Question about HP Compaq Evo D310 PC Desktop
Cannot boot from cd rom
Currently has six Xp, but I'm looking to 'Darin boot n nook' hard drive then install a new win 7, problem is I cannot get it to boot from cd rom, even though bios order is correct, also tried to get it to boot from USB same issue, this applies to weather I have win Xp recovery disk, or the boot and nook cd in drive. It just will not boot from cd rom. Can anybody help me out ...would be very much appreciated
    Brigadier General:
  • HP Master
  • 3,400 Answers
Check out cd/dvd-writer.if any dust partikels clean with caned air.
Posted on Apr 22, 2013
  • 1 more comment
  • ricardo cafolla Apr 22, 2013
    Hi Lars have two of these computers and same problem with both, they work normally when it hd boots to Xp but just can't get it to boot from cd on start up
  • Lars Olsson
    Lars Olsson Apr 22, 2013
    ricardo. a suggestion try with a other cd/dvd-writer. external or internal.
    Will indeed try ...many thx will let u know how it goes
  • 3 Answers
I want supreme vilking orientations
crash76
  • 185 Answers
SOURCE: My Compaq Presario would not
Of course. You can use some live linux distro (Ubuntu in example) or Hiren's Boot CD (one of the best tools, download here: http://rapidshare.com/files/426971514/Hirens.BootCD.11.1.rar )
Posted on Oct 24, 2010
techniwiz
  • 275 Answers
SOURCE: On my HP Pavilion I
try resetting all the connections and also disconnect the power cable from the back of the computer and hold down the button for 10 seconds and start the system that should work
Posted on Feb 01, 2009
support793
  • 81 Answers
SOURCE: Have A HP 735P made recovery disks when computer
The most likely cause of this, is that the new hard drive is not the same as the orginal. Restore media is setup to install only on OEM. Orginal Equipement. If the new hard drive is larger or smaller then the orginal it will not properly load.
The easiest solution to this is if the new hard drive is larger, use a disk setup utility and create a partition the same size as the old drive.
If your drive was retail the software to do this will have been in the box. If you purchased an oem drive you can download the drive setup tools from the manufacturers site.
The drive setup utility is easy to use. Boot to it and choose setup drive. When selected it then procedes to the screen where you will need to set the size of the partition. 1024MB is 1 GB. This will help you detemine the size of the partition you need to set.
Good luck
Posted on Apr 03, 2009
  • 10406 Answers
SOURCE: I have an HP 513n, currently running Windows XP
Yes. Install the hard-drive, and use Windows XP to "partition" and "format" the second disk-drive.
When installing Windows 7, be sure to "point" the installer to the drive-letter of the second disk-drive.
Windows 7 will create a "dual-boot" environment.
Posted on Jan 29, 2010
technical114
  • 1851 Answers
SOURCE: trying to boot and change bios start up for compaq d530 sff
Unplug the case from the power, open the cover and try to locate on the motherboard a small round battery (a little bigger that the one at the electronic watches) TAKE CARE THAT THE TOWER IS UNPLUGGED FROM THE MAINS. Very carefully remove the batery and wait 1-2 minutes. After that insert the battery back, close the case, plug the tower and start the pc. It will boot at the default bios settings, without passwords but you have to make the settings again (date, boot order e.t.c.)
In case of a problem post back.
Stelios.
Posted on Feb 23, 2010
Dell bootmgr is missing
Most likely cause is that the boot order in the BIOS is set up for the HDD first. When turning on the unit, press the key needed to enter setup. Once in setup, search thru the menus for the boot order. Choose the CD drive as the first boot device, then the hard drive as second. Save and exit the setup. When rebooting, ensure the WIN XP CD is in the drive. When the screen says, "press any key to boot from CD", press a key and the WIN XO CD should take over and start the install. Once WIN XP starts installing, follow directions. On each restart after that, DO NOT press the key to boot from CD. WIN XP setup will handle everything until the reinstall is complete. After you are done, you may choose to go back to setup and change the boot order back, but it is not really necessary. The only time you will get the "press and key to boot from CD" message is when there is a bootable CD/DVD installed in the drive. Otherwise, it overlooks it and goes to the next boot device (HDD).
Sep 07, 2014 | Dell Inspiron 2600 Notebook
Cannot boot from cd rom on compaq evo d310v, i have lost all disks but have the product key if it makes a difference. So what i wanted to do was wipe the hard drive with dariks boot and nook then inst
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
Apr 21, 2013 | Compaq Evo D310v PC Desktop
Acer aspire one nav50 how to install windows on new hard drive
To install windows on a hard drive you have to boot from a CD with windows XP on, after which it will ask you to press a button.
After which you can follow the setup instructions in windows XP.
Mar 01, 2012 | Acer Aspire One PC Notebook
I bought a LENOVO B 450 laptop. The dealer installed WIN 7. But in WIN 7 Tally 7.2 will not work. So I wish to install WIN XP. But when I tried to install WIN XP there shows an error message and a blue...
Please note that installing an operating system on an OEM machine OTHER than what was factory-installed on it may void either phone support for the customized OS or the warranty itself.
Lenovo Machines, like most new OEM models are set, by default to run their hard drives in AHCI mode for better performance & power management. Go to the computer's system setup F1 or Del while the computer is starting up to locate the Power, Hard drive or System configuration (Lenovo computers have different System Setup formats for each model so you'll have to navigate around a bit since they may be labeled differently).
Once you find it, you have to change the setting from AHCI to IDE or Compatibility, whichever option is available (once again, each model has a different format & labeling convention). Save the changes & exit the setup & retry the installation. Should work.
Aug 13, 2011 | Computers & Internet
RM Z91FR laptop I want to remove the windows "Vista Ultimate" operating system and go back to XP Vista has slowed the machine drastically and filled the HD. I also want to instal a larger HD...
try to format all your drive by deleting your partition..insert your xp cd room boot with cd room press enter, press f8 press esc, press d, press l, then press c and enter
May 06, 2011 | ASUS Computers & Internet
My computer formatted i have genuine product key how to get win xp home edition and install in my computer
Put the genuine Microsoft CD-ROM disk into your CD-ROM drive.
Restart your computer.
As soon as it starts, look for a message like "press Fxx to temporary change boot-order".
Press that key.
Select to boot from you CD-ROM drive.
This will start to install Windows, by reading from the CD-ROM drive.
Apr 23, 2011 | Microsoft Windows XP Home Edition
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
How do I format C drive with windows 7 on it I want to put windows XP on
hi
thank you for using Fixya
to formate C drive and re install windows XP
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
then just folow the instruction
it will ask you foue setps
May 16, 2010 | Compaq Presario CQ60-220US PC Laptop
Can i change the operating system from windows vista basic to windows xp?
I would advise you not to do so. Most manufactureres did not release proper drivers for windows XP, as MS didn't encourage them to do so.
I can advise you to install windows 7 instead. I've installed it on all of my computers and I'm more than pleased. You can even run different programs as if the windows was XP... (and no, I don't work for Microsoft...)
Jan 12, 2010 | Acer Aspire 5335-2257 Notebook
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
HP Compaq Evo D310 PC Desktop Logo
195 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
