Question about Provo Craft Cricut Expression Personal Electronic Cutter
Cricut i get a "cartride communication error"
2 Suggested Answers
CricutAddict
  • 13 Answers
SOURCE: Cricut Expressions Machine error
  1. Make sure your cricut is off when you plug it into your computer via usb.
  2. Make sure your usb cable is plugged directly into the machine, and not to a usb hub.
  3. Start up the DS Once the DS is fully loaded, choose HELP > UPDATE FIRMWARE.
  4. On the cricut machine, hold down the STOP button. Keep holding it down and briefly hold down the power button. Keep holding down the stop button and in about 3-5 seconds, you will hear a beep. That means you are good to go.
  5. On the "update firmware" screen on your computer, select the model you have and then click "begin updating now"
  6. Go and read a magazine or make a cup of tea because it takes a while to update. If it goes really fast (no matter how cool your computer is) it means it did not install properly and you will probably have to do it over again.
Hope this helps you.
Posted on Mar 25, 2010
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    Cricut explore one. Downloaded program,but get error message,wont install
    Frustrated!!! [Driver installation problems][Resolved] - Make The ...
    forum.make-the-cut.com/.../frustrated-driver-installation-problems-resol...
    May 11, 2010 - 29 posts - ‎10 authors
    I cannot get the Cricut firmaware to update. ... I just got a new computer with Windows 7, I tried to cut with the cricut but I get two error messages. RESOLVED Problem getting computer to recognize Cricut
    Dec 15, 2010
    RESOLVED!!!Help Sending Cuts to Cricut
    Jul 24, 2010
    Cricut Error: Unable to load drivers
    Jan 28, 2010
    cannot get program to cut
    Jan 14, 2010
    More results from forum.make-the-cut.com
    Dec 28, 2015 | Computers & Internet
    Cricut expression 2
    Cricket is hung up on the first small cut and keeps repeating that same cut over and over
    Aug 09, 2012 | Toys
    Getting "Catridge error: Refer to
    if the cartridge is not sensing poperly this error may occur.clean the cartride contact and try it.
    the following link may useful to you.
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01571812&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3441011
    Aug 08, 2011 | HP J3680 Officejet All In One Printer
    Error 5...ink cartridge is not recognized after refilling
    Clean the contact point of the cartridge to the printer before placing it, then **** some ink in the cartride by a cyringe to lessen the level of ink inside the cartridge. full ink cartridges encounter this error because the absorver inside the cartride overflows.
    Mar 28, 2011 | Office Equipment & Supplies
    I have the cricut jukebox but no instruction manual. Where can I find one?
    http://content.cricut.com/c/downloads/JukeboxManual.pdf
    There you go :D
    Mar 01, 2011 | Computers & Internet
    Jpeg file onto a cricut
    Cricut does not accept jpegs. They use their cartridges that come with the machine and others that you can purchase. However if you have Cricut Design Studio you can design your image with the cricut. Any further questions feel free to ask.
    Dec 02, 2009 | Provo Craft Cricut Disney Font Cartridge
    I am getting an error warning on my HP. "Error: left cartrid
    Change the cartridge if this still persists with the old and new cartridges then its a hardware malfunction with the printer and so call in to hp
    Jun 30, 2009 | HP PSC 2210 All-In-One InkJet Printer
    Jun 10, 2009 | Provo Craft Cricut Disney Font Cartridge
    Provo Craft Cricut Expression Personal Electronic Cutter Logo
    52 people viewed this question
    Top Provo Craft Office Equipment & Supplies Experts
    Tom Chichester
    Warren Roth
    Warren Roth
    Level 1 Expert
    Flo Hill-Rennie
    Flo Hill-Rennie
    Level 1 Expert
    Are you a Provo Craft Office Equipment and Supply Expert? Answer questions, earn points and help others
