Question about Husqvarna 24HP 54" Yard Tractor ()
After a week of setting, my yth24v54 (with 29 hours) takes10sec + to start - after 2 or more weeks it will crank and crank until the battery is down and I have to jump it or until I put a shot of starter fluid in the intake. Has anyone else experienced this? Any suggestions? (btw, I also have a 20yr Murrary Ultra Widebody that starts promptly EVERY time. Sheesh)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
1. Check the choke and check the spark plugs and plug gaps.
2. Check that you're not getting oil or gas draining into the engine while its stored.
Posted on Nov 18, 2013
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: 4 years old, replaced original battery last year
Hi, W/D here.
Check the battery terminals for corrosion, and make sure that the connections are shiny, bright and tight. Follow the cables from the battery, and disconnect and clean each terminal as needed. Check the voltage in the battery as it sits. If you do not have a volt meter, any auto parts store can check it for you. They can also put a load test on it to determine if the battery is capable of taking a charge. It sounds like you had just enough battery to start the mower, but not enough to sustain it, but the problem may be elsewhere. You cannot move further until the battery is proven good, or replaced.
Provided that you have a good battery and all connections are secured and cleaned, with the key on, try to bypass the solenoid with a heavy insulated wire jumper between the large terminals. If the starter turns over, the solenoid or the start switch is bad. You can test the start switch for continuity with a meter, or a cheap automotive tester.
If all of the above checks out, the problem lies in the charging system.
Best regards, and please post back with your findings, --W/D--
Posted on Mar 18, 2011
1978 Suzuki GS1000 Battery Dies Out After a Week
Either there is a short somewhere or your starter is dragging.
Jun 23, 2017 | Motorcycles
Car starts and runs perfectly until engine reaches operating temp then loses power starts poping spitting firing all over the place until it dies. then it wont start again for 2-3 hours until engine cools...
Possibly the catalytic is plugged. How to know? Has this been getting worse over short time period week or two? Check out at exhaust shop..
Good luck.
Aug 18, 2011 | 1997 Chrysler Sebring
Problem #1. On model #DT300 the instructions under Set Time of Day # 3 does not change the day. The only place I can get the day/s to change is under the programming. What is wrong with it. I have...
Thank you for very clear question, and timer identification.
1) I don't have repair for defective timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
2) Choose DT300 format
#3 says to press-and-hold CLOCK button until display shows 24H or 12H
Then release CLOCK button.
Next press HOUR button to select either 12H or 24H
This lets you choose am-pm format -or- choose military-time format where 11pm is 23
3) Set current time
Press-and-hold CLOCK button throughout whole current time setting.
Do not release CLOCK button until current time settings are finished.
Next, press HOUR button, and then MINUTE button, and then DAYS button until current hour, minute and day display.
If this step does not work, then timer has gone bad.
Replace with locally available Utilitec 155671 from Lowes or Westek TE06WHB from Target
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
4) How to set DT300 timer program for full week of operation.
Each program requires you to set program 1 ON time and program 1 OFF time
Be careful to avoid program conflicts and overlaps so timer works as expected.
For program 1 ON time, you press PROGRAM button until 1 and ON display.
Release Program button.
Then select hour, minute and days. In this case you want all days of week, so you keep pressing DAYs button until whole week displays: Mo Tu We Th Fr Sa Su
Then you set program 1 OFF time, you press PROGRAM button again until 1 and OFF display.
If you set ON time for all days of week, and OFF time for Tu Tuesday, then timer will not work correctly.
5) Read manual and add a comment for additional help
Aug 18, 2011 | Hardware & Accessories
Gardenline - garden tap timer.I can't work out the instructions- the timer won't work . Please help and give me an easy guide line to the instructions.
1. Press PROG
2. Press up/down arrows to select the programme you wish to set (16 spaces are available)
3. Press SET
4. Press up/down arrows to set the hour at which watering is to start
5. Press SET to store the hour
6. Press up/down arrows to set the minutes at which watering is to start
7. Press SET to store the minutes
8. Press up/down arrows to set the number of hours over which watering is to take place (0-9)
9. Press SET to store the hours
10. Press up/down arrows to set the number of minutes over which watering is to take place (0-59)
11. Press SET to store the minutes
12. Press up/down arrows to select which days of the week watering is to take place (2nd means every second day, 3rd means every third day). When the required day of week is displayed press SET to store that day. The next day of the week will then be displayed and Set can again be used to store that day. Carry on throughout the seven days of the week as required.
13. Press the clock symbol to store the programme.
Mar 07, 2011 | Hardware & Accessories
I have a IIIWoods timer #59203WV and have trouble programming it to turn on and off exterior lights. Thanks for your response.
Manual:
http://waterheatertimer.org/pdf/Woods-59203.pdf
59203 plug-in timer: your outdoor lights have to plug into side of timer.
If you want a timer to replace outdoor light switch: buy in-wall timer Aube T1032 or Lowes sells Utilitec 0192773.
http://waterheatertimer.org/Programmable.html#Aube
Add a comment for more help with in-wall.
Here are instructions for 59203 plug-in timer:
Plug in the timer until battery is charged.
Unplug timer so you can program easily.
Press R reset button with paper clip to clear.
Set the time of day:
Press and hold clock button
Press hour button until current hour shows
Press minute button until current minute shows
Press day button until current day shows.
Release clock button
Program review:
Write out ON-off schedule showing hours minutes and days
For example: timer turns ON 6:00 pm all days of week.
Timer turns OFF 1:00 am all days of week.
First step: Set program1 ON > hour, minute, and day.
Next step: Set program1 OFF > hour, minute, and day
If needed, go to next step: Set program2 ON > hour, minute, and day
Next: Set program2 OFF > hour, minute, and day
How to program timer for ON at 6:00 pm and OFF at 1:00 am all days of week:
Step 1: Press PROGRAM button until display shows 1 ON (this is program1 ON)
Press hour button until 6 pm shows
Press minute button until :00 shows
Press day button until all days of week show (MO TU WE TH FR SA SU)
Step 2: Press PROGRAM button until display shows 1 OFF (this is program1 OFF)
Press hour button until 1 am shows
If you want to set another program, you will repeat same steps for program2
Press PROGRAM button until display shows 2 ON
If you are done programming, press clock button
Press ON/AUTO/OFF button until AUTO displays
Nov 13, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
My solar clock needs setting. I set it back an
1) Pull the batteries and replace them, or gently insert a straightened paper clip into the "reset" hole in the back of the clock. The clock will beep.
2) Press the "receive" button" so the clock sets itself. The default time zone will be "EA".
3) Press the "adjust" button untill the time zone is showing (rather than the day-of-the-week).
4) Press and HOLD the "set" button down untill the hours digits start to flash2.gif.
5) Now press the "set" button again six times. The time zone characters will flash.
6) Press the "adjust" button untill your time zone appears.
7) Press the "mode" button to return the clock to normal operation.
8) Press the "adjust" button to display the day-of-week.
Nov 09, 2009 | SkyScan 86742 Digital Atomic Wall Clock
2002 Taurus starts & then dies. After an hour, it is OK for weeks
put a volt meter on the battery when you get the problem to occur, I have run into intermittent problems and found that when cranking the battery voltage drops below 9 volts and when the voltage drops below 9 the pcm powertrain control module does not know what to do and will cause the problem you are talking about, if it drops below 9 volts check and clean power and ground connections and have you battery tested, your local autozone will test it for free, and most likely your battery is going bad. and auto zone installs batteries for free also.
Sep 18, 2009 | Ford Taurus Cars & Trucks
How do I set time zone
My 86742 batteries took a dump after many years so I ended up with the same problem. It took me about an hour to figure it out, but here is the solution:
4) Press and HOLD the "set" button down untill the hours digits start to flash.
Do you think they could have made it any MORE complicated?
May 18, 2009 | SkyScan 86742 Digital Atomic Wall Clock
03 Altima ( 2.5 ) crank position sensor - retired ASE Master Teck
does the check engine light flash or is it on when the car misfires?? Bythe way, Nissan has a new program available for your ECM/computer for the long cranking condition. Check with your local NIssan dealer. Also spark plugs are rated for 105K, You have 110K on it. Check your plugs and make sure, that you use NGK if they need to be replaced. Also, look at your overflow bottle. If its down, top it off to FULL mark and monitor the level for few days. See if it goes down in like a week. I have seen some headgasket problems, where the coolant gets into the cylinders and drown the spark plug, causing a misfire. Let me know what you find. Lets get to the bottom of this and lets fix it.
Aug 27, 2008 | 2000 Nissan Altima
Husqvarna 24HP 54" Yard Tractor () Logo
83 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
