Instruction manual for Loth-X othello turntable needed
I bought the above record deck second hand, but no user manual has come with it. I would value any advice about setup, etc. for this deck. Best of all, where I could get hold of a manual. Also, I need a strobe disc to set the speed of the deck.
djproaudio
  • 515 Answers
SOURCE: Technics sl-dz1200
Here is the direct link to the manual - FREE!
You'll need Adobe Acrobat to view it.
Enjoy!
- DJPROLAB
Posted on Feb 24, 2008
djproaudio
  • 515 Answers
SOURCE: Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
  • 92 Answers
SOURCE: Turntable does not rotate when switched 'on'.
K, I'm not familiar with that particular stereo unit but there were a lot of stereos from years gone past that used a turntable made by BSR. When you activate the switch to start the turntable listen closely to the record platter for a hum or possibly the sound of a motor turning (they're quite quiet). Is the switch lever you pull rectangular made of black plastic, you pull it towards you one click to start the record and pull it one step further (spring loaded) to make the tone arm lift from the record automatically? Just want to make sure I'm talking about the right turntable before we continue.
Posted on Oct 11, 2008
  • 3 Answers
SOURCE: can't get sound from turntable to pc speakers
go to control panel, sound audio devices, hardware , USB Audio Device Properies, Properties, click the + next to Audio Devices USB Audio Device Properties, make sure that is highlighted, click do not map through this device, apply restart program. Under device properties make sure sound playback is set to default driver ie: Realteck Ac97 audio etc... Hope this helps
Posted on Sep 23, 2009
Throw it from a second story window then smash it with a sledgehammer. That's what I plan to do with mine.
Posted on Jun 03, 2010
I bought a second hand Elna 1000 sewing machine but there is no user or instruction manual
The only manual I find (several places) is 15 pages, and $10 (cheapest) for a pdf download:
Elna 1000 Instruction Manual
Mar 16, 2015 | Elna Sewing Machines
How do I manually adjust this speed on this turntable. I timed it with a stopwatch and it's playing my LP's exactly 1 second too fast than the CD version of the same LP. Thanks.
Without technical equipment it would be near impossible to get the speed down to the level of a CD. A lot depends on the belt, how much it has been used, for example a new belt might help! The motor of the deck could have a speed setting on it, but even so it would be on the bottom of the deck and you would have to adjust while you were under the turntable. Like being under a car!
Some have speed presets, again under the deck, often covered with a label. Others will have them on the PC board of the deck's power supply section.
On the whole that's one of the flaws with records and decks, they are not as good as CD's.
Nov 21, 2010 | Sony PS-LX250H Turntable
1210 mk5 poor sound
If the cartridge is good and your wiring is good. Then it's either got to be a fault on your amp, or there is a pre-amp in the deck itself faulty. Double check that the amp is working, amps have a pre-amp for record decks, they cause trouble a lot.
If you touch the wires that connect to the cartridge, you should get a buzz on either channel (remove them from the cartridge first). If you don't get a decent buzz, and you know that the amp is working fine, then there's something inside the deck causing the problem. In which case take the bottom off and take a look inside.
Feb 11, 2010 | Technics SL-1210MK5 Turntable
How do i fix my turntable when the output is working on the right hand side but not the left
First - Has the cartridge failed, or has a wire become lose to it? Have you checked the cable comming from deck?
If you have or none of these gives solves the problem, then try reversing the leads on the cartridge so the good ouput gets the missing channel. If you still can't hear it then there's a electronic fault on the left hand channel pre-amp inside the record deck.
Oct 19, 2009 | Stanton T.120 Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Deck fades out when i bring the second deck in (records I mean)
are you running phono pre amps ? are you running pre amps to each deck or one for both decks , if you are running pre amps maybe the power supply is not sufficient to run two decks anymore [ possibly damaged ] but it sounds like a power delivery failure to me . hope this helps
May 24, 2009 | Technics SL-1210 Turntable
Instruction manual for ministry of sound mixing decks
What are Ministry of Sound mixing decks? I am familiar with MOS, but was not aware they manufactured mixing decks?
Are you connecting these to a DJ mixer, or a Home Receiver?
If it's going through a home receiver, make sure you have them connected to the PHONO input on your receiver. If your receiver does not have a phono input, and you are connecting to the LINE IN or AUX IN section on the rear, you will not hear much. Most turntables require a pre-amplified signal, and only the PHONO input has this option. So, you will need to purchase a PHONO PRE-AMP, and connect your turntable to it, then connect the PHONO pre-amp to the LINE IN.
If you are connecting to a DJ mixer... same thing. Make sure you have them connected to the PHONO INPUT on the mixer. If you still don't get anything, then there might be something wrong with your mixer.
If you could clarify you exact set up, and the EXACT models, we can help you better.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 27, 2008 | Technics SL-1210 Turntable
How do I set up a record for 45 speed?
You place it over the turntable spindle if you need to use it. Many 45s have a standard 6mm spindle hole so you do not need to.
Dec 25, 2008 | Numark PT01 Turntable
SONY RDR GX120
Download Sony RDR-GX120 user manual here.
Regards,
Sep 09, 2008 | Televison & Video
187 people viewed this question
 Grubhead
Grubhead
