Question about Craftsman 48" Cut Riding Lawn Mower Deck Belt 174368
My craftsman gt3000 deck belt is twisting and breaking how do i fix this problem
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 86 Answers
SOURCE: replace drive belt Craftsman 917-255572
First you have to remove the deck,then you may have to remove belt guards to install new one,then reinstall the deck
Posted on May 12, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
  • 133 Answers
SOURCE: need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
Posted on Jul 29, 2009
  • 760 Answers
SOURCE: My deck belt broke and I am unable to measure it
If you don't have the broken belt, and you don't want to buy 2 or 3 wrong belts. Go to a lawn and garden supply company or sears and buy it by model number of the mower. Then when you have the new one, find the numbers on the belt, and write them down. http://www.searspartsdirect.com or
Posted on Jul 01, 2010
What is the drive belt diagram for a Craftsman GT3000 lawn tractor?
https://www.scribd.com/document/148079291/Craftsman-GT3000-Owners-Manual
Aug 06, 2017 | Craftsman Garden
Snapper NXT236 keeps twisting and breaking mower deck belts
check for failing cutter shaft bearings , misalignment of pulleys , incorrect belt tension, wrong section belts in use
breaking belts is an indication of the belt going around a pulley and flexing against the belt fabric structure ( bending backwards as opposed to running properly in the groove) which indicates that the tension pulley is on the wrong position on the belt
Jul 14, 2016 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
Part # for drive belt craftsman gt 3000
http www searspartsdirect com model part 3000A 0736 1509200 WL000217 00005... Lawn Mower Variable Speed Belt Part Number 754 0280 GUARANTEED FIT from... Belt 715 0 Part Number 754 0370 GUARANTEED FIT from Sears PartsDirect
Here are 3 links to Sears. The first is a diagram of the drive system of the gt3000. They show 2 belts. One looks to be the drive belt and the other is for the blades. Those are the other links. Hope this helps
Jun 25, 2015 | Craftsman Garden
I have a craftsman GT3000 with a 48" deck. The blade belt was old so I thought I could replace the belt without removing the deck. Not a good idea. I unsprung the tension spring to remove the belt. Had...
Use a long pry bar the fits the s[ring end and lever the end against a solid part of the base, then stretch the spring and let it slide into the rtaining slot. The long bar is the key since it will multiply your leverage by a huge factor.
Aug 25, 2014 | Craftsman Garden
Why do the belts keep breaking on my craftsman 42"Model No. 247.288812 lawn tractor
Which belt? If its the deck belt, you could have a siezed bearing on one of the pulleys or possibly a pulley break or belt protector is out of adjustment.
Jul 02, 2014 | Craftsman Garden
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Keeps throwing off mower belt on a sears craftsman lawnmower gt3000 46 deck serial #042502A001409 model # 917.274953
if this is an older belt, it may be stretched longer causing it to pop off , specially when the mower is being raised up or down at which time the pulleys are not parallel.
Jul 10, 2009 | Sears Roebuck and Co. Pedal Tractor
Craftsman 48" Cut Riding Lawn Mower Deck Belt 174368 Logo
130 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
