Question about Garden
Wont start has been sitting outside
Has been sitting outside along time. where do I start to get it running again?
  • 7,482 Answers
Hi eggink
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in and be sure to install it in the same position
Normally the clearance is around .10 thousandsands
Also write the measurement down on a piece of paper for later reference, this measurement is critical to starting of the engine later.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
You can also try to lightly sand the module metal face to increase the possibility of ignition of the old module before replacement.
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 23, 2013
83 yamaha enticer 300 wont start. if i use starting fluid directly into cylinders it runs and dies
Check for your accelerator pump is pumping fuel directly into the engine when you rotate the throttle, if not then you probably need a carburator fuel pump kit. (usually located on the outside of the carbs). However, through following the mechanical linkage, you can see that it leads directly to the little pump assembly as well.
Good luck my friend.
kd4rua
Dec 29, 2011 | Motorcycles
I have a 95 s10 and its been sitting alot here lately i drove it the other day and it was hard to start and when it did start it didnt wont to run it is missing and stumbling real bad made it up the road...
If the vehicle has been sitting for a while, you should start by draining the fuel tank, and changing the engine oil. Gasoline does go bad if it is just sitting for a period of time, and will cause the issue you describe. Most likely, your issue is simply bad gasoline.
Aug 24, 2010 | 1995 Chevrolet S-10 CA Edition
My kenmore series 80 model # 110.74852400, takes forever to dry. the flame comes on, but doesn't seem to stay on for long. please help. thank you
my kenmore dryer ignites runs for awhile then wont reheat. let it sit for a few minutes and it will heat again for awhile
Apr 20, 2010 | Kenmore 72802 Gas Dryer
1990 acura, when it gets hot outside, the check engine light comes on and wont let me start my car. Happens after about 12 hrs of sitting outside. Starts fine in the morning on my way to work, but then...
unfortunately anything could be causing your check engine light to come one. You'll actually need to have it towed to autozone or someplace like that to have the car scanned to determine what is causing the issue
Sep 09, 2009 | 1990 Acura Integra Hatchback
DURING DAYTIME WHEN HOT OUTSIDE 35-40 DEGREES C, AC TRIPs off
units are not able to work properly above 90, 1.0 T not go for more than 1 room. is outside of unit clean? if not turn off power to unit then spray 409 or simple green or something along those lines of cleaners on the coil part (soak it real good) it should cover entire coil as much as possible. let cleaner sit on it for about 10 minutes then use water hose to rinse as good as you can. wait about 10 minutes then try unit - so work better.
Jun 15, 2009 | Heating & Cooling
Hard starting after sitting awhile
if before you start if you hold the gas pedal just a bit does it start faster if it does its our idle air control valve that defective (iac) let me now pierre
Jan 25, 2009 | 1998 GMC Jimmy
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
