Question about Briggs & Stratton Garden
Briggs & stratton mod. 406777-0115-E1 engine backfires thru exhaust
Engine starts and runs fine except that it backfires thru the exhaust.
    Sergeant:
    Champion:
  • 320 Answers
This is a true tale sign of a valve being out of adjustment or possible burnt or sticking. Most likely its just out of adjustment. Setting them to Book Specifications of: Valve Clearance (cold) IN and EX .005" (0.13 mm) should take care of the problem. Since you said that it runs fine rules out the possibility of a sheared flywheel key, though I have seen one run with it slightly sheared. Thanks; George
Posted on Oct 18, 2013
2 Suggested Answers
  • 302 Answers
SOURCE: I need to know the valve setting for a Briggs
Around .08-.10 clearance at top dead center.
Posted on Jun 30, 2010
Briggs 5 hp backfires through muffler
Exhaust valve is not closing completely or the valve seat is cracked.
Sep 24, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How tocheck timing onbriggs stratton model44577
The timing is fixed, if you suspect the timing is off the only adjustments available are the .030 clearance from pickup to flywheel and the shear Key that positions the flywheel on the crankshaft. You would also want to make sure your valve clearance is .030 as well, the issue sounds like a valve leaking, a dead cylinder or mal adjusted valve clearance causing the exhaust valve to hang open just a bit.
May 13, 2014 | Briggs & Stratton Briggs Stratton Intek V...
I have a briggs and stratton 18 hp vanguard mod 356447 that will not start when trying to start it backfires through the carb, It seems to have good spark on both cyclinders using a sprak plug test light....
I would still say it's a timing issue. Check the spark plug leads go to the correct cylinders. Was there a woodruf key locating the flywheel and did you replace it? Check points and any cams or anything to do with the ignition.
Oct 29, 2013 | Briggs & Stratton Briggs Stratton Intek V...
My briggs and stratton 18 hp vanguard model 356447 will not start just back fires through the carb. I have good comprssion and spark at both plugs. I replaced the flywheel key as thought the backfireing...
check intake valves for proper seating. If the valves do not close completely it will allow the engine to backfire thru the carb. Another possibility is internal timing caused by the misalignment of the timing gears between the crankshaft and cam gears.
How to replace ohv cam on 17.5 briggs model 31c707-1346-b2
I SET THE INTAKE VALVE AT .005 AND THE EXHAUST VALVE AT .003 AND THE EXHAUST VALVE MOVES ONLY HALF THE DISTANCE OF THE INTAKE. IT IDLES OK BUT GIVE IT SOME GAS AND IT BACKFIRES THROUGH THE CARBURATER AND SHUTS DOWN.
Oct 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Jun 18, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
310 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
