Question about Pentair 1.0 Hp Whisperflo Pump
Lost high pressure to spa jets. Pump running , gauge on sand filter shows 30psi ?
New seal and impeller in Feb. No obvious leaks.
  • harry Apr 24, 2013
    Thank everyone for your suggestions. Today with the help of a pool tech. founf air intake pipe was partially cloged. An air blast into pipe corrected problem.
    Top Expert:
  • Pentair Master
  • 8,502 Answers
Backwash and try again if sand is over 3 years old replace but try on recirculate if ok you have a filter problem that I told you about if still no pressure see if impeller is plugged
Posted on May 08, 2016
4 Suggested Answers
adamh294
  • 310 Answers
SOURCE: My pressure gauge is reading 0 when the pump is
1. Make sure multi-port valve if on "filter" (gotta start with the easy answers)
2. Remove the V-clamp holding the pump housing together and start inspection.
3. remove diffuser to gain access to the impeller.
4. check impeller for clogs (very common if around pine trees)
5. If impeller in free of debris, inspect housing o-ring, diffuser o-ring, drain plug o-ring, and shaft seal (if any one of these parts as failed, this pump will not prime and the filter will have no pressure)
6. If all these things check out, then it is possible you have a suction side plumbing clog. (is the skimmer and main drain protected by screens? if so, a clog is very unlikely)
Note: the most common cause of a loss of "prime" on a pump is a failed shaft seal. It is cheap and easy to replce.
You will not want to remove the impeller or do any serious work on this pump unless you have replacement o-rings for the internals. New o-rings and seals is what allows these pumps to work properly.
Hope this helps
If this post helped you, please take the time to vote positively for me on this site.
thanks,
adam
Need more help? adamh@newconceptchem.com
Posted on Oct 28, 2010
  • 366 Answers
SOURCE: my new Optiflow pump surges..............it
it sounds like you may have a suction side leak on the pump. check the lid o-ring and the suction side fittings to see if there may be a possibility of air being sucked into the pump and causing it to act like it's picking up prime and then losing it.
Posted on Jul 31, 2011
xler8tn
  • 64 Answers
SOURCE: Weak return, weak suction when vacuuming
It may be the hose going from the pool to the pump intake is partially clogged. I had the same problem,, removed the hose and shoved a broom handle through it to remove tree debris.
Posted on Jul 24, 2012
I have almost no flow from my Hayward Sand Filter VL40T32. What do I need to do to get the flow back?
Look at your pressure gauge. If it is reading high, you have a clogged filter. Open filter and clean out or replace sand.
If it is reading low, you have a pump/ suction issue. Check the o-ring on the pump basket lid and make sure it is lubed and has no cracks. Check your basket for cracks. The pump impeller could be clogged. The pump may be pulling air in through a suction fitting or a small crack.
Jun 22, 2015 | Hayward Pool & Spa
I have an air leak in intake line
Question:
What do I do if my pool/spa pump is loosing suction or prime?
Answer: by Osko Pool n Spa Pool Pump Losing Suction or Prime If your Swimming Pools Filter system looses Prime, it is caused by one of the following conditions.
Note: The lost of suction/prime is caused a leak which in turn sucks air into the system. The lost of suction/prime will be anywhere from the Main Pool Skimmer(s) to the Pool Pump. It will NOT be from the Pool Pump to the Pools Main Return(s).
1) First make sure that your water level is high enough so that the skimmer is not sucking air.
2) Check the Pump Pot Housing Lid Seal and be certain that its completely sealing and is not
Sucking air into the system. Check the lid for cracks. If either condition is true, replace the Pump Pot Lid Seal and/or entire lid
3) Check all fittings, clamps and hoses from the pools skimmer to the Pools Pump Pot Housing for wear, tightness and leaks.
4) Check Pool Pump Pot Housing for cracks.
If everything aforementioned in good working order, the next thing to check is the Pump Pot Housing Main Seal and the Pumps Impeller and finally the pump.
5) While the Pool Pump Motor is running, carefully inspect the area where the Pump Pot Housing attaches to the Pump Motor. See if there is any water leaking. Next, spray the area with water and see if the water is sucked into the Housing. If so, your Main Seal is damaged.
6) Disassemble the front half of the Pump Pot Housing from the back half and inspect the Pump Motor Impeller. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged.
7) Re-inspect the Pump Pot Housing Main Seal by standing the partially disassembled upright, with the Pump Motor towards the ground. Pour water over the impeller and into the cavity. See if the water leaks thru to the outside of the Pump Pot Housing. If so, your Main Seal is damaged.
8) Remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged.
If everything seems to be in good working order, then you need a new pump... not just replacement parts
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
Aug 18, 2013 | Hayward SAND FILTER, PRO SERIES
Pressure psi filter
Is there water flowing into the pool? If the flow is there it may only be that your gauge is stuck. If not make sure the pump pot (where the basket is by the motor) is full of water before starting. If the pump has water + is running + no psi showing + no water flow, then you likely have an impeller issue. The pump needs to be opened up to see if the impeller is clogged or broken.
May 29, 2013 | Hayward SAND FILTER, PRO SERIES
I have a swimpro sand filter it is 5 yrs old and this season when i started it up it doesn't seem to have very good pressure i have backwashed it three times and it wont even run my pool cleaner no...
If there is not much pressure, the problem is with the circulation system. Probably the pump.
When a sand bed gets old the pressure goes up on the guage, but the filter doesnt do much. When there is a lack of pressure, its due to a problem with the water flow. Usually a clogged impeller, strainer basket, or skimmer basket.
The most common solution for a loss of pressure is to dissasemble the wet end of the pump, clean out the impeller, and replace all o-rings and seals, including the shaft seal. This will revitalize the performance of your pump.
Jun 02, 2011 | Hayward SAND FILTER, PRO SERIES
Done every thing suggested. Still doenst prime. should I fill sand filter?
No prime = either impeller problem, air leak, or blockage on output(bad filter or bad valve) My first choice is dirty filter. Second choice is impeller. Both easy to check.
If you have checked those than you probably have an air leak. Hold a very slow running hose over all pipe joints running into filter, while motor is running. Most likely place is the screw in fitting on front of pump. The water from hose will temporarily seal leak and it should prime.
May 29, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
I have a Hayward Pro series Model S 180T and my pump is not pulling in the water through the skimmer like it did, therefore I am not getting the circulation in my pool like I had in the past. I checked all...
There are a few things to look at here. First is filter pressure.
Check the pressure guage on the filter . If it is at a normal pressure, you sand is probably fine, but do a 20 minute backwash anyways.
Next, are you out doors? if so, when the last time you serviced your pump. All it takes is a bad shaft seal, some pine needles, or some leaves to completely block the impeller in the pump. The is easy to check, simply remove the wet-end of the pump and look inside.
If its the shaft seal, the pump wouuld be dripping water in between the wet-end and the motor.
Also, make sure all skimmer baskets and/or main drains are clear of debris.
Also, make sure all valves are in the correct position.
If the pressure on the filter is normal, again, i wouldnt think its the filter sand.
Apr 12, 2011 | Hayward SAND FILTER, PRO SERIES
Very low pressure when I run filter and when I backwash filter
Ok... First check to make sure the skimmers are clear, the skimmer float valve is open, the valves by the pump are all open and check the pump strainer basket too. If you are able to, take the motor and seal plate off and check for debris in the impeller. Also there should be an o-ring on the diffuser (the cone shaped part that covers the impeller. Make sure it is there and not stretched or damaged.
Jun 15, 2010 | Hayward SAND FILTER, PRO SERIES
2 hp Swimming Pool - Jet / Well Pump Motor / Century B124: Water pump from swimming pool to filter lost it's ...
NOT THE MOTOR ,THE SEAL... JET PUMPS ARE NOT FOR POOLS.. LOW FLOW HIGH PRESSURE.. YOU NEED HIGH FLOW LOW PRESSURE ... IF NOT YOU MAY HAVE A SUCTION LEAK OR A BAD SHAFT SEAL... VOTE JAY
May 17, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
No water is pumping back into the pool through the jets and the gauge on the sand filter stays at zero
A gauge that is reading zero indicates there is no pressure in the system, therefor no water is circulating. I am assuming the pump is turning on?? If so, you most likely have an internal impeller failure or a blockage. If the pump is on, and it just hums, then the capacitor on the motor will need to be replaced or the pump itself.
Feb 24, 2010 | Pool & Spa
Restricted flow
Try cleaning the filter cartridges thoroughly. Also test operation without filter(s) in place, temporarily. Check that any adjustable jets are open and not creating too much back pressure on system.
Apr 16, 2009 | Pool & Spa
Pentair 1.0 Hp Whisperflo Pump Logo
42 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
