Question about Coby TFTV3225 32 in. LCD TV
Coby tv in standby - Coby TFTV3225 32 in. LCD TV
    Sergeant:
  • 308 Answers
It sounds like the power supply is not coming up to power the rest of the set. I would look for defective capacitors in the power supply first. If nothing turns up there, there could be a shorted component keeping it from running elsewhere.
Posted on Apr 22, 2013
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
My led tv coby 1926e is standby. How to make it. ?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 08, 2015 | Coby Televison & Video
Hi. First How do I get the apart with out damage. I only see four screws at bottom center behind the pivot bracket.
Time to leave this set behind, many problems with them and company went bankrupt. Visit this site for more info. http://coby-tv-reviews.measuredup.com/9211179
Feb 03, 2015 | Coby Televison & Video
Standby light is on but doesn't turn on! Measure the 24V on turning on but losses it!
Most TVs shut off automatically if there is no input signal. This would also explain the lack of screen image.
Jun 23, 2014 | Coby Electronics Corporation Coby...
Coby 40 LCD TV has splash screen and sound, but no picture
Looks like you might have issues with your screen it self the lights and all internal issues. You might have to take into a repair shop to get it done, a fuse might have been blown up. If you have warranty try to take it in and get it fixed.
Nov 05, 2013 | Coby 40 TFTV4028 LCD TV
TF TV 4025 TV will not come on. A NO Signal comes on.
Do you have standby/power LED on the front of the TV? You may have a defective power supply. A good source of replacement Coby TV boards is Tri-State Module. You could ask their technicians to help diagnose it further.
Nov 04, 2013 | Coby TFTV2214 22 in. LCD TV
My coby tftv3227 tv won't turn on and has no sound plugged it in new power source and still nothing what to do?
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_27_2012_5_44_12_pm.jpg5_27_2012_5_44_31_pm.jpg
May 27, 2012 | Coby TFTV3227 32 in. LCD TV
My Coby 40 inch HDTV wont turn on. The blue light on front (standby?) is on but I can't turn it on. Help I don't wanna buy a new tv
I had a 32" Coby that did the same thing, turned out to be a defective main board. The main board wasn't sending the 3.3v signal to wake up the power supply. In my case I sold the tv for parts because it wasn't cost effective to replace the main board. It sound like your main board
Apr 10, 2012 | Coby Televison & Video
Remote does not work
You can get a replacement remote directly through Coby:
What to send:
$6 Money Order 'Made out to Coby Electronics'
Note with your name, address, phone#, model# and what part you need
Send to:
Coby Electronics
Att: Customer Service
56-65 Rust St
Maspeth, NY 11378
Aug 05, 2008 | Coby TF-TV1901 19 in. LCD Television
Coby dvd player
do you see the laser light come on when the disk spins if not it has probably lost power or failed, if so sometimes the laser head gets moved to close to the drive mechanism and the motor cant pull it out. i have found several of these that had this problem.
Oct 19, 2007 | Coby DVD-207 Portable DVD Player
Coby TFTV3225 32 in. LCD TV Logo
102 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
