Question about Ryobi Garden
Spark plug gap ryobi rlt 30
Attach cable to spark plug
SOURCE: have a ryobi rlt 30 cd and the spool wont spin fast enough
hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
Posted on Aug 15, 2009
moretons
  • 155 Answers
SOURCE: spark plug gap
Normally 25 thou
Posted on Sep 10, 2009
  • 496 Answers
SOURCE: what is the spark plug size and gap?
The "Champion" spark plug for your item is #RDJ7Y
Or another brand, "NGK" #BPMR6F/130-769
You can set the gap to .020"
Hope this helps...
Posted on Sep 25, 2009
bbreton
  • 437 Answers
SOURCE: I have a Ryobi RLT 30CESA with the strimmer
I would not put a brushcutter blade on this unit. The curved shaft quik disconnect may not hold up to the shock torque created by the brushblade. It may damage the drive shaft since it is a curved shaft quik disconnect model. You may have to purchase a straight shaft trimmer to get that job done.
Posted on Oct 03, 2009
  • 78 Answers
SOURCE: Ryobi bush cutter, what is the spark plug gap
Use a wire plug gauge or disk and Set at 0025,
Posted on Oct 19, 2009
I have a 2 stroke ryobi brushcutter. No spark at a new plug. Ohm reading is 1.2 on the secondary coil,and 3.91 on the primary. Are these readings acceptable ?
Check the lead going from the ignition module to the plug. some are sealed and moulded, others the cable just screws onto a spike on the module. Then check the boot end, if it can be removed, make sure there is a good connection to the inner wire core in the cable. I cant find anywhere that gives you ohm readings of what the output should be tho.
Apr 25, 2016 | Ryobi Garden
Ryobi rlt 30 cesa petrol strimmer will not start
Keith you have got to make sure the gap is right between the coil and the magnetic flywheel. Use a buisness card to set the gap and make sure the coil is on the right way.
May 14, 2014 | Garden
What is the spark plug gap for a Ryobi string trimmer model RY30550 ?
No need to gap from a new spark plug unless the plug was dropped on the electrode.
May 02, 2014 | Ryobi Garden
What is the spark plug gap for the ryobi 320vbr blower
Hi and welcome to FixYa, I am Kelly.
The spark Plug Gap is 0.030. Any original or aftermarket spark plug for this unit is pre-set to 0.030. Unless you dropped the replacement plug it should be fine. All Ryobi engines 2 and 4 cycle have a 0.030 spark plug gap.
Thanks for choosing FixYa,
Kelly
May 07, 2011 | Garden
Ryobi RLT30CET difficulty starting and when running doesn't power up sufficiently to do job. Has 50:1 unleaded fuel The machine was bought 18 July 2009
Hi...Ryobi RLT-30CET...I have a newish strimmer which I dropped 2 ft. Changed the spark plug...as it seemed to have no spark. Now I think its flooded. How do I sort the flooding problem. and are there delicate parts that could break? many thanks...Phil
May 15, 2010 | Ryobi Garden
I have no spark on my ryobi 990r. i have replaced sparkplug. i have checked and have plenty of fuel
make sure the gap on the plug isnot to wide other wise u will not get any spark or just a weak spark
May 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have no spark on my Ryobi Brush Cutter. Replaced spark plug but still no spark.
If the spark plug you have put in has the correct gap then u will next have to check or change the HT lead Change it if no spark is showing
Apr 20, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Have a ryobi rlt 30 cd and the spool wont spin fast enough
Apr 21, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
18 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
