Question about Sunbeam Irons
4268 microglide sunbeam iron
Scorching the iron surface
3 Suggested Answers
Metal maniac
  • 6 Answers
SOURCE: 4268 iron leaving residue
This will probably just need de-scaling. Buy some descaler and there should be instructions on the packet of how to de-scale an iron. Usually by warming the iron slightly, switching off, emptying out the water and then adding the diluted de-scaler to the iron and leaving it in an almost horizontal but raised position in a bowl or something so that some of the de-scaler will drain through. Then emptying out, re-filling with water and then iron something that you don't mind getting marked while any residue get's flushed out.
Posted on Aug 04, 2009
SOURCE: my wife's sunbeam microglide iron
I just took apart a Sunbeam iron. This is how it disassembles:
first remove the screw at the base. Next remove the moisture dial top (it should just pop off). This allows the iron to slide apart - the metal base from the top. It should slide about an inch then lift off.
My iron didn't get hot, and what I found is the gear that attaches the temp setting to the electrical was missing a tooth. Perhaps you could set the gear to permanently "ON". In my case I found out with brute force how the iron is supposed to disassemble... time for a new iron...
Posted on Jun 11, 2011
Sunbeam iron 5900 2400 watt not become hot. Now what can I do?
opps sr 5900 2400 watt have mixed consumer confidence
http://www.productreview.com.au/p/sunbeam-ultura-sr5900.html
if the dial or iron wont heat up at all
most sunbeam irons have 12 month warranty
if less than 12 months old and you have the reciept
take it back for refund or exchange
if out of warranty toss in the bin...... buy a new iron
Sep 20, 2016 | Sunbeam Irons
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
Iron won't turn on and heat up
laundry.manualsonline.com has free Sunbeam manuals.
Sep 23, 2014 | Sunbeam Irons
My wife's sunbeam microglide iron does not get hot. What could it be the problem?. Mauricio. Thanks.
Mar 27, 2011 | Sunbeam 4214 Iron
Fleece shirt melted on the bottom of non-stick iron
well try heating the iron and rub the wax on the heated iron and wipe it off using cotton cloth
Jan 04, 2010 | Sunbeam 4237 / 4238 Iron with Auto...
Aug 04, 2009 | Sunbeam Irons
Trouble cleaning Sunbeam iron 3983
you can buy an iron cleaner from your hardware store, wallmart sell it.
Jun 09, 2009 | Sunbeam Best Value 3983 Iron
Cleaning non stick iron surface
There is a product called goo-be-gone available at any hardware store in a small bottle which will remove the adhesive easily.
please mark this as a fixya! thanks
Mar 17, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
Irons Logo
20 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
