Question about Vizio VA26LHDTV10T 26" 720p LCD HDTV
My vizio tv just has the vizio light on when i plug it in it wont turn on
I plug in my tv and the vizio light in just turn on what can i do
    Sergeant:
  • 308 Answers
Sounds like a problem in the power supply. Possible bad capacitors if you can have it checked out.
Posted on Apr 22, 2013
5 Suggested Answers
  • 148 Answers
SOURCE: I have a brand new vizio 32L 40a flat screen I
Assuming the Vizio name is the powerlight, then this is your problem and solution........................The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this has helped you (or not), please rate, thank you
Posted on Feb 03, 2010
SOURCE: why wont my vizio tv
its a power supply issue, you need a new psu board.
Posted on Dec 16, 2008
  • 5 Answers
SOURCE: Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Posted on Jan 25, 2010
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
I have a vizio tv...i can see the vizio logo light up but wont turn on...
Corrupted firmware. A firmware update is necessary. Contact any service technician.
Nov 21, 2015 | Vizio VO Televison & Video
My vizio wont come back on what do ineed to do to get it to work?
There are several things that could be wrong. When you plug in the set, is the Vizio light orange? When you try to turn it on, does it turn white?
Jan 14, 2013 | Vizio VX42L 42 in. LCD TV
Vizio HDTV E3DB420VX wont turn on
If your power indicator isn't lighting up, you don't have your 5vdc standby power. You're most likely looking at a power supply issue. Did this happen after a T-storm???
May 11, 2012 | Vizio 42 Class 120hz - 3d Hdtv Lcd...
My vizio wont turn on but the vizio organge light comes on please help
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. Hope this works for you.
Mar 26, 2010 | Vizio L32 32 in. LCD HDTV
My vizio tv wont turn on. Any secret buttons that
Hi my name is Roety,
I can help you with your issue ,
 Check the AC plug, to reset the TV unplug and connect it. If the power light lights up check the input select button the TV needs to be own the correct input to view TV again.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Jan 26, 2010 | Vizio VW32L 32 in. LCD HDTV
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
Vizio vn60p clicked off wont come back on
Try to unplug the power to the TV for about a minute and plug it back in. Is the Vizio LED light on?
Jan 02, 2009 | Vizio VM60P 60 in. Plasma TV
Vizio VA26LHDTV10T 26" 720p LCD HDTV Logo
390 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
