Question about Sansui COM311AD 13 in. Combo
Sansui TV/VCR 13" color
The Vcr won't stop running and it wont play a tape either. It has a constant whirring sound even when the TV is playing Also,the letters D E W are on the screen. Can you Help me?
  • 78 Answers
There is what is called a "dew sensor" in a lot of vcr's that keep you from playing a tape if it senses moisture in the unit because a tape will stick to the video head and get all bunged up. sometimes they go bad and will keep you from playing a tape even when there is no moisture present. if your are electronically inclined you can take the back off and locate the dew sensor, then disconnect it. the constant whirring noise is the unit's way of trying to dry off the video head cylinder. the dew sensor, which is usally located behind the video head, is a dark grey thing about a half inch by half inch and has two wires going to it.
Posted on May 05, 2008
SOURCE:
VCR has no color picture is clear but black and white
Vee, V, a Vee Cee Rrrrr ? Not a DVD?
If you are playing a VHS tape that should be color content and it's in Black and White ... well you could check the tracking control if there is one on that model. Otherwise it sounds pretty broken. Probably NWR. Not worth repair. Try Cleaning the heads with a cleaning tape???
Nov 22, 2009 | Memorex MVT2135 13 in. TV/VCR Combo
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
Sansui VCR/DVD
Cant' get remote buttons to work. No buttons work so can not watch DVD or Tape but can hear sound. Without the TV/VCR button not respondingnit won't switch over.
Jul 06, 2009 | Sansui VRDVD4005 DVD Player/VCR
My Sansui VCR plays the tapes with sound but no picture
open your vcr. u will find a head clean it by useing cotton cloth.
Jun 09, 2009 | Sansui VCP1506 VHS VCR
Audio muffled when playing back video tape
Have you tried using a wet type head cleaning tape? If not, run one thru at least 3 times.
Feb 05, 2009 | Sansui COM3101 13" TV/VCR
Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
Sep 28, 2008 | Sansui COM3101 13" TV/VCR
Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Mar 02, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
VCR plays tape with only sound and some channels seem deleted.
Needs the vcr heads cleaned, and get a universal remote with a menu button to change the tuner setup.
Jan 25, 2008 | Toshiba MV13P2 13 in. TV/VCR Combo
Vcr setup menu
you could have a separate record head that is working & a separat pay head that is misaligned or damaged.
What u are talking about is [OSD] On Screen Display, did you always have it?, Did it suddenly go away?
Jan 08, 2008 | Sansui VHF6010 VHS VCR
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Televison & Video Logo
240 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
