Question about Sharp 70" Aquos LED Smart TV - LC70LE640U
Sharp aquos tv input won't change - Sharp 70" Aquos LED Smart TV - LC70LE640U
  • 71 Answers
SOURCE: Sharp Aquos Color Variations
Put the OPC off and check the conection for Pb signal.
Posted on Dec 06, 2007
dsacco86
  • 1077 Answers
SOURCE: Sharp Aquos Resolution
According to the manual for the TV, you need to change the resolution on the computer itself first.
The computer resolution should be 1024 X 768 at 60Hz or 1360 X 768 at 60Hz.
After the adjustment made on the laptop, then try the resolution change option.
Posted on Jun 12, 2009
  • 441 Answers
SOURCE: I need to change resolution on my Sharp Aquos
it is most likley the setting on the cablr/sat box
Posted on Jul 24, 2009
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
satavlad
  • 405 Answers
SOURCE: no input selection availiable on sharp aquos lcd tv
You have to come back to EZ SETUP and complete the setup procedure. Press MENU>SETUP>EZ SETUP.
Posted on Dec 29, 2009
My sharp aquos won't power on
CHANGE IC202 WITH TL431 OR TRY PUSH INPUT AND VOLUME DOWN THEN PLUG THE POWER UNTIL THE GREEN LIGHT START ,,, WHEN IT START PUSH VOL DOWN AND CHANNEL DOWN AT THE SAME TIME AND PLAY WITH THE SETTING
Apr 20, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
My sharp aquos 52" power button is blinking blue and won't come on.
power supply which can be ruled out or confirmed with voltage checks on that board.
Aug 31, 2012 | Sharp AQUOS 52" Flat-Panel LCD HDTV
My Sharp Aquos LCD TV 40E77U is working on the analog input but won't detect HDMI inputs?
This set MAY require or have available a software upgrade for this issue.
Contact Sharp to see if they have it or if this is an issue in their database that is common.
Mar 20, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Bose home theater system and a Sharp Aquos tv. I'm trying to hook up the Bose dvd directly to the tv. Problem - tv only has HDMI input capability and Bose does not. I purchased a HDMI convert
Hello
You haven't given any description about the converter you bought. Please send me the model number and brand name of the converter did you bought. OK.
Nov 18, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
How do you access inputs 1,2,3,? They are locked-out or skipped. Aquos Sharp TV
Often times this happens with TV's when there is nothing plugged into the input. Try plugging a device into the 1,2, or 3 input and then check if you can switch to it. The TV has the ability to read whether or not something is attached so if there is not, it won't give you the option to switch to this input.
Jul 24, 2011 | Sharp Televison & Video
Can't find the DVI-D hookup on our sharp aquos 52' tv
The Sharp Aquos 52 inch model LC-52D62U doesn't seem to have a DVI-D input. Make sure your model is designed with a DVI-D input. If you provide me with your model # I'd be more than happy to find out specifically for that model.
Jul 18, 2011 | Sharp Televison & Video
The demo mode apears every 30 minutes. I can't really stand it. How can I shut it doen for ever? Sharp aquos LED 40"
I'm not certain of the specific model number of your set, but this should be the same for all Sharp Aquos models.
First, navigate to TV input, and select menu
Next, enter setup and select, "ez setup"
In the ez setup menu, select "home", not "store", for television location.
This should turn off the demo mode and solve your issue.
Jun 10, 2011 | Sharp AQUOS LC-40C32U 32 in. LCD TV
My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp 70" Aquos LED Smart TV - LC70LE640U Logo
44 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
