Question about Cell Phones
Not sure of product name
Hi there seams you are keep adding to my bill . and its been turn off for mo. so please stop what ever account I have till we agree with a real solutions thanks ROB
  • 11 Answers
SOURCE: p steering slow leak;can i buy and replace o ring easily
for this p steering pump it's recomended to replace it.
As my experience,repair (o/h) will not solve the problem for long.
attention ! this leakage will damage the alternator (it's located right under this p s pump)
Posted on Oct 04, 2008
shafykp750
  • 1070 Answers
SOURCE: postpad idea datacard no 9927843999 Account No. :
Welcome to FixYa
To view online Idea cellular bill for mobile phones payments just register on the Idea Website click here. You need to have your postpaid mobile handy also one email address. Once you you register there they will send you pin no on your mobile number via sms. Just enter that pin number in required place and you are ready to check and pay your bill online.
In case registration fails, kindly get in touch with Customer Care to complete the registration process...
There you can Available to check and All about your Plan Details....
If this HELPED you-RATE me....Thanks for Contacting FixYa...
Posted on Jun 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: Hi my name is rob oulette,I have the epic model
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
  • 4340 Answers
SOURCE: Hi. Please can you tell
Rob, this change is router brand and model relevant. In essence you need to log into the router and change the wireless settings. Go to the website for the brand and download instructions relevant to yoru specific unit. You want to invoke WEP wireless security, and assign yoru own password, often yoru 10 digit home or cell phone number, change system ID to something that you recognize, change AND RECORD the changes that you make. Also, change the broadcast channel to 11 or so, and have less issues with land line wireless phones.
There is much higher security that you could invoke, but typically just passwording the wireless access does it.
Posted on Oct 15, 2010
  • 8404 Answers
SOURCE: I had a friend who is deceased now. I keep getting
I am sorry to hear of your loss. FixYa.com has no say as to the functioning or operation of MSN.com. Please have Mr. Patteson survivor or fiduciary contact MSN.com and explain the situation and ask that the account be closed.
Thank you for your question @ FixYa.com
Posted on Mar 12, 2011
Hi my name is James Thomas and I keep getting billed on Facebook and I never put my credit card number on there can you please help me out as soon as possible please and thank you
The BBB (BETTER BUSINESS BUREAU) has been advising members on Facebook to be extra careful when entering personal information on any site but here lately scammers have set up a page that looks like the real Facebook page. Before entering your private information I suggest logging off whatever site that is sending you these notices and log in to the real Facebook account. If you're still leery, try emailing or contacting Facebook yourself to verify any questions you may have concerning bills from them. I hope this helps you.
Mar 23, 2015 | Facebook Computers & Internet
Account cancel deactivate settings
hi my name is shaun and my email address is ssacco@schiavello.com Please take me of your listing I am being charged each month and I do not know why. Please stop billing and take me off straight away.
thankyou
Dec 14, 2013 | cupid.com
How do I cancel direct debits
When subscribing to services or products that require a monthly payment, it can sometimes be a hassle to keep contacting the service provider each month to make your payment.
If you are like many individuals, you will opt to have the payments automatically deducted from your banking account.
While this automatic debit option may seem momentarily convenient, in the long term it can be risky.
Even if you are no longer receiving the products and services, some companies will continue to debit your account.
If you have decided that you no longer want the automatic debits from your bank account to be made, there are easy resolutions to stopping the payments.
Call the customer service telephone number of the company that is making the automatic debits from your bank account.
If you don't have a telephone number for the company, visit the company's website and look for the "Contact Us" link.
Most legitimate companies will have contact information on their site.
Select the option to speak with a billing or sales representative.
Advise the company representative that you no longer want the automatic debits to come out of your bank account.
Be sure to get the representative's name and a confirmation number just in case you later need proof that you did call in and make the cancellation request.
By Mail
Write a cancellation letter to the company stating your desire to stop the automatic debits.
Be sure to include your account number on the letter as well as your signature and the date the letter was written.
Make a copy of the signed letter for your own records.
Mail the cancellation request letter to the company that is deducting the automatic payments from your bank account.
If you don't have the mailing address, you can visit the company's website or contact customer service to get it.
Note that some companies require that your request be submitted within a certain amount of days before the next billing cycle.
Through Card Issuer
Contact your bank or the financial institution that provided you with the debit card if you notice that the automatic debits have not stopped.
Ask the bank representative to place a block on your account or debit card so that the automatic debits are stopped.
There may or may not be a fee assessed by your bank to initiate the block.
Request that your banking institution completely cancel your debit card if the option to place a block on the card is unavailable.
After your old card is cancelled, your bank will issue you a new replacement card.
Ask for the bank representative's name and a reference number for your own personal records.
Nov 04, 2013 | Computers & Internet
Unit will not turn on.
i just answered your last post regarding this magellan 300.
bill
Aug 26, 2009 | Magellan RoadMate 300 GPS Receiver
Adjusting for PayPal fees when recording payment received
Actually, you do not want to reduce the product name. When you make the deposit from PayPal, you want it to be for the full amount the customer paid. Then add a second line with a minus amount for the fees, and the account of paypal fees (expense). This way, you split off the fees paid to paypal as an expense, and the bank reconcile matches.
Attempting to reduce the ProductName will only result in tax liability issues, as you have to charge sales tax on the full amount the customer was originally charged.
Using a negative line on the deposit to split the paypal fees off is a much cleaner process, and causes no confussion for the accountants.
Oct 31, 2008 | Intuit QuickBooks Pro 2007 Full Version...
P steering slow leak;can i buy and replace o ring easily
Aug 18, 2008 | 1995 Lexus LS 400
I have a charge on my visa card for TB AOL perfect Disk Live for 4 months and I did not order and I want it taken off of my computer at once. If not you then who can I contact. Thanks
My credit card is currently being billed for a subscription to an AOL product called PerfectDisk Live. How can I cancel this subscription that I signed up for on AOL?
PerfectDisk Live is a subscription that is only offered by AOL and is not a Raxco supported product. For this reason, Raxco does not have access to your billing or account information. Raxco has received numerous inquiries regarding this subscription and we understand the reason for the confusion.
We have contacted AOL Customer Service regarding this matter and they have assured us that they will take care of any customers that wish to cancel their subscription. They asked if we could provide the instructions below to customers that contact Raxco regarding this matter.
Please email your cancelation request to support@aolproductcentral.com. To help AOL expedite your request, please include your full name, any other screen names, and your billing phone number. Also, make sure that your request that you wish to cancel your subscription to PerfectDisk Live.
This is from the FAQ on the Raxco site.
http://www.raxco.com/Support/cust_detail.cfm#cs65
Hope this helps. M~
May 01, 2008 | Dell Dimension 3000 PC Desktop
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
