF, and then press and hold the volume + button; then, connect your GoGear to PC while still holding the volume + button (VERY IMPORTANT: this process will fix your player, but it will also delete all music and images you have stored on the GoGear) - do not let go of the Volume + button until a pop-up comes up saying that your player is being repaired
After the repair process is complete, your player should work fine - you will have to re-download all files to the GoGear.
-ThaMp3Doctor
Feb 04, 2008 | Philips HDD1630 MP3 Player
Is HDD1630/17 compatible for vista?
Not when you posted, but there is now:
-Tha Mp3 Doctor
Aug 12, 2007 | Philips HDD1630 MP3 Player
My philips mp3 wont work
-Tha Mp3 Doctor
Jun 02, 2007 | Philips HDD1630 MP3 Player
My mp3 keeps freezing!!!!
-Tha Mp3 Doctor
Sep 19, 2006 | Philips HDD1630 MP3 Player
Philips HDD1630 MP3 Player Logo
76 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
