Question about Frigidaire GLTF2940ES Front Load Washer
Door is closed, and washer still says its open
  • Official Brand Answer
  • 4,342 Answers
Hello leximoma - I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately 2 minutes and turn on the washer. Select a normal cycle and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. Contact a professional to move forward accurately.
Posted on Apr 23, 2013
Codes f26 and then f27 for maytag model MFH 0710
F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start. unsure of f27
Dec 23, 2016 | Maytag Washing Machines
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Kenmore Elite HE5t washer - Door is hard to open and close
It may be sprung in the hinge or there may be a tiny piece of debris causeing the door to hang when being opened or closed.
Jun 03, 2012 | Kenmore Elite HE5t Washer
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
Washer says f26 and won`t spin the clothes out. is there anything i can do?
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cannot get washer door to open.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
27 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
