Question about Exercise & Fitness
There is a noisy sound coming out of the rear belt section like metal parts breaking or banging.
    Problem Solver:
  • 5 Answers
The bearings have gone in it mate 100% sure, try contacting the manufacture and source some new ones
Posted on Apr 28, 2013
Machine bangs when on spin
Washing machines are just metal drums spinning in an axis from a motor with a belt (like how your vacuum spins the front brush). The pulleys to guide the bey can wear out. Open up machine's back and you'll likely see the problem. (have a flash light)
Here's videos and parts. Check elsewhere as you can likely find cheaper but they aren't terrible for prices.
Kind Regards,
Scott
How to Repair Your Washing Machine
How to Fix Noisy Washer
Feb 11, 2015 | Washing Machines
My toyota corolla2005 rear right side wheel scrubing th tire when breaks
I would first check the break parts on that tire. remove the tire...making sure you take the precaution to chock the other tires and use an appropriate jack and proceed to removing the tire. Once the tire is down look at the the components for wear. Some break pads come equipped with a metal blade that once the pad wears out this metal plate comes in contact with the rotar or drum and makes a high pitch metal grind sound. This would be the indicator to change your pads and may possibly need to resurface your rotars or drums to spec. Let me know if that's what it was. GE.
Nov 07, 2013 | 2005 Toyota Corolla CE
Loud squeaking.
To me, I think I am hearing a dry bearing.
However, an old worn out belt can make the same sound!
You could take off the belt and try spinning the pulleys to hear which is noisy, or you could use a mechanic's stethoscope to find out.
A mechanic's stethoscope is a really long screwdriver or metal rod about 2 or 3 feet long that they put on different parts (put the handle end to your ear) to hear the noise each part is making.
If your belt is good, try the alternator bearings.
There is also an idler pulley or maybe 2 that could be noisy.
Be blessed.
Feb 07, 2013 | Cars & Trucks
Washer gets noisy and bangs around or out of balance during spin cycle
OK, lets see if I can help you. First, remove the 2 screws that are on the rear of the top panel, slide the panel back about 1/2 inch and lift the top off. Look at the rear bearings and any other visible signs of malfunction. Also, be sure to check the suspension for anything that may be loose. Post your findings back to me.
Regards,
Richard Roth
http://appliancecafe.com
Nov 12, 2012 | Maytag MAH2400AWW 2.4 cu. ft. Compact...
IN A 1993 BONNEVILLE SHOULD THE HORMIC BALANCER SPIN PART WAY AROUND WITH THE BELT OFF? AND WHY WHEN IT'S RUNNING DOES IT MAKE A BANGING SOUND
You should change the balancer .They should NOT spin . The banging sound is the engine not balanced.
If left too long you can break crankshafts
Apr 05, 2010 | 1997 Pontiac Bonneville
Water in trunk lid Popping in front end springs when going over speed break squeaks sound like it is coming out of the car
the only fix for the water in the trunk is to replace the trunk seal, folowing EXACTLY, the install directions. The water actually gets it's way in at the rear most vertical sections of the weather stripping. new strip needs CORRECT sealer, buy from dealer only.
There is an improved design being produced now.
COMPLETELY clean all old sealer, a tough but necessary job...
Brake squeaks repair involves machanic in a tube on the METAL to METAL parts of the back of your pad. Ideally, you would resurface the rotors, or look at replacement, as that may cost less...
Buy top quality parts only for these brakes.
Doc
Sep 25, 2009 | 2008 Cadillac STS
In spin cycle, there is a loud metal on metal sound. could it be a bearing going out? the machine still spins but much slower, and the banging sound occurs in one place every revolution during the spin...
Hi
Remove the drum belt, and spin drum by hand.
If it feels rough, or it is noisy, then drum bearigs have failed.
Please rate my solution.
thanks.
Jul 24, 2009 | Whirlpool Washing Machines
Banging Sound from Rear of 2001 Explorer
check your sway bar link pins they probably are broken in the back .
Apr 16, 2009 | 2001 Ford Explorer
WFW8300SW01 rear bearing noisy
Go to sear.com and then to the parts section. Type in your model # and there will be a list of sub compenents to the parts. Click on the tub section and the bearing (rear tub assembly) will be there.
Dec 10, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Hotpoint VTD60 is making a loud metal to metal scraping sound regardless of load capacity. Should this be so on a machine that is less than two years old. Thanks Geoff
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://www.repairclinic.com/0088_8_1.asp#Level1_7
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 01, 2008 | Dryers
Exercise & Fitness Logo
66 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
