Question about Haier HTQ18JABRSS Top Freezer Refrigerator
Haier fridge leaking water - Haier HTQ18JABRSS Top Freezer Refrigerator
4 Suggested Answers
  • 159 Answers
SOURCE: Haier Refridgerator
Your freezr drain is blocked or frozen. What you need to do is remove the ice rack then in the front of the freezer you will see 2 or 3 plastic plugs on the freezer floor remove the plugs and there might aso be some 1/4 inch screws farther in on the freezer floor. also remove the back of the back of the freezr and then lift out the bottom floor. under the evaporator you will see a lot of ice or just fod blocing the drain. I will bet its all full of ice. Carefully remove all the ice and hot water will help once you get the buk of it out. The hot water will make sure the drain is not blocked with ice. Once its al clear install in the reverse order and things should be good. This is a common problem with this unit.Good Luck
Posted on Jul 12, 2007
  • 833 Answers
SOURCE: Leaking water INTO fridge
Your problem is a blocked drain which prevents melt water from the defrost from getting out. You'll have to expose the coils and find the drain hole. It is possible that the problem can be on the other end of the hose...where it hits the evaporation pan in the bottom of the unit.
Posted on Jan 22, 2008
Sea Breeze
  • 4655 Answers
SOURCE: RRTG18PABB HAIER LEAKING WATER FROM FREEZER TO FRIDGE PORTION
Make sure it is not the fill tube from the ice maker first. Yes I would think ice or sludge is blocking the defrost drain and causing water to flow into freezer and then to the floor. Here is more about leaking refrigerators=> Leaking Refrigerators
Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
How to Fix Fridge Water Leak
Posted on Dec 05, 2012
My haier refrigerator light is blinking
Reset your Refrigerator Filter Indicator Light Water Filter For Fridge
You need to find out the reset procedure for the Haier unit. And change the water filter.
How is your French? At least this is a video and you can see what the guy is doing.
haier How to reset the filter icon FR
Oct 21, 2017 | Haier Refrigerators
Dec 05, 2012 | Haier RRTG18PABB (207 cu ft) Refrigerator
Haier WDNS401VS manual
My haier does not dispense cold water its dispense warm water
Nov 25, 2011 | Haier Water Dispenser w Fridge...
I have a Haier HRD-211 HP5 direct cool fridge. Last couple of days the air around the fridge is smelling like spoiled or sour milk - no smell inside or on the body of the refrigerator and cooling is fine...
Check the defrost water evaporator tray located inside the bottom grille. You probably will find a disgusting mess. Remove the tray and scrub it clean to resolve the problem. While you are cleaning up, check the tube that directs defrost water into the tray. It may be clogged.
Jul 02, 2017 | Haier Refrigerators
WATER DISPENSER JUST DRIPS.MAKES VERY LITTLE ICE AND WHEN IT DOES IT IS MELTED INTO A SHEET OF ICE .IT NOW NEEDS FILTER CHANGR, BUT THIS PROBLEM BEGAN ABOUT 1 MONTH AFTER PURCHASE
Probably the solenoid is leaking(electronic water valve located in the back of the fridge that opens when ice maker calls for water) and the water freezes up inside the filling tube to the ice maker and when the solenoid opens water doesn't go through.
Sep 02, 2009 | Haier Refrigerators
Our Haier refrigerator is leaking water below the freezer. It is coming from only one side. How to fix?
The reason for your fridge to leak water on floor sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a boaster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear.
Thank you for contacting Fixya.com
Aug 11, 2009 | Haier Refrigerators
My fridge will not cool. I hear it running non stop, there is a trickling water sound, but hardly cools. I had it set at "4" for over 24 hours, and then moved it to the max. At both settings, the freezer...
You have a refrigerant leak sorry I suggest to get a new one because they are not wort to repair then unless you happen to do that for a living. will cost you more to fixed than the fridge wort. :(
Jun 10, 2009 | Haier HSB03 Compact Refrigerator
Freezer Noise. Water leaking in Fridge.
you need a repair man.you have a defrost problem and your drain is clogged.
Mar 09, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Jan 21, 2008 | Haier HTQ18JABRSS Top Freezer Refrigerator
Haier HTQ18JABRSS Top Freezer Refrigerator Logo
48 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
