Question about Scosche Industries Car Audio & Video
Gm13sr not getting consistant power. it works but 15 seconds after I turn the vehicle off I hear clicks from the black box and I dont get power
emissionwiz
  • 76846 Answers
SOURCE: radio and power windows
I would change out the GEM module, all these systems are controlled by the GEM (Generic Electronic Module)
Posted on Feb 03, 2009
  • 423 Answers
SOURCE: does not woork
Has the water drained by the time the dishwasher powers off?
The clicking sound is probably the (failed) pump motor and will require a service call or replacement of the unit.
Posted on Mar 29, 2009
SOURCE: Picture goes black
I had the same problem. Could you let me know how to replace the power supply? Thank you in advance.
Posted on Jan 02, 2010
  • 2427 Answers
SOURCE: black screen/pc powers on, fan works, hear
sounds like your mainboard / process is stalling ,, try the following,,
  1. unplug machine
  2. open it up to expose the mainboard
  3. remove the memory module(s) / Ram(s)
  4. locate and remove the battery (its like a flat large watch battery)
  5. press and hold the power button for 10 seconds then release
  6. replace memory / rams and battery
  7. plug in and turn on.
if that fails repeat steps 1 to 4 then
  • remove the heatsink
  • remove the processor
  • press and hold the power button for 10 seconds then release
  • replace processor / memory / battery
  • plugin and retry
Posted on Apr 01, 2011
SOURCE: got a 2006 hummer h3
what was the soution to this problem? thanks!
Posted on Sep 19, 2011
I have 2006 Nissan Altima. The engine will not start or turnover, there is also a clicking sound that is coming from the black wiring box, which is located under the hood by front passenger side...
What size engine ? The clicking you hear is probably the starter relay , provided you hear the click while turning the key to the start position . That black box is the fuse / relay junction box. Testing the starter electrical circuits with a volt meter is the way to find the problem . Voltage drop testing . Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. Year , make , model and engine size . Under system click on engine then under subsystem click on starting . Click the search button then the blue link.Does your vehicle have a manual or automatic transmission ? First blue link for a manual transmission ,the second link for a automatic transmission .
How to voltage drop test starter motor circuit
VEHICLE RELAYS Operation Diagnosis
Jul 26, 2017 | 2006 Nissan Altima
Will not start. have jumped battery. will get enough juice to make the key in ignigtion warnig bell but will not turn orver
when you cycle the key.do you hear a fuel pump noise it will be on for 3 seconds, cycle it. you should hear it, if you dont go to the battery junction box fuse area, and check the fuses. and make sure the fuel pump fuse is not shorted out. also when you cycle the key to ACC do you hear a click in that box area? This vehicle is ASD relay control ill keep my eye on this post if you repond to me i ll respond if some one else you respond to let them help you
Apr 30, 2011 | 1997 Dodge Neon
My 98 dodge durango 5.9L for a while would only start on the second try but would still crank over and start. not it wont even try to crank and the battery is fully charged then u hear clicking from the...
Have you ruled out that the starter has gone bad? With use and age, the armature can sieze in the motor, essentially making the motor useless even though there is voltage applied to it..
Write me back if you require further advice..
Mar 24, 2011 | 1999 Dodge Durango
Drivers window dont work can hear clicking under dash when push button
The clicking is probably your relay you can change it and see if thats whats wrong, its in your fuse box (bigger looking black squares). Most likely your wiring in your door is cracked, i have the same issue, however my window will work with the vehicle on and the door closed but not if the door is open and/or off.
Feb 03, 2011 | 2001 Ford Windstar
My 04 navigator left power seat wont move any direction and pedal adjust wont move...there is a clicking sound coming from a black box under seat but no function
it does not appear that the driver seat or adjustable pedal share anything in common
furthermore, the sound you hear clicking may be the actual seat motor trying to work, but lets do a quick test
try to move the seat up/down, forward/back and any combination. If while holding the button in said position and you consistently hear the clicking sound that follow the sound and touch the motor under your seat. If you feel the "clicking" then your seat motor is bound or siezed and will need repair.
if instead you just hear one click then you might be experiencing a relay problem
As for the pedal adjustment... have you checked fuse #109 (30A) @ the CJB (Central Junction Box) behind the right kick panel?
Apr 10, 2010 | 2005 Lincoln Navigator
Car starts but shuts off after 15 seconds
Here is the link to get the manual. http://www.caralarm.com/manuals/MARS/MARS-22.pdf
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
Feb 10, 2010 | Omega MARS-22 Remote Vehicle Starter with...
I drove my Jeep to school and after class it wouldn't start. It cranks really good but sounds like it's not getting fuel. How can I check to see if the fuel sending unit in the tank is working or check the...
get somone to turn the key to the on position while you listen for the pump in the fuel tank usualy a whiz or wineing sound if you hear it the you good if you dont hear it when turning the key to the on off on position "the positoin before you crank the engine" then try hitting the tank with a stick or hammer a few times it could be stuck. if this works then park it when you get home, until you get a new pump.
you can check the pump relay usually under the hood in a black box marked as fues or somting like that the relays are marked on the bottom of the lid. if you dont hear clicking with key to on off position then try switch aound with a similar relay in the same junction box
Feb 08, 2010 | Jeep Grand Cherokee Cars & Trucks
I turn the car on and it runs fine volt meter reads in the positive, temp of the vehicle is fine and everything reads fine. The only thing blinking is the Change oil sign and it has just begun to flash....
you have a underhood fuse box. in that box you mayhave circut breakers. they click when going off and some have a rest time 15 minutes. check all of those and make sure no underhood , truck wires are rubbing on something causing a sort.
Dec 31, 2009 | 2002 GMC Sierra 2500HD
Itouch black screen and wont turn on
I had the same problem. I pressed the power button and the home button at the same time for about 10 seconds and then the home page showed up.
Aug 05, 2008 | Audio Players & Recorders
Turn Table
The home page for Cosley =
"http://www.crosleyradio.com/prods/cr78.html"
Contact and support links are near the bottom of the page (RHS)
Contact them and ask them if they have a user manual in PDF
format for download.
Martin
Please rate my answers.
Jul 27, 2008 | Crosley CR78 CD Shelf System
Car Audio & Video Logo
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
