Question about Honeywell Programmable Thermostat Heater
I want to replace a Marley MD26 Thermostat but what is the digital equivalent?
Marley md26
A standard 'Geyser' (water heater) timer is quite capable of controlling the two heaters.
Nov 22, 2013 | Heating & Cooling
How do i wire a 240volt hydronic base board heater and thermastat
I need a control knob for my Marley electric wall heater model#fzl3004b
Dec 17, 2012 | Marley Electric Hydronic Baseboard Heater,...
Marley IUH524 Heats but no fan
high limit not working , not letting fan come on try jumping it out to see if it works
Feb 11, 2012 | Marley IUH524 Electric Heater
Hello Fixya Guru ! I am in the process of installing several Marley PLF series 2000 watt/ 240 volt electric "Hydronic" baseboard heaters. I am using 10/3 bx with a 30amp breaker. To my...
You are correct that these heaters use a two-wire 240 volt supply, and the neutral is not needed.
2000 watts = 240 volt x Amps ==> Amps = 8.3 amps
30 amps x .8 safety factor = 24 amps
24 amps / 8.3 amps = 2.9 heaters per 30 amp breaker (3 heaters should be okay)
More info, pls let me know.
Charlie
P.S. Where does the 2880-watt number come from ?
P.P.S. There has to be a ground bus-bar in the panel -- if it's a main panel (not a sub-panel) the ground buss and the neutral buss are connected in the panel. Could you clarify what you have in the panel.
Jan 11, 2011 | Fahrenheat Electric Convector Baseboard...
Looking for a wiring diagram for a fahrenhear model FTA2a
I found this VERY helpful step-by-step pictorial direct from Marley (manufacturers of the heater and thermostat).
Worked like a charm for me.
www.marleymeh.com/en/assets/pdf/F2500wiring.pdf
Nov 21, 2010 | Fahrenheat Built-In Baseboard Thermostat...
I have a marley elect wall heater the little motor is shot
These motors are now made by Century electric motor Co. -who bought A.O. Smith, who bought UPPCO motor company.
The parts can also be requested Marley EP still manufactures a similar heater
HOW TO ORDER REPAIR PARTS
In order to obtain any needed repair or replacement
parts, warranty service or technical information, please
contact Marley Engineered Products Service Center tollfree
by calling 1-800-642-HEAT.
When ordering repair parts, always give the information
listed as follows:
1. The Model Number
2. The Part Description
3. Date of Manufacture
Dec 11, 2008 | Marley PJ1257 Heater
Marley md26 line voltage thermostat
The Black Wires from the md26 are your load(the heater) and the red lines are your line(power). The lines are also paired up on the thermostat with a red and black on the left and are red and black on the right. In the actual heater connect the black to the black wire and the white to the white and connect the grounds. In the thermostat connect the black from the heater to left side black( remember there are pairs left(black, red) right (black, red) and the white to the right side black connect the black from your power to the left side red and the white from your power to the right side red. Should be ready to go.
Nov 08, 2008 | Marley Electric Hydronic Baseboard Heater,...
Heating & Cooling Logo
64 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
