Question about KitchenAid Kitchen Ranges
Oven door handle is loose on one side, no place to tighten it
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Apr 23, 2013
Skill Will
  • 53 Answers
SOURCE: How do I tighten the
hi,
Remove the door from the oven, most doors you just open to the first stop point and lift up on the door, if yours doesn't let me know. Then, most doors have screws on the top and bottom, some also have them on the side, remove those screws and the front and back of the door will separate, the screws that hold the handle are in there. Remember to use caution with the glass when separating the door panels.
Posted on Apr 06, 2008
rickzilla
  • 706 Answers
SOURCE: I have a Maytage MER5775RAW electric stove and need to take the door apart
Try this website..it shows and exploded view and a parts list if you punch in your model number.. http://www.pcappliancerepair.com/model-display.php
Hope that helps...
Posted on Aug 22, 2008
aborcass
  • 2651 Answers
SOURCE: MAYTAG PERFORM OVEN DOOR,THE HANDLE IS COMING OFF.
in your user guide it explains procedure to remove the door, after emoving the door and layingit flast on conter /table ita amtter of removing sccrews holding on glass, and top trim to get to the screws that holdon hanlde, a little patience is all thats required not hard here
Posted on Mar 07, 2009
  • 31 Answers
SOURCE: oven door handle (right side)came loose
If you put the door at a 45 degree angle on the hinges, it will lift right off. Then once on the ground, it should be easy to remove the screws of the inner panel and expose the screws that the door handle attaches to.
Posted on Mar 13, 2009
SOURCE: Kenmore Electric Range - Door handle
I had the same problem with my stove. I tried to replace, glue the srews and other things, but nothing really worked well. It's a shame that Kennmore has such a design flaw in their stoves, but did nothing to help their customers.
Here is the solution that worked for me:
Fix the thread with helicoils (these are inserts that create a new threat in the handle). You can find the instructions how to use the helicoils on Youtube.
I replaced the crews with new screws that fit to the helicoil threat and now the handle is safely secured.
Regards
Michael
Posted on Aug 24, 2009
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
I have a loose door handle, how do i fix it? Do i have to take the door off?
Hi You will have to open the oven door and take the screws out of the side that faces inwards to the oven. Once the screws are removed the door will come apart. And then you can tighten the screws to secure the handle better. Also before you do that look under the handle and make sure there are not any set screws in it that tightens down to an anchor. They usually will be hex or allen screws .
Dec 16, 2010 | Magic Chef CER3760 Electric Kitchen Range
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Loose door handles.
There was a plastic card the size of a credit card that came with the refigerator that helps release the handles. If you don have this you can use any stiff plastic card ie: blockbuster card, store card etc...
Pull the handle away from you while inserting the card in the top or bottom of the handle based on your model. I believe the Admiral model LSD2615HEB required the card be inserted 11/16 of an inch. This should release the handle. Once released there are 4 hex screws located on the handle that may require tightening.
To reinstall: Match the hardware up just above the final location and then slide down, this should lock the handle back into place.
Feb 24, 2009 | Admiral 26 cu. ft. Side-By-Side...
Loose oven door handle on kitchenaid gas range
youl have to take apart the door.the screws are on the other side of the glass/framing
Dec 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Loose door handle
If a tight place is worn out, then try warmer temperature and go to the tools store to place the door with your new tools.
Aug 08, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
How do I tighten the handle to the oven door, it has come loose and I can't see where I can access to tighten.
hi,
Apr 05, 2008 | Kitchen Ranges
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
I would try putting some locktite on the threads so It wont come losse anymore.
Nov 07, 2007 | Ovens
Kitchen Ranges Logo
158 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
