Question about Datavideo MP-6000 Pro DVD Recorder
MP-6000 DVD Recorder eject button is not responding
Datavideo MP-6000 DVD Recorder is not responding to the eject button
DVD side wont respond
I had this problem as well after recording a DVD. player might be in timer mode. press SET TIMER buttom to cancel timer function, press DVD to use player.
Jan 04, 2013 | Toshiba DVR620 DVD Recorder/VCR
Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
DVD+R stuck in logik ldvr808 recorder
Pull out the power cable and leave for a few minutes then plug it back in. Now before the DVD player tries to play the disk press EJECT or OPEN/CLOSE button continously until it releases the disk.
Jul 10, 2009 | Televison & Video
How do whe open the door of a dvd recorder ?
Try this - I had the same problem and this worked for me. Don't just turn off the unit but turn off and then unplug from the mains. wait 5 mins and then plug back in, turn back on and press the eject button on the unit just once - and wait for it to finish it's start routine - and then it may open - it did on mine - if not, then try eject button again.
Hope this helps
Dec 24, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Dvd recorder repair
Remove the cover of LVW and access the dvd assy,unscrew the 4 screws holding the dvd assy to the LVW bottom.
Remove the top and bottom shield (also 4 screws)and remove the top black plastic cover (4 screws).
You will access the dvd spindle.
Remove the dvd stuck inside.
Oct 29, 2008 | Lite On LVW-5005 DVD Recorder
This can usually be down to two things, a faulty PSU board which is going to be expensive and needs to be professionally repaired, or simply a faulty or dirty DVD has been inserted into the machine.
Try the following:
1. Hold down Standby and Eject buttons on front panel together for 60 seconds (until the recorder goes into standby mode).
2. Now hold down Eject button until it ejects the disc.
3. Now insert a different DVD disc and see if that cures the problem.
If that fails then it's probably a faulty PSU, and unless the recorder is under guarantee or warranty it will be too costly to repair.
Jun 30, 2008 | Televison & Video
My DVD Rom wont open
You can get the DVD out by putting a pin into the little hold on the other side of the eject button. Try putting an audio CD into the drive and see if it recognizes it. If it won't see anything and there's no light, it's probably broken and time for a trip to the computer repair shop of your choice.
Mar 18, 2008 | Dell INSPIRON 6000 CENTRINO...
Dvd eject button does not respond
Had a similar problem after loading a suspect dvd (one I had buned myself) Could not do anything - stuck at loading.
Try this :
  1. Unplug and wait 10 seconds
  2. plug it back in and wait 1 minute. DO NOT PRESS ANY BUTTONS!
  3. With the machine still in the standby state, press eject on the REMOTE. It should eject without trying to read the disk.
Good luck. It worked for me.
Dec 03, 2007 | Samsung DVD-HR720 DVD Recorder
Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
Datavideo MP-6000 Pro DVD Recorder Logo
109 people viewed this question
Top Datavideo Televison & Video Experts
Are you a Datavideo Televison and Video Expert? Answer questions, earn points and help others
