Question about Luggage & Travel
How to replace batteries
Scale reads low battery. Replaced with new batteries, but readout still says Lo Bat and then shuts off
  • 232 Answers
SOURCE: Batt Lo Displayed. I replaced with new batteries.
sometimes you can bend out the battery holders to allow more tention on the batteries but thats only a temporary repair. a new thermostat is needed
Posted on Oct 28, 2009
Testimonial: "Thanks! It appears that you are right--I even tried other "new"batteries....Off to buy a new thermostat."
  • 17 Answers
SOURCE: When you step on the scale the readout says
Yes it means battery needs replacing. Check oringinal papers that came with scale to see if you need to order special battery. Otherwise go to a battery store that recharges batterys. They usually carry most makes. Take your battery with you so you can match right one.
Posted on Dec 10, 2009
  • 5 Answers
SOURCE: Replaced batteries last week, scale worked fine
use alkaline battery and make sure that you switch it off after use
Posted on Feb 16, 2010
SOURCE: I replaced the batteries in my Honeywell CT3300
Per manual do this: System set to Off Remove batterie Replace IN REVERSE POLARITY POSITION or 5-10 seconds Put back in with CORRECT POLARITY Reprogram per sticker on back of thermostat. Done. Just did this myself and it's simple and effective! PaulHaven
Posted on Nov 23, 2011
SOURCE: my beutler 800 said lo
The other "solution" posted here is not a solution. According to this web site: http://www.espenergy.com/faq_honeywell_thermostat.htm
First, replace the batteries with a new set of AA alkaline batteries. If you insert the new batteries within 20 to 30 seconds of removing the old ones, you will not have to reprogram the thermostat. If the bAt Lo indication does not clear itself once new batteries are placed in the device install the batteries backward for 5 seconds, take them out, and reinstall correctly.
So I tried it... put the batteries in backwards. It completely reset the thermostat so I had to reprogram it (which was easy enough). One thing I did that the instructions did not specify. After I removed the batteries, I let it go completely blank before installing them backwards. Then I waited 5 seconds, pulled em out and put them back in correctly and eventually it started flashing indicating it needed to be programmed. HINT: Don't forget to set the current time!
Posted on Dec 10, 2012
What does it mean when my Boflex body fat scale reads Lo then turns off
My scale readout is now blank? Do I have to buy a new battery?
First, did you notice of the scale had a "lo" or "bat" display before it went blank? If so this means the battery needs to be replaced. If you did not get the battery indicator, did you "miss" seeing this? Has it been a week since you were on the scale? If you stand on the scale regularly and did not receive the battery indicator then you can try the reset procedure above.
Source: <http://www.taylorusa.com/faq-scales> Syz D
Aug 22, 2014 | Health & Beauty
Model ww66
In the event that the scale battery needs to be replaced, (display shows "Lo"),
open the battery cover on the bottom of the scale and replace the old battery with
a new 3V lithium battery.
Jun 04, 2014 | Conair WW60 Weightwatchers Scale
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
http://www.taylorusa.com/media/IBs/7506_ib.pdf
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
Apr 23, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
My beutler 800 said lo bat we replaced them and still reads bat lo
Dec 04, 2010 | Honeywell Programmable Thermostat Heater
Even after replacing the battery, the programmable Honeywell thermostat still shows "Low Batt."
Turn control to off. Remove the batteries for at least one hour. If the display message still reads "bat lo", leave control off, batteries out, and disconnect the red wire on back and wait another hour. Reconnect red wire, put new batteries in and turn system on. It's like a reboot.
Jan 26, 2010 | Honeywell Programmable Thermostat Heater
When you step on the scale the readout says "LO". Does this mean low battery, and if so I can't find a battery to replace.
Dec 10, 2009 | Taylor & Digital Scale Lithium Scale
6AE Lo
6AE Lo is probably 'bAt Lo'. Batteries are low and need to be replaced.  It looks like 6AE Lo because of the digital readout (b looks like 6).
Model number shouldn't change what the readout means.
Oct 14, 2009 | Honeywell CT3600 7 Day Electronic...
MY bfm588dq-81 scale is malfunctioning. The
Throw it away. The product sucks. I know, I'm throwing one away right now and I"ll NEVER purchase one again.
Aug 17, 2009 | Health-O-Meter Health o Meter BFM588DQ-81...
Scales showing Lo after battery has been replaced
Anytime you have trouble with a Taylor scale - they have a lifetime replacement warranty. You need to call their 800 number and pay for 1 way shipping and they will send you a new one.
Jun 04, 2009 | Taylor & Digital Scale Lithium Scale
Luggage & Travel Logo
499 people viewed this question
Top Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a Luggage and Travel Expert? Answer questions, earn points and help others
