Not coying replaced toner, goes through the printing process but does not produce a copy
    Problem Solver:
  • 14 Answers
Electrical noise / spark on one side of any corona unit or charging/transfer corona unit with tungsten wire. Replace the wire or put insulation on both rear or front blocks attach with charge wire.
Posted on Apr 24, 2013
4 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: printing blank pages
open the door and look for a unit that has some small hair like wires, are they intact or is one missing /broken???
Posted on Oct 30, 2008
iservice
  • 318 Answers
SOURCE: copies blank
This is normally the corrona wire that needs to be replaced in the transfer unit and drum unit.
Posted on Sep 15, 2009
O RICH
  • 26 Answers
SOURCE: new cartridge and prints very light
Ithink you might need a developer change.
Posted on May 05, 2010
LIGHT COPIES WITH A NEW TONER CARTRIAGE
Was the toner sign on when u replace the toner bottle?
Dec 02, 2013 | Savin Compatible Copier Toner Black For...
Sharp 1641cs - Dark/black page after replacing drum & toner
Hi you have not said the toner type you replaced with though that will give not completely black copy. The problem may have been the drum unit installation. Make sure the charge unit over the drum service is present ie the one with a mesh wire like grid. If present, clean it or wipe with a soft clean and dry cloth. Clean the saw-tooth like metal plate inside that unit by slow blowing and make sure no toner particles are there. Finally screw the unit properly on the drum unit and your problem is solved.
Jan 11, 2013 | Sharp AL-1641CS All-In-One Laser Printer
New cartridge and prints very light
May 04, 2010 | Minolta bizhub 200 Copier
How many copies should a copier produce before changing a drum
I bought a km1620 copier. but copied only A4 size paper. No longer paper can not print except A4 paper. how can I change copying system. And how can I count copy. pls. mail me.
mizan
Jun 12, 2009 | Kyocera Copystar CS-1620 Black and White...
Noises when printing copies
Take the new cart. out and reinstall the old cart. Does the noise disappear? I would tap and shake the toner cart. BUT BE CAREFULL, the cart is ready to spill toner. On the box and in the instructions it tells you, or should, that you must shake and tap the outside of the cart. This is due to settling and the toner maybe packed. By tapping and shaking it will feel the toner. If the toner is packed it will put undue pressure on the augers inside the toner cart. and cause a grinding noise. If after tapping and shaking, reinstall the new cart. and check. If everything is ok -- great. If the noise remains contact the company your purchased the cart. from and ask for a replacement. These cart. are mass produced and mostly reused ( refurbed). Parts wear now and they do not replace the inside parts, they just repack with toner and seal.
Dec 25, 2008 | Sharp AL 1631 Copier
Only prints once ?? Toshiba BD-3810
When the toner is very low the copier is programmed to only print one copy.
Fill the toner and it should go back to normal
Dec 05, 2008 | Office Equipment & Supplies
Light (faded) print
What's the copy count on the machine?  It could be resolved by adding developer to the unit.
Nov 02, 2008 | Ricoh Aficio 450 Copier
Printing blank pages
Oct 30, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
Canon6050 toner recycling
I have glanced at and passed by your question several times, and finally cannot resist the urge to answer. Canon copiers are unique in the fact that they are " monocomponent". This probably means nothing to the average person. But suffice it to say,the"waste toner" you speak of is primarily drum polish and paper dust, neither of which is very good at producing a decent copy. In fact, ANY percentage of waste toner introduced into the Canon copy process is a recipe for disaster. I primarily say this because at some point you will have to replace the development unit (or have some serious service) and probably replace the drum ($1000) if you continue. I am not a Canon employee but have worked on Canon equipment for over 20 years. I merely wish to help. I would be hard pressed to see how you can save enough money up front to cover the back end costs.
Apr 07, 2008 | Canon NP 6050 Copier
Laser Printer Problem
Do a panic stop while the machine is in the middle of processing copy. Remove the imaging unit and lift the drum cover to view the surface of the drum. If the image produced on the drum is OK (ie.no ghost image) then focus your attention on the hot rollers just before the paper exit. Otherwise your problem is the imaging unit.
Dec 31, 2007 | Office Equipment & Supplies
16 people viewed this question
jasbo
jasbo
