Question about Conair DCC-3000 - Cuisinart Coffee on Demand DCC-3000 Brewer
Cuisinart dcc-3000 will not brew
Everything is set up correctly and even if you manually turn it to on the blue light comes on but no brewing.
Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
Only brews one cup at time
Open this website and choose on the right side "DOWNLOAD USER MANUAL"
http://www.cuisinart.com/parts/coffee_bar/dcc-2000.html
Jan 13, 2013 | Cuisinart DCC-2000
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
Mar 21, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart Grind & Brew DCC 490
ask manualfox.com, they have it.
Sep 10, 2008 | Cuisinart Coffeemakers
Cuisinart dcc 1200 will not brew
I'lm not sure of the model, but it is a Cusinart Coffee Maker with a Glass Pot. It gets power on all lights except the ON/OFF switch, and it willl not brew. Any suggestions, or should I trash it and get a new Coffee Maker. This one is approx. 1 year old. Thanks for your advise.
May 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Self clean feature on coffee pot
here is the link to the manual http://www.cuisinart.com/share/man/25_man.pdf page 8 - looks like you have a calcium buildup - descale overnight using vinegar/water 50% if the self clean feature is not able to deal with the problem. hope this helps :)
Mar 10, 2007 | Cuisinart DCC-1200 Coffee Maker
Conair DCC-3000 - Cuisinart Coffee on Demand DCC-3000 Brewer Logo
137 people viewed this question
Top Conair Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Conair Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
